time lapse
Jun 23, 2012 6:22 PM
Tags: #time #timelapse #lapse #shift #tilt
can anyone suggest the best snap rate for time lapse?
I`m using a camcorder that allows 3 seconds or 10 seconds, i wanted to film high on an angle and do a tilt shift video, would I use shooting of one frame per 3 seconds or per 10 seconds?
i`d be filming for 7 hours.
    Jun 23, 2012 6:35 PM   in reply to bluefire777
    What is the subject matter?
    I have done several Time-Lapse Videos, but use an intervelometer on a still camera, and adjust that, depending on the subject, and its movement.
    Then, I adjust the Still Duration in Edit>Preferences to somewhere between 3 - 5 Frames, again, depending on the subject, and assemble in Premiere.
    Good luck, and let us know a bit more, please.
    Hunt
    Jun 24, 2012 9:20 AM   in reply to bluefire777
    It is good that you are checking things out before hand. I would test, on a similar subject, if possible.
    I have never shot Time-Lapse on a video camera with built-in intervelometer, so have no tips to add there. You know more about that, than I do. With still cameras, and still images, I usually adjust the frequency for both the subject, and the "look" that I am after. Say with clouds streaking across the sky, I have used about 1 Frame per 5 sec., but have also gone with a longer frequency, up to about 1 Frame per 30 sec.
    Good luck, and please share your settings, when your testing is done. Also, travel safely.
    Hunt
