Hi all
I have the following code, how can I cfloop and dynamically output this info instead of having to have each meeting time? Thanks
<cfselect name="MEETINGTIME" width="90" label="Time"onchange="UsersGrid.dataProvider.editField(UsersGrid.sele ctedIndex, 'MEETINGTIME', MEETINGTIME.selectedItem.data);">
<option value="None">None</OPTION>
<option value="05:30 AM">05:30 AM</option>
<option value="06:00 AM">06:00 AM</option>
<option value="06:30 AM">06:30 AM</option>
<option value="07:00 AM">07:00 AM</option>
<option value="07:30 AM">07:30 AM</option>
<option value="08:00 AM">08:00 AM</option>
<option value="08:30 AM">08:30 AM</option>
<option value="09:00 AM">09:00 AM</option>
<option value="09:30 AM">09:30 AM</option>
<option value="10:00 AM">10:00 AM</option>
<option value="10:30 AM">10:30 AM</option>
<option value="11:00 AM">11:00 AM</option>
<option value="11:30 AM">11:30 AM</option>
<option value="12:00 AM">12:00 AM</option>
<option value="12:30 AM">12:30 AM</option>
<option value="01:00 AM">01:00 AM</option>
<option value="12:00 PM">12:00 PM</option>
<option value="12:30 PM">12:30 PM</option>
<option value="01:00 PM">01:00 PM</option>
<option value="01:30 PM">01:30 PM</option>
<option value="02:00 PM">02:00 PM</option>
<option value="02:30 PM">02:30 PM</option>
<option value="03:00 PM">03:00 PM</option>
<option value="03:30 PM">03:30 PM</option>
<option value="04:00 PM">04:00 PM</option>
<option value="04:30 PM">04:30 PM</option>
<option value="05:00 PM">05:00 PM</option>
<option value="05:30 PM">05:30 PM</option>
<option value="06:00 PM">06:00 PM</option>
<option value="06:30 PM">06:30 PM</option>
<option value="07:00 PM">07:00 PM</option>
<option value="07:30 PM">07:30 PM</option>
<option value="08:00 PM">08:00 PM</option>
<option value="08:30 PM">08:30 PM</option>
<option value="09:00 PM">09:00 PM</option>
<option value="09:30 PM">09:30 PM</option>
<option value="10:00 PM">10:00 PM</option>
<option value="10:30 PM">10:30 PM</option>
<option value="11:00 PM">11:00 PM</option>
<option value="11:30 PM">11:30 PM</option>
</cfselect>
goodychurro1 wrote:
#timeFormat(dateAdd('n', 30, YourDateTime),'hh:mm:ss tt')#
That does not change the value of the #YourDateTime# variable. So the loop just runs until it crashes because
the value of #YourDateTime# is always less than 11:30PM. You need to increment the value on each loop and assign the new value to #YourDateTime#.
<cfloop ....>
<cfset YourDateTime = dateAdd('n', 30, YourDateTime)>
</cfloop>
Hi Dan, thanks I tried this it is almost working, I get all the times in half hour intervals from 8 - 5.30 but in the wrong date!! {ts '1899-12-30 08:00:00'}
<cfset YourDateTime = "7:30AM">
<cfset MaxDateTime = "11:30PM">
<cfset startweek_dt = TimeFormat(YourDateTime, "hh:mm") >
<cfloop index="ii" from="1" to="20">
<cfset startweek_dt = DateAdd('n',30, startweek_dt)>
<cfoutput>#startweek_dt#</cfoutput><br>
</cfloop>
Thanks cfsearching, I don't understand where I use YourDateTime variable if it is inside the cfloop, I tried using the variable in the to and from parts of cfloop but I kept getting errors
<cfloop condition = "YourDateTime lte #MaxDateTime#" >
</cfloop>
It is not the wrong date. Since you only specified a time (ie "07:30AM") the "date" portion defaults to 0 or 12/30/1899 . If you needed a specific time and date, you must specify it when creating the variables. For example:
<cfset YourDateTime = createDateTime(2012, 6, 25, 7, 30, 0)> ... or
<cfset YourDateTime = parseDateTime("2012-06-25 07:30AM")>
BUT .. in your case it does not make a difference because you are not using the date for anything. So just use timeFormat() to display the time only.
ie #timeFormat( yourVariableName, 'hh:mm:ss tt')#
Thanks cfsearching, this code works great for outputting the times:
<cfset YourDateTime = "7:00AM">
<cfset startweek_dt = #timeFormat( YourDateTime, 'hh:mm tt')# >
<cfloop index="ii" from="1" to="23">
<cfoutput>#timeFormat( startweek_dt, 'hh:mm tt')#</cfoutput><br>
</cfloop>
This code works great for outputting them in a cfselect:
<option value="<cfoutput>#timeFormat( startweek_dt, 'hh:mm tt')#</cfoutput>"><cfoutput>#timeFormat( startweek_dt, 'hh:mm tt')#</cfoutput></option>
</cfloop>
