How can I loop instead of hardcoding this info
Jun 17, 2012 8:28 PM
Hi all
I have the following code, how can I cfloop and dynamically output this info instead of having to have each meeting time? Thanks
<cfselect name="MEETINGTIME" width="90" label="Time"onchange="UsersGrid.dataProvider.editField(UsersGrid.sele ctedIndex, 'MEETINGTIME', MEETINGTIME.selectedItem.data);">
                        <option value="None">None</OPTION>
                            <option value="05:30 AM">05:30 AM</option>
                            <option value="06:00 AM">06:00 AM</option>
                            <option value="06:30 AM">06:30 AM</option>
                            <option value="07:00 AM">07:00 AM</option>
                            <option value="07:30 AM">07:30 AM</option>
                            <option value="08:00 AM">08:00 AM</option>
                            <option value="08:30 AM">08:30 AM</option>
                            <option value="09:00 AM">09:00 AM</option>
                            <option value="09:30 AM">09:30 AM</option>
                            <option value="10:00 AM">10:00 AM</option>
                            <option value="10:30 AM">10:30 AM</option>
                            <option value="11:00 AM">11:00 AM</option>
                            <option value="11:30 AM">11:30 AM</option>
                            <option value="12:00 AM">12:00 AM</option>
                            <option value="12:30 AM">12:30 AM</option>
                            <option value="01:00 AM">01:00 AM</option>
                            <option value="12:00 PM">12:00 PM</option>
                            <option value="12:30 PM">12:30 PM</option>
                            <option value="01:00 PM">01:00 PM</option>
                            <option value="01:30 PM">01:30 PM</option>
                            <option value="02:00 PM">02:00 PM</option>
                            <option value="02:30 PM">02:30 PM</option>
                            <option value="03:00 PM">03:00 PM</option>
                            <option value="03:30 PM">03:30 PM</option>
                            <option value="04:00 PM">04:00 PM</option>
                            <option value="04:30 PM">04:30 PM</option>
                            <option value="05:00 PM">05:00 PM</option>
                            <option value="05:30 PM">05:30 PM</option>
                            <option value="06:00 PM">06:00 PM</option>
                            <option value="06:30 PM">06:30 PM</option>
                            <option value="07:00 PM">07:00 PM</option>
                            <option value="07:30 PM">07:30 PM</option>
                            <option value="08:00 PM">08:00 PM</option>
                            <option value="08:30 PM">08:30 PM</option>
                            <option value="09:00 PM">09:00 PM</option>
                            <option value="09:30 PM">09:30 PM</option>
                            <option value="10:00 PM">10:00 PM</option>
                            <option value="10:30 PM">10:30 PM</option>
                            <option value="11:00 PM">11:00 PM</option>
                            <option value="11:30 PM">11:30 PM</option>
                          </cfselect>
    Jun 18, 2012 4:40 AM   in reply to goodychurro1
    Use cfloop condition = "YourDateTime lte #MaxDateTime#"
    inside your loop use DateAdd to increment YourDateTime and use TimeFormat to display it.
    Jun 25, 2012 5:17 AM   in reply to goodychurro1
    Did it work when you ran it?
    Jun 25, 2012 9:33 AM   in reply to goodychurro1
    That's probably because you have an infinite loop.   Also, you are setting your two variables to strings instead of datetime objects.  This might cause unexpected results.
    Jun 25, 2012 11:06 AM   in reply to goodychurro1
    goodychurro1 wrote:
    #timeFormat(dateAdd('n', 30, YourDateTime),'hh:mm:ss tt')#
    That does not change the value of the #YourDateTime# variable. So the loop just runs until it crashes because
    the value of #YourDateTime# is always less than 11:30PM.  You need to increment the value on each loop and assign the new value to #YourDateTime#.
            <cfloop ....>
                    <cfset YourDateTime = dateAdd('n', 30, YourDateTime)>
            </cfloop>
    Jun 25, 2012 4:21 PM   in reply to goodychurro1
    I get all the times in half hour intervals from 8 - 5.30 but in the wrong date!! {ts '1899-12-30 08:00:00'}
    It is not the wrong date.  Since you only specified a time (ie "07:30AM") the "date" portion defaults to 0 or 12/30/1899 .  If you needed a specific time and date, you must specify it when creating the variables. For example:
          <cfset YourDateTime = createDateTime(2012, 6, 25, 7, 30, 0)> ... or
          <cfset YourDateTime = parseDateTime("2012-06-25 07:30AM")>
    BUT .. in your case it does not make a difference because you are not using the date for anything. So just use timeFormat() to display the time only.
         ie     #timeFormat( yourVariableName,  'hh:mm:ss tt')#
