Operating System is Linux (OEL) 5.5.
After upgrading browser to FIrefox 10.0.5, Adobe download site recommended Flash-plugin 11.2.202.236. Installed on Linux using 'rpm'. Started browser and entered 'about:plugin" which listed the shockwave flash plugin. BUT, when URL to the Adobe test page entered, the flash 'movie' did not display anything .. just blank box. I've deinstalled and reinstalled, and searched numerous websites for help .. but nothing helpful. PLEASE, help!
what version of the rpm did you install? the binary must match firefox, meaning if your firefox is 32-bit, you'll need to install the 32-bit rpm. if your firefox is 64-bit, you'll need to install the 64-bit rpm.
assuming you installed the correct rpm, it may be that firefox doesn't know where to search for the libflashplayer.so binary
what you can do is symlink it from a location firefox does know where to look, usually ~/.mozilla/plugins
to do that lets go through these steps...
find out where the binary is installed (as root in a terminal window type): rpm -ql flash-plugin
in my 64-bit example the binary is installed here - /usr/lib64/flash-plugin/libflashplayer.so
lets symlink to it from you home mozilla directory (as yourself in a terminal window):
move to the folder (type in terminal): cd ~/.mozilla/plugins
Note: if the folder doesn't exist, create it and do the command above(as yourself in terminal type): mkdir ~/.mozilla/plugins
link the binary (as yourself in terminal type): ln -s /usr/lib64/flash-plugin/libflashplayer.so .
quit out of firefox and restart your browser
hope that helps...
Thank you very much for your reply.
These are the files I downloaded from adobe.com:
[swp@mysrvr ~]$ cd Desktop/
[swp@mysrvr Desktop]$ ll
total 24744
-rw-rw-r-- 1 swp swp 6897842 Jun 12 10:45 flash-plugin-11.2.202.236-release.i386.rpm
-rw-rw-r-- 1 swp swp 18360320 Jun 12 16:38 install_flash_player_11_linux.i386.tar
I first tried using 'rpm -Uvh flash-plugin-11.2.202.236-release.i386.rpm'
> this installed, then 'rpm -qa' did show the new version; but test page on adobe site didn't play.
I also tried untarring the 'install..tar' file, moved the .so file to home directory,
> but again, test page on adobe site didn't play.
So, going through your steps, first found 'firefox' binary:
swp@mysrvr plugins]$ which firefox
/usr/bin/firefox
[swp@mysrvr plugins]$ cd /usr/bin/
[swp@mysrvr bin]$ ll firefox
-rwxr-xr-x 1 root root 6540 Jun 5 23:33 firefox
Then, looked for the flash-plugin using your command:
[swp@mysrvr Desktop]$ su
Password:
[root@mysrvr Desktop]# rpm -ql flash-plugin
/usr/bin/flash-player-properties
/usr/lib/flash-plugin
/usr/lib/flash-plugin/LICENSE
/usr/lib/flash-plugin/README
/usr/lib/flash-plugin/homecleanup
/usr/lib/flash-plugin/libflashplayer.so
/usr/lib/flash-plugin/setup
/usr/lib/kde4/kcm_adobe_flash_player.so
/usr/share/applications/flash-player-properties.desktop
/usr/share/doc/flash-plugin-11.2.202.236
/usr/share/doc/flash-plugin-11.2.202.236/readme.txt
/usr/share/icons/hicolor/16x16/apps/flash-player-properties.png
/usr/share/icons/hicolor/22x22/apps/flash-player-properties.png
/usr/share/icons/hicolor/24x24/apps/flash-player-properties.png
/usr/share/icons/hicolor/32x32/apps/flash-player-properties.png
/usr/share/icons/hicolor/48x48/apps/flash-player-properties.png
/usr/share/kde4/services/kcm_adobe_flash_player.desktop
Then, created the sym-link using command you provided:
[swp@mysrvr Desktop]$ cd ../.mozilla/plugins/
[swp@mysrvr plugins]$ ll
[swp@mysrvr plugins]$ ln -s /usr/lib/flash-plugin/libflashplayer.so
lrwxrwxrwx 1 swp swp 39 Jun 13 17:24 libflashplayer.so -> /usr/lib/flash-plugin/libflashplayer.so
Closed, restarted Firefox, but once again, still no dispay on the adobe.com test page:
http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html
In firefox, access 'about:plugins' provides this confirmation the plugin is there:
Enabled plugins
Find more information about browser plugins at mozilla.org.
