This discussion is locked
Why is Adobe force installing their new Flash player when it's causing browsers to not play video?
Jun 24, 2012 1:41 PM
Why is Adobe force installing their new Flash player on billions of computers when it's causing so many web browsers to not play video?
I had installed the Flash Player 11.2.202.228 from 3/28/2012 and it was working fine, unlike some of the previous Flash players in several web browsers, so I chose NOT to install any of the new Flash players that came after that, all based on experience.
But last Friday, 6/22/2012, I got a new Adobe Flash Player installer message that came across my desktop for the new Flash Player v 11.3.300.262 and I chose NOT to install it for the reason I stated above... and now look at all the problems that this new Flash player has caused for so many people.
Now, I see from looking at my Add-ons manager in my Firefox browser, and in my Windows 7 Programs panel in the control panel that the stupid new Flash Player v 11.3.300.262 has been FORCE INSTALLED behind my back, even though I definately DID NOT install it and I deleted the installation panel when it came up on my desktop on Friday.
And now no videos or Flash content will play in my Firefox browser! Nice job Adobe!
What's the deal Adobe?... why are you forcing software on to our computers that distinctly was not installed by the user, and then it screws up our computers.
How do explain something like this?
Now I have to troubleshoot it and try to install my old Flash Player.
Why?
    Jun 24, 2012 2:07 PM   in reply to digiday
    By any chance, do you also happen to have RealPlayer installed on your machine?
    If so, the issue is this in a nutshell:
    Flash 11.3.x is a protected mode plugin (think sandboxing).
    RealPlayer has a browser plugin that captures video content by hooking the Flash plugin, but it's not a protected mode plugin.
    Flash is, justifiably, not going to run like that.
    The cause for this is not entirely Adobe's fault, for once, but is caused by a piece of software that can honestly be lived without (RealPlayer).
    Interestingly enough, the issue will persist if you create a new profile in Firefox (firefox.exe -p).
    Check the troubleshooting page for working with Protected Mode plugins here: http://forums.adobe.com/thread/1018071?tstart=0
    The too long, didn't read, make it work now answer for others that might stop in:
    Either disable RealPlayer's Browser Record plugin from within RealPlayer itself (preferred), or manually disable Protected Mode for Flash by editing the mms.cfg file in:
    Windows 32bit: %SystemRoot%\system32\macromed\flash
    Windows 64bit: %SystemRoot%syswow64\macromed\flash
    On versions newer than XP, you may need to elevate your text editor at launch (Start pearl, and in the search box, type the name of the editor, eg: notepad. While holding Control and Shift, press enter to request elevated permissions. Alternately, with that same search, right-click the program, choose Run as Administrator.) so that changes made to the text file can be saved.
    Disabling Protected Mode in this manner is achieved by adding this line to the document:
    ProtectedMode=0
    Once you have done this and saved, then restart Firefox (or its derivatives), Protected Mode is disabled.
    Hope this helps you out.
    Jun 24, 2012 2:48 PM   in reply to digiday
    Well its not FORCE installing anything, you select the option when you install the program... so thats entirely on you, if you want it to auto update, or ask you before updating.
    Yea, im pissed they didnt catch these problems, cause im having a few myself... but dont start throwing out rather ignorant accusations and statements, when its really YOUR doing(not fault.)
    Jun 25, 2012 2:08 PM   in reply to digiday
    Says the person kicking and screaming on a forum, regarding troubleshoot.
    Cute come back though, kid.
  • Chris Campbell
    May 4, 2010
    Jun 25, 2012 2:44 PM   in reply to Mockingcrow
    Build 11.3.300.262 is a hotfix that should fix stability problems with Firefox.  Digiday, if you are having problems with it can you create a new thread and give us a description of the problems and steps to reproduce?
    While not recommended, you can also disable the auto silent update mechanism via the Flash Player control panel (How does the automatic update feature in Flash Player 11.2 work on Windows?).
  • Chris Campbell
    May 4, 2010
    Jun 25, 2012 3:17 PM   in reply to digiday
    digiday - 11.2 includes the silent auto updater, so it's expected that you would be updated within 24 hours once an update is made available (regardless of the version number).
  • Chris Campbell
    May 4, 2010
    Jun 25, 2012 4:14 PM   in reply to digiday
    Have her click Classic View on the left side of the control panel window, that should display all of the icons and allow her to see the Flash Player icon.  The alternative is to type "flash player" in the control panel search field which should also find it.
    Also note that changing auto update to "notify me to install updates" will only delay the process by 30 days.  After 30 days, the update will be installed automatically.  You can totally disable this by changing it to "never check" but I would definitely recommend against this.
    Jun 25, 2012 5:06 PM   in reply to digiday
    CRash.. crash.. stutter, stutter, stutter, crash, stutter, stutter.CRASH
    Jun 28, 2012 5:03 PM   in reply to digiday
    [ abuse removed by admin ] What are you expecting? I was right, you didnt have it set to "not auto update." The man JUST said that if you have it set to notify you, it will still auto install AFTER 30 days, regardless, OR you could have it set to NEVER install auto updates, regardless. Guess what nimrod, it hasnt been 30 days since this new versions release, meaning it didnt FORCE install. You had it set to auto update.
    Auto update, is the first option, it will install within 24 hours without notifying you that it did anything, HENCE THE PHRASE "SILENT." Its no different than the thousands of other auto updaters in the world, and plenty of people have their pros and cons about them, from taking up memory, to "beta testing" poorly coded patches, or flat out ignorance of "forced install!"
    Read chris' posts again and learn how to use a computer beyond pressing buttons on your keyboard.
    Jun 25, 2012 7:10 PM   in reply to fixthisstutterplayer11
    This topic does no longer serve any purpose.
    [topic closed]
