Athang
Resizing Video without quality loss
Jun 25, 2012 6:15 AM
I am facing a problem in video resizing, could someone help me to resolve this issue.
I want to scale video to available content size (stage size) without distorting quality like VLC player.
Here is my code.
FLA Code:
import flash.display.StageScaleMode;
import flash.display.StageAlign;
import flash.events.Event;
var videoMC : MovieClip = new MovieClip ();
this.addChild (videoMC);
var videoMgr:VideoManager = VideoManager.getInstance();
videoMgr.init ("sampleFile.flv");
videoMC.addChild (videoMgr);
// this tells Flash NOT to allow the assets to be scaled
stage.scaleMode = StageScaleMode.NO_SCALE;
stage.align = StageAlign.TOP_LEFT;
// need to set up a listener object to say when the stage is resized.
stage.addEventListener (Event.RESIZE, onStageResize);
setBackground ();
// called when the stage is resized
function onStageResize (evt : Event)
          setBackground();
function setBackground ()
// determine middle
          var middleX = stage.stageWidth / 2;
          var middleY = stage.stageHeight / 2;
          // reposition the bkgd to middle
          videoMC.x = 0;
          videoMC.y = 0;
          // scale background to fit width and height
          videoMgr.updateVideoSize (stage.stageWidth, stage.stageHeight);
          // see if it grew bigger horizontally or vertically and adjust other to match
          // to maintain aspect ratio
          //videoMC.scaleX > videoMC.scaleY ? videoMC.scaleY = videoMC.scaleX:videoMC.scaleX = videoMC.scaleY;
AS3 Class:
package
  import flash.display.Sprite;
           import flash.events.AsyncErrorEvent;
           import flash.events.NetStatusEvent;
           import flash.events.SecurityErrorEvent;
           import flash.events.StatusEvent;
           import flash.events.TimerEvent;
           import flash.media.SoundTransform;
           import flash.media.Video;
           import flash.net.NetConnection;
           import flash.net.NetStream;
           import flash.utils.Timer;
          public class VideoManager extends Sprite
                    private static var _instance : VideoManager;
                    private var con : NetConnection;
                    private var vStream : NetStream;
                    private var video : Video;
                    private var vWidth : uint;
                    private var vHeight : uint;
                    private var filePath : String;
                    public function VideoManager (enforce : Singleton)
                    public static function getInstance () : VideoManager
                              if (_instance == null)
                                        _instance = new VideoManager (new Singleton);
                              return _instance;
                    public function init (path : String, w : uint=720, h : uint=480) : void
                              filePath = path;
                              con = new NetConnection ();
                              con.addEventListener (NetStatusEvent.NET_STATUS, onNetStatus);
                              con.addEventListener (SecurityErrorEvent.SECURITY_ERROR, onNetSecurity);
                              con.connect (null);
                    public function updateVideoSize (w:uint, h:uint) : void
                              vWidth = w;
                              vHeight = h;
                              video.width = vWidth;
                              video.height = vHeight;
                    /*public function playVideo (startFrom : uint) : void
                    public function pauseVideo () : void
                    public function resumeVideo () : void
                              vStream.togglePause ();
                    public function stopVideo () : void
                    public function hideVideo () : void
                    public function setAudioLevel (val : uint) : void
                              var sndTrans : SoundTransform = new SoundTransform (val);
                              vStream.soundTransform = sndTrans;
                    private function connectStream () : void
                              vStream = new NetStream (con);
                              registerStreamEvents ();
                              video = new Video (vWidth, vHeight);
                              video.attachNetStream (vStream);
                              vStream.play (filePath);
                              startPreloader ();
                              addChild (video);
                              trace (vStream.bytesLoaded + "/" + vStream.bytesTotal);
                    private function registerStreamEvents () : void
                              vStream.addEventListener (StatusEvent.STATUS, onNetStatus);
                              vStream.addEventListener (AsyncErrorEvent.ASYNC_ERROR, onAsyncError);
                    private function unRegisterStreamEvents () : void
                              vStream.removeEventListener (StatusEvent.STATUS, onNetStatus);
                              vStream.removeEventListener (AsyncErrorEvent.ASYNC_ERROR, onAsyncError);
                    private function onNetStatus (evt : NetStatusEvent) : void
                              switch (evt.info.code)
                case "NetConnection.Connect.Success":
                    connectStream();
                    break;
                                        case "NetStream.Play.Complete":
                                                  videoPlayComplete ();
                                                  break;
                case "NetStream.Play.StreamNotFound":
                    trace("Unable to locate video: " + evt.toString());
                    break;
                    private function onNetSecurity (evt : SecurityErrorEvent) : void
                              trace ("Error occured in connection. " + evt.toString());
                    private function onAsyncError (evt : AsyncErrorEvent) : void
                              // This is mandate handle
                    private function startPreloader () : void
                              var tmr : Timer = new Timer (100);
                              tmr.addEventListener (TimerEvent.TIMER, checkLoadProgress);
                              tmr.start ();
                    private function checkLoadProgress (evt : TimerEvent) : void
                              if (vStream.bytesLoaded == vStream.bytesTotal)
                                        trace ("Stoping the timer.");
                                        evt.currentTarget.removeEventListener (TimerEvent.TIMER, checkLoadProgress);
                    private function videoPlayComplete () : void
                              // TODO: Dispatch event which will indicate that video is at end.
internal class Singleton {}
  • kglad
    Jul 21, 2002
    Jun 25, 2012 8:03 AM   in reply to Athang
    video.smoothing=true;
                                  startPreloader ();
                                  addChild (video);