Find updates for installed plugins at mozilla.com/plugincheck.
Help for installing plugins is available from plugindoc.mozdev.org.
Shockwave Flash
File: nswrapper_32_32.libflashplayer.so
Version:
Shockwave Flash 11.2 r202
MIME Type Description Suffixes
application/x-shockwave-flash Shockwave Flash swf
application/futuresplash FutureSplash Player spl
NPAPI Plugins Wrapper 1.3.0
File: npwrapper.so
Version:
nspluginwrapper is a cross-platform NPAPI plugin viewer, in particular for linux/i386 plugins.
This beta software is available under the terms of the GNU General Public License.
unknown/mime-type Do not open none
Within Firefox, access 'Help | About Firefox' shows "Firefox ESR 10.0.5"
Hope this information helps you.
I will gladly let you look at this or give you any screen shots or files you need to help troubleshoot this.
thank you very much!
shane.//
also, if the firefox version was a default install, it may actually be 64-bit. so, you would have to install the x86_64 rpm rather. there is incompatibilities/conflict with the native 64-bit flash binary and nspluginwrapper, so it would be best to uninstall it. thanks...
As for your suggestion Firefox might be 64-bit, I am fairly certain this is 32-bit Linux (OEL 5.5) as seen here:
[root@mysrvr plugins]# uname -m
i686
[root@mysrvr plugins]# uname -an
Linux mysrvr.world 2.6.18-194.el5 #1 SMP Mon Mar 29 20:06:41 EDT 2010 i686 i686 i386 GNU/Linux
Notice it says i686, not i686_64 as seen in the firefox executable script:
MOZ_ARCH=$(uname -m)
case $MOZ_ARCH in
x86_64 | s390x | sparc64)
MOZ_LIB_DIR="/usr/lib64"
SECONDARY_LIB_DIR="/usr/lib"
MOZ_LIB_DIR="/usr/lib"
SECONDARY_LIB_DIR="/usr/lib64"
[swp@mysrvr usr]$ ls
bin etc games include kerberos lib libexec local sbin share src tmp X11R6
There is no /usr/lib64, just the /usr/lib .. doesn't that confirm this is 32-bit?
Is JAVA plugin a pre-requisite requirement for Flash-plugin?
Is Firefox 10.0.5 and Flash-plugin 11.2.202.236 compatible/certified?
Is there some utility/tool to assist troubleshooting this?
thank you.
you firefox is picking up something for the flash binary. so there may be more than 1 installed on your sytem and it's somehow confused.
There is no /usr/lib64, just the /usr/lib .. doesn't that confirm this is 32-bit? from your uname ocmmand it looks like it's NOT 64-bit
Is JAVA plugin a pre-requisite requirement for Flash-plugin? no, this is not required
Is Firefox 10.0.5 and Flash-plugin 11.2.202.236 compatible/certified? we do not run a certification on your distro, but it should have been tested on RHEL/openSuse/Ubuntu
Is there some utility/tool to assist troubleshooting this? no, there is no utility for troubleshooting this. installation instructions are available here: http://helpx.adobe.com/flash-player/release-note/readme-flash-player-l inux.html
lets completely uninstall the flash player...
