Have any of you guys had any luck using the Provisioning Tool to unserialize a CS6-installation?
If so - what was the command line you used?
We've tested various commands but none of them have been succesful.
Some gives the return code 1 and a single one gives the return code 0.
The one giving the return code 0 should work, but sadly it doesn't actually unserialize.
Our CS6-package is made using AAMEE and packed as a serialized install.
After the install we plan on unserializing the install, but have no luck doing so.
The reason for this procedure is bad experiences trying to serialize a trial install of CS5.5.
Kenneth
please confirm if you are using this commandline - "adobe_prtk --tool=UnSerialize --leid=Photoshop-CS6-Mac-GM [ --locale=en_US ]" to unserialize the CS6 product. use LEID of suite/product which you have used to create the AAMEE package.
please refer to these document for detailed information on PRTK usage for managing licenses.
http://www.adobe.com/devnet/creativesuite/enterprisedeployment/licensi ng-identifiers.html
if you still see an issue, please send across amt3.log and oobelib.log
It should be located at
/tmp/oobelib.log on OSX
and
%TEMP%\oobelib.log on Windows.
thanks,
Rahul | rbaiswar@adobe.com | Adobe Systems
First of all some basics about our procedure.
We deploy a serialized version of Master Collection packaged using AAMEE3.0.
Once successfully installed we run this command:
adobe_prtk --tool=UnSerialize --leid=MasterCollection-CS6-Win-GM
to unserialize Master Collection. This gives the return code 0 and leaves us with a trial version.
We then want to serialize to eg. Design & Web Premium - using the Provisioning Tool - and the Master Collection CS6 Install using this command:
adobe_prtk --tool=Serialize --leid=DesignWebSuitePremium-CS6-Win-GM --serial=xxxx-xxxx-xxxx-xxxx-xxxx-xxxx --adobeid=xxx@xxx.com
This gives the return code 0.
If we then use the Provisioning Tool to unserialize Design & Web Premium using this command:
adobe_prtk --tool=UnSerialize --leid=DesignWebSuitePremium-CS6-Win-GM
this gives the return code 6.
According to the oobelib.log this should be due to the LEID not being valid.
I don't have a clean oobelig.log and amt3.log at the moment, but could prepare one if you want to take a look at it.
Is it no longer possible to serialize to a different package using the Master Collection-install?
This procedure worked in CS5.5 where we use it today.
