Installation CS6 64bit and 32bit
Jun 24, 2012 10:14 AM
Tags: #cs6 #64bit #32bit #installatioin
When I installed the downloaded Photoshop CS6 software, the application offered to install BOTH 64bit AND 32bit versions.
Never seen that before, usually software looks at system and installs the correct version (or you choose before downloading).
I have Windows 7 64bit system.
Is there a reason to install BOTH?  Is there a problem to have both installed?
    Jun 24, 2012 12:33 PM   in reply to LA2NV
    PS CS 6 on 64 bit machnie offers you both the options 32 bit as well as 64 bit.
    Its your choice to install both or any one of it.
    64 bit Photoshop can utilize more RAM installed on your machine and will respond better to larger files as compared to 32 bit
    On 32 bit OS , there is no choice given because the only option left out is 32 bit photoshop.
    If you install both the versions, there will be "NO PROBLEM AT ALL"
    Jun 24, 2012 11:11 PM   in reply to LA2NV
    Yes. TWAIN for scanner support and other legacy support features that only exist as 32bit software.
    Mylenium
    Jun 25, 2012 12:36 PM   in reply to LA2NV
    Moving this discussion to the Photoshop General Discussion forum.
