MichaelFaulkner
CS6 Update Failure - Error U43M1D204 (new content added to question)
Jun 23, 2012 9:53 AM
Tags: #update_failure
Web and Design Premium install.  I get this error when running an Adobe Application Manager update in any of the products.  Per one tech note  found, I deleted the local profile folder for the logged on admin user where the updates are downloaded and then applied (AAMUpdater).  Same issue.  The logs in that folder don't shed any light on the problem that I can see.
Addition:  This is a network command line install from a package. The first package was incorrectly configured so that updates could not be applied by an administrator logon.  Repacked with the correct setting, uninstalled on the workstation, and reinstalled via the new network package to discover this issue.
QUESTION:  Is their a tech note on a manual uninstall of CS6 suite in case the control panel uninstall did not remove everything and the product is in some sort of inconsistent state regarding update patches?
Message was edited by: MichaelFaulkner
    Jun 25, 2012 6:49 PM   in reply to MichaelFaulkner
    Hi Micheak ,
    I believe now is your problem solved.