1. (run as root): rpm -e flash-plugin
2. go to the version page to make sure nothing is picked up: http://www.adobe.com/software/flash/about/
3. download the flash player tarball: http://get.adobe.com/flashplayer/otherversions/
4. choose Linux (32-bit) > x.tar.gz
5. save it and unpack it
6. copy libflashplayer.so to your ~/.mozilla/plugins directory
7. restart firefox and go to the version page
Thank you for your repy;
> i did exactly as you suggested with only deviation the URL to the 'version page' which is:
> on that page, the Flash box is empty,
> when I enter 'about:plugins' I see this display:
| application/x-shockwave-flash | Shockwave Flash | swf |
| application/futuresplash | FutureSplash Player | spl |
| unknown/mime-type | Do not open | none |
ok, i had a chance to download Oracle Enterprise Linux 5 Update 8. i did a basic install and it came with firefox 3.6. i copied the libflashplayer.so file to ~/.mozilla/plugins and firefox did not load the plugin.
do you have selinux running?
well i saw the error and ran the recommended command, in terminal, to allow the loading of the binary:
chcon -t textrel_shlib_t '/home/labuser/.mozilla/plugins/libflashplayer.so'
change the path to your location and see if that helps...
i have entered an internal bug for the TEXTREL, but it may be difficult to resolve since our last supported shipping version is 11.2...
Thank you for the response.
(Sorry for delay in responding with feedback, was away for a bit)
I tried the command you suggested and got the following message returned:
$ chcon -t textrel_shlib_t '/home/oracle/.mozilla/plugins/libflashplayer.so'
chcon: can't apply partial context to unlabeled file /home/oracle/.mozilla/plugins/libflashplayer.so
fyi:
[oracle@mysrvr .mozilla]$ cd plugins/
[oracle@mysrvr plugins]$ ls -la
total 17040
drwxr-xr-x 2 oracle oracle 4096 Jun 19 14:45 .
drwxr-xr-x 5 oracle oracle 4096 May 31 2010 ..
-rw-rw-r-- 1 oracle oracle 17406436 Jun 19 14:45 libflashplayer.so
[oracle@mysrvr plugins]$ pwd
I ran the command as the user 'oracle'
You mentioned a Bug filed, is there any resolution possible?
Should I just try install a new version of Firefox from the Mozilla site?
(current version having problem is the "Firefox ESR 10.0.5"
thank you.
did you try running the command as root?
in terminal change to user root:
$ sudo root
it will prompt you for root password. enter the password and the promt should turn from $ to #
at that time try the command: chcon -t textrel_shlib_t '/home/oracle/.mozilla/plugins/libflashplayer.so'
also, the bug would only apply to the flash player binary. it does not have anything to do with firefox at all.
I too am experiencing these problems. I uninstalled the latest flash, then reinstalled version 10 something to fix this. I am running Windows Vista 64-bit, the latest Firefox beta as recommended, and the latest Yahoo messenger. The problem is, if I pull up IE which I need for cloud access for work, then it automatically installs the latest version for my pc, which is buggered, and I'm back to flash not displaying facebook or ad content across the web in Firefox and crashing when I exit Yahoo. I receive successful installation each time, but cannot access settings manager immediately after install.
The only helpful notice I receive is in yahoo messenger as it exits. I receive the message "flash.ocx no longer part of windows" as the crash error when exiting Yahoo messenger, then it wants me to go back and install it again. Facebook content never loads, and ads pull up blank windows I can't exit. It's very frustrating. Any suggestions other than keep rolling back?
Hello,
Thank you for suggestion to try command as 'root'.
See results:
[oracle@mysrvr plugins]$ su
Password:
[root@mysrvr plugins]# chcon -t textrel_shlib_t '/home/oracle/.mozilla/plugins/libflashplayer.so'
[root@mysrvr plugins]# whoami
root
Unfortunately, same results.
thank you.
I found through extensive Google searches that other users experience similar severe frustration and problems with the Flash-plugin 11.2.202.236. Others recommended to find and use the 'supported' 10.3 version, which I did and it works! So, I removed all traces of 11.2 and then disabled the Autoupdate in Firefox in order to keep the 10.3.
Closing this thread.
