Tony_Ry
FlexPMD 1.2 and Eclipse Plug-In
Oct 20, 2010 8:24 AM
Hi, I'm probably missing something simple here but Flex PMD (using the eclipse plugin) isn't working for me: Nothing gets populated in either the Flex PMD view or the CPD view but the views do open when I run Flex PMD.
My configuration is:
FlexPMD command line installation: C:\Software\FlexPmdAll\flex-pmd-command-line-1.2.jar
FlexPMD custom ruleset: C:\Software\FlexPmdAll\pmd.xml
Java command line: java -Xms512m -Xmx512m
FlexCPD command line installation: C:\Software\FlexPmdAll\flex-pmd-cpd-command-line-1.2.jar
There are no spaces in my workspace path, it is simply: C:\Views\ProjectNameHere\
Using these settings I get a pop-up error message saying: 'add markers job' has encountered a problem.
Expanding on this error gives me: An internal error occurred during: "add markers job". Index: 0, Size: 0
If I change the Java command line (a tip found on the web) to: java -Xms512m -Xmx512m -Djava.io.tmpdir=C:\Users\NameGoesHere\AppData\Local\Temp
I get the same error.
If I remove the custom ruleset value no error message shows when I run Flex PMD but nothing happens either.
If you have any idea what's wrong let me know. The open source website is offline and I can't find any reference sites that don't link to it for an answer.
Cheers,
Tony
    Oct 20, 2010 8:28 AM   in reply to Tony_Ry
    Hi Tony,
    we're planning a new release of the plugin really soon. could you give a try to install a newer temp version from this update site? http://www.rialvalue.com/flexPmd/updateSite/ and let me know if the problem still persist?
    this update site comes with FlexPMD 1.1 bundled but from the preferences you'll be able to point to whatever version you have locally
    please let me know if the problems persist
    Oct 20, 2010 9:04 AM   in reply to Tony_Ry
    mmm it sounds like it's messing around with your old preferences... Could you open the preferenes panel for FlexPmd, make a dummy change and save them just to override any wrong value?
    Xavi
    Oct 20, 2010 9:12 AM   in reply to Tony_Ry
    Can you open the "Error Log" view on eclipse and see if there's any message there from FlexPMD? I guess that the popup error you see is truncated...
    Xavi
    Oct 20, 2010 2:11 PM   in reply to Tony_Ry
    what OS are you in? do you have admin rights?
    Sep 18, 2011 1:52 PM   in reply to Tony_Ry
    I had a similar problem. I resolved it by installing the update into FB 4.5. However, while I get a PMD view, I do not get any CPD view. I am on Mac OSX
    Sep 22, 2011 7:46 AM   in reply to Cancerinform
    I have encountered this same problem. I am on Win7, have admin privs, am running Flash Builder 4.
    Is there any way to fix this without updating to Flash Builder 4.5?
    Oct 15, 2011 4:43 PM   in reply to Tony_Ry
    I've just gotten the "add markers job" error when trying to analyze various individual files in my project, but I don't get it when I analyze the whole folder.
    Based on this, plus some details about the classes themselves, I have a hunch that maybe the error is happening when there aren't any errors to report.
    Thoughts?
    I'm using FDT on a Mac running 10.6
    Nov 4, 2011 9:49 AM   in reply to xyroclast
    Based on the last two posts here : http://forums.adobe.com/message/3872559#3872559 the problem might spaces in the workspace path. The default is something like 'c:\Documents and Settings...' so it may well be http://bugs.adobe.com/jira/browse/FLEXPMD-127
    I don't get any output, or any errors, Builder 4.5, Flex 4.1 SDK, Windows XP.
    Hopefully the next release will fix all this, because it's a really common use case that really should Just Work.
    Jun 25, 2012 10:54 PM   in reply to Tony_Ry
    Did you ever get FlexPMD running? I'm getting the exact same error that you got -
    26.06.12 07:50:50,755 [0x0-0x175b75a].org.eclipse.eclipse: !MESSAGE Error running
    FlexPMD/var/folders/l2/q0y9p12d1419gczk1j_gtbdc0000gn/T/flexpmd6167148 067338996286dir/pmd.xml (No such file or directory)
    This is with OS X, Flash Builder 4.6 and the FlexPMD 1.2 from the link in the start of the thread.
    Jun 25, 2012 11:14 PM   in reply to casper_no
    Finally got it to work, seems like there was some problem with preferences after I updated from 1.0 to 1.1. The solution was to "restore defaults" from FlexPMDs preference panel.
    Jun 26, 2012 6:49 AM   in reply to casper_no
    The only issue which i found was Flex PMD is not compatible with java version 7.
    Uninstall the java 7 and try with java 6 it works...
Bookmarked By (1)
