I upgraded a Vista 32-bit to Win 7 64-bit and now cannot seem to install. A message indicates I should check the 32-bit or 64-bit compatability.
Thanks for any assistance.
I don't think PRE 5.1 will work on Win 7, be it 32 bit or 64 bit as it was never tested on Win 7. Also, so far we only have 64 bit version for PRE 10, not for previous versions.
So, you can try rebooting the machine or turning off UAC and perform selective sartup and check if that helps.
Better option is to upgrade to PRE 10.
[Moved to Premiere Elements Forum]
If you have Win7 64bit PRO or higher, try Microsoft's Virtual XP
This is only ONE example of using Virtual XP http://forums.adobe.com/thread/702693
-And a Tutorial http://windowssecrets.com/newsletter/using-windows-7s-xp-mode-step-by- step/
Welcome to the forum.
There was no Premiere Elements 5.1. PrE skipped from version 4 to 7, to align its version numbers with those of Photoshop Elements.
Now, there was a PrPro CS 5, and I believe that it was updated to 5.1 (maybe 5.0.1?) PrPro, as of CS 5 is a 64-bit OS version only.
Exactly which version of which program do you have?
Good luck,
Hunt
Got you, and thanks for that clarification. You want the Premiere - Premiere Pro CS4 & Earlier Forum. Not sure of the answer, but someone there can help you.
Good luck,
Hunt
[Thread moved from Premiere Elements Forum]
You will not be able to install Premiere 5.1 (quite an oldy) on a 64 bits machine.
5.1 is only 32 bits.
