anabliss
Indesign CS5 won't print specific pages within document
Jun 25, 2012 8:26 AM
Tags: #problem #cs5 #error #mac #printing #indesign_cs5 #print
I'm working on Indesign CS5. The issue is with a specific document, and just started happening on version 11. All previous versions of the file have printed with no problems. I have so far determined that it is a document level problem as I can print other documents in Indesign with no issues. I have also determined which pages are giving me an error message: I can print all but one spread of this 16-page document. For example, it will print pages 1-9 and 12-16, but will not print 10-11. It gives it a try, and then gives me an error message box that just reads "error: " with no code or explaination. Any one else out there experienced this or know what's going on? There's no overset text, unlinked graphics or missing fonts, if that helps. Also, I'm working on a mac.
Edit: I have also already tried different print settings, and repasting everything into a new document that I created.
    Jun 25, 2012 11:02 AM   in reply to anabliss
    This is very basic stuff, but it is somewhere to start. Have you tried the suggestions in this thread?
    Jun 25, 2012 2:37 PM   in reply to anabliss
    If that doesn't work, move the pages from spread to a new document so you can play without risking the file you have now. First, try to print the spread as-is, then if it doesn't print remove half the objects and try again. If the file prints without removing anything, then move all the pages fromthe old file to a new one and save with a new name, then try again. If you have to remove objects, there is probably a problem with one of the objects on the spread. You'll bew able to isolate it very fast by dividing the group of things that won't print in half, then dividing the half that won't print, and so on.
