I updated from CS5 to CS6 using the Creative Cloud - on my Mac. Now my previously created custom workspaces aren't showing up. Yes, I tried copying them from the Library's Preferences folder into the CS6 preference folder, but they still don't show up. I don't see a way to import workspaces. I manually re-created my Photoshop workspace, but I don't want to have to do that with InDesign - I did too much work creating it in the first place. Help, please.
Thank you, Baljeet. When posting a question, I was prompted to provide a subject and Creative Cloud was the closest there was in the pull-down menu. Hopefully someone can help me with an answer - it's very frustrating. It should happen automatically, so it's doubling frustrating that it not only doesn't, but that there isn't an obvious way to import one's settings from the previous version. Thanks again for moving my question to the InDesign forum.
Thank you for your response, Peter. But I already did that and my workspace does not show up. That's why I asked if there was some way to import them. Some additional task to do after copying the .xml file into my CS6 preferences folder. Because my workspace simply is not showing up in the pull-down list of workspaces.
Thank you - excellent suggestion. I had it in the wrong place - the posting after yours, by Rob Day, with the screen shots showed me that we're on version 8?!? I thought that version would equate with... well, the suffix on CS, so I thought we were on version 6 since we're on CS6. The test workspace that I saved confirmed that I'm on version 8. Thanks for your help.
May I add that I just received CS6 Cloud and immediately setup a workspace in InDesign (after reading the blogs I decides to make fresh ones instead of bringing them over from CS5).
The problem I am having is that I cannot save it as a default. Everytime I open InDesign the Essentials workspace is active. Maybe I am creating it wrong? Can someone tell me how to create it correctly so that it sticks as a default?
Also note below the workspace is my custom workspace—not the Essentials as shown above the pallets. Should not the "Essentials" read "The Name Of Myworkspace?" since the pallets are my custom settings?
Any help would be appreciated.
Try trashing your prefs. See Replace Your Preferences
