In my quizzes, I don't want to have learners going back to previous quiz slides until they get to the Results slide. I also want them to answer every question and to not skip any questions.
In the Results slide, they can click Review Quiz to go back to previous quiz slides.
To prevent learners from navigating back to another quiz question while taking the quiz, I removed the playbar on the quiz slides.
I would also like to remove the Skip button, but if I do, with the playbar hidden the learner has no way to navigate forward when they review the quiz. On the other hand, when they are answering the quiz questions, they are able to click the Skip button and not answer the question, even if Incomplete option is turned on.
NOTE: This whole problem comes about because of a bug in Captivate. If a learner enters a quiz slide, without answering the question or clicking on Submitt they navigate to the previous slide, then they navigate back to that same quiz slide, Captivate acts as if the learner has already clicked Submit and the learner can no longer answer the question.
Jay
What's your captivate version? All the above mentioned use cases have been addressed in Captivate 6 and how
1. Submit all - a new option which allows users go back and forth and also ensure they answer all the questions
2. New quiz scope which gives lot of flexibility to Captivate developer
Suresh J
Captivate Engineering team
Hi Jay,
I cannot remember if I already suggested to drag the Skip button under the Clear button and rename its text to 'Next' because that is its function while reviewing.
There is a stack order for the buttons on question slides. And the Clear button will not be visible during Review, so the Next button will then be available.
About stacking order and other question/score slide functionalities:
http://lilybiri.posterous.com/question-question-slides-in-captivate
http://lilybiri.posterous.com/question-question-slides-part-2
Lilybiri
Lilybiri,
You did suggest that before, but I couldn't make it work. This time it did work. I discovered that the reason it didn't work the first time was that the Clear button and the Next button don't always have the same stacking order. It depends on the order that you click the check mark to display each of these buttons in the Properties panel.
Suresh,
Thanks for letting me know about the new features. In fact, I was going to convert my project to version 6, but when I tried opening one of the modules, the file size bloated to twice the original size. Perhaps it would publish at the same size as version 5.5. I haven't had time to try publishing from version 6 yet.
I'm not Jay, but he will not mind I think ![]()
The system variable cpCmndShowPlaybar can be changed. Default value is 1 and the playbar will show. To hide it:
To show it again on a later slide, repeat this work flow, but change to the value 1 again.
Lilybiri
