Hi, I've recently downloaded flashbuilder 4.6 and started to develop my first mobile app.
Just to explain the sense of my problem/question, I'd like to manage a local database offline (insert data to a table) and manually sincronize it to a server database (push a button -> add records batch to table in server).
Following tutorials I was able to manage a sqlite local database, I got the connection to server database (mySQL) with php and have Data/Services panel populated (services test works fine).
Unfortunately I'm not able to send local data, batch to server. A few lines of code below (debugging I got no errors and no results).
Something wrong on the code?
Or did I take a wrong way to solve my problem?
thanks in advance for interest
protected function button_clickHandler(event:MouseEvent):void
var LocalDatabase:ArrayCollection = ... <loaded from sqlite database>
var RecordToAdd: MydataTable; //server data table to fill
for (var i:int= 0; i<LocalDatabase.length; i++)
RecordToAdd = new MydataTable;
RecordToAdd.Field1= LocalDatabase[i].Field1;
RecordToAdd.Field2 = LocalDatabase[i].Field2;
createMydataTableResult.token = MydataTableService.createMydataTable(RecordToAdd);
createMydataTableResult.token = MydataTableService.commit();
Hello
you said "Following tutorials I was able to manage a sqlite local database, I got the connection to server database (mySQL) with php and have Data/Services panel populated (services test works fine)."
can you indicate some tutorials with that? i am trying to do the same thing but i'm having some trouble...
thanks
