I have a multi folio viewer app but now Im out of ideas how to submit the second issue in. I've went through all the manuals please help or point me to right direction
is there a step by step guide how to publish the consequent folios? I had no problem with the first one and theres plenty of documentation but I have no idea how the second one should be published. Do I have to go to itunes connect at all? What to do after it is published from folio producer. The id is in this form com.brand.magazine.july2012 is there something wrong with that?
Publishing the second folio is simple. Here are the steps:
For Retail Folio:
1.) Go to Itunes connect and make a In-App Purchase
2.) Wait for Apple to review and approve it
3.) Once approved go to digitalpublishing.acrobat.com and
4.) Select the options as "Public" & "Retail" and publish the folio using the same Product ID created in Itunes Connect for the In-App Purchase.
For Free Folio:
1.) Go to DigitalPublishing.acrobat.com and click on folio Producer
2.) Click on the Folio and click the Publish Button
3.) Select the options as "Public" & "Free"
4.) Enter The Product ID and Hit Publish
Make sure that you are using a unique product Id for ever folio except in case of renditions...
Thanks for the help!
It's all clear now. But we're still not getting the new issue in. Where should we start the troubleshooting? We've tried to upload multiple times again. I think the problem is somewhere between our app and adobe server since the upload etc are ok. Should we remake the content viewer again and update it?
Are you able to see the folio inside the Adobe Content Viewer?? If it is a free folio you should be able to view 2 folios one with a blue badge and another without. The one without is the one that shows up inside the App.
Try to download the one without the blue badge if you can view it and see if it works inside the adobe content viewer.
Also check that all folio have the correct orientations i.e if you are doing a folio with horizontal and vertical folio than check that all the articles have the orientation or not , if even one of them is missing the orientation than that can be the cause of your problem and you need to add the orientation to fix this...
hi, already found very usefull comments about publishing the second issue of a multi viewer app but still can't figure out if we have to use the same Product ID for each issue in 1 multi viewer app, or do we need to create a different Product ID for each issue ?
figured it out myself, using a different Product ID works. With the same Product ID for 2 issues the testapp crashes while opening.
