Hi all,
In the last section of the code I am testing to see if meetingdate is a holiday, what is the correct way to do it , am I on the right track? Thanks
<!--- QUERY TO GET HOLIDAY DATES --->
<CFQUERY name="hols" datasource="salesdb">
SELECT holiday, holidayid FROM holidays
</CFQUERY>
<!--- SET MEETINGDATE ACCORDING TO DAY OF THE WEEK --->
<cfset meetingDate = trim(form.meeting)>
<cfif not isDate(meetingDate)>
<cfif DayOfWeek(Now()) eq 2>
<cfset meetingDate = dateAdd("d", 2, now())>
<cfelseif DayOfWeek(Now()) eq 3>
<cfelseif DayOfWeek(Now()) eq 4>
</cfif>
</cfif>
<!--- NOW CHECK IF NEW MEETINGDATE IS A HOLIDAY AND ADD DAYS--->
<cfif meetingDate = hols.holiday >
<cfif meetingDate eq 2>
<cfset meetingDate = dateAdd("d", 3, now())>
<cfelseif meetingDate eq 3>
<cfelseif meetingDate eq 4>
</cfif>
worked it out, thanks for the help guys
SELECT * FROM holidays
</CFQUERY>
<cfset meetingDate = '2012-07-20'>
<cfoutput>#meetingDate#<br>
#DayOfWeek(meetingDate)#</cfoutput>
<cfif ListFind(ValueList(hols.holiday), meetingDate)>
<cfif DayOfWeek(meetingDate) eq 2>
<cfset meetingDate = dateAdd("d", 2, meetingDate)>
<cfelseif DayOfWeek(meetingDate) eq 3>
<cfset meetingDate = dateAdd("d", 5, meetingDate)>
<cfelseif DayOfWeek(meetingDate) eq 4>
You appear to be missing a function call in the bottom part of your code. It also appears to be incomplete. You don't have anything for Thursday and Friday.
Hi Dan
I got rid of Thursday , Friday , Saturday and Sunday to make the code easier to read. What function call am I missing?
If you want the code to be easier to read, consider using switch/case instead of if/else if/else.
Hi I'm going back to basics on this one, using a date that I know is in the hols query, then using listfind to see if it appears. I run the following code which should add 5 days to the meetingDate date as the 25th of December 2012 is a tuesday but it doesn't. Why not? Thanks
</CFQUERY>
<cfset meetingDate = '2012-12-25'>
<cfset meetingDate = dateAdd("d", 5, now())>
<cfelseif meetingDate eq 5>
<cfset meetingDate = dateAdd("d", 4, now())>
<cfelseif meetingDate eq 6>
<cfelseif meetingDate eq 7>
<cfelseif meetingDate eq 1>
<cfset meetingDate = dateAdd("d", 1, now())>
</cfif>
</cfif>
<cfdump var="#hols#">
<cfoutput>#meetingDate#</cfoutput>
Why not?
You are checking to see if '2012-12-25' is 2, 3, 4, 5, 6, 7, or 1, Which one did you expect to return true?
I expected this one to return true as 2012-12-25 is a tuesday:
Ah sorry I forgot to check for day of the week! I'll try with this code and see!
</CFQUERY>
<cfelseif DayOfWeek(meetingDate) eq 5>
<cfset meetingDate = dateAdd("d", 4, meetingDate)>
<cfelseif DayOfWeek(meetingDate) eq 6>
<cfset meetingDate = dateAdd("d", 3, meetingDate)>
<cfelseif DayOfWeek(meetingDate) eq 7>
<cfelseif DayOfWeek(meetingDate) eq 1>
<cfset meetingDate = dateAdd("d", 1, meetingDate)>
</cfif>
</cfif>
<cfoutput> #meetingdate# <br>
