Have been tryiing to use dreamweaver to do popup menu and it was very easy with dreamweaver 8 but dreamweaver CS3, 4 & 5 is not easy. The idea is to come up with a layout in photoshop then slice it, take it to dreamweaver and use one of the images as a menu so when you mouse over the munu pops up and drops. I have tried with spry but spry cannot work with existing images, I will really appreciate if I can get help on this
Let's start with basics. You say this -
"The idea is to come up with a layout in photoshop then slice it, take it to dreamweaver"
Are you exporting the layout from Photoshop as HTML? If so, then you are heading down the wrong path. That feature of PS is *only* useful to create a quick PROTOTYPE of the page/site that would be used for a controlled demonstration of the final product. The resulting "HTML" page is not (and never has been) suitable for use in a real web page/site. This is because the code is very 'rigid' and relies on that rigidity to exactly reproduce the physical layout in PS. When placed on the web, unexpected variables come into play, like browser text display size, and those variables can cause your page to develop gaps between the various text regions (that's a best case failure example). PS (or FW) should be used only to produce the graphic elements that are found on your page. DW is what should be used to create/write the page's HTML infrastructure.
(I won't go into all the ways that using DW8's popup menus were wrong)
Then you say -
"use one of the images as a menu"
Are you using a single image as a menu, or multiple images?
Then you say -
"spry cannot work with existing images"
But that's not the case. You can make a spry menu using existing images. It just may require some additional work on your part.
Thank you very much for your reply
now this part is what i need to know
*" You can make a spry menu using existing images. It just may require some
additional work on your part."*
Let me know what I should do to make it work. Just to let you know am a
graphic designer, before about 3 years ago i used dreamweaver to do
websites so the last dreamweaver I used was 8 after that i started using
CMS but after a while i came to realize that my design skills are limited
when i use CMS so now am back to dreamweaver and that small issue is making
me almost go mad.
Assistace wil be highly appreciated.
Regards
This is the actual web that i want to work on.
http://www.friendsofsafaris.com/
The Destination, Adventures & Mountain Climbing Menus need drop down menus
that pops up when you mouse over. The menus are images, please check
Yes I saved the layout from PS as html
Regards
Here's an example page. It will require some manual work in the code. Alternatively you can use my code on your page.
http://www.gws-sandbox.com/test-sprymenu-horizontal.html
Your table-based menu is shown above, and the modified Spry menu is shown below it (with dropdowns).
