Hi to everyone, i'm working in a flash proyect using this action for each button/city (it's a map).
btn_monteria.addEventListener(MouseEvent.CLICK, montpress)
function montpress(Event:MouseEvent){
//Crear una variable cargador para mostar el swf
newMedia = new Loader;
//Crear una variable para un clip vacio (anteriormente host)
cont = new Sprite;
//ruta para cargar la pelicula
newMedia.load(new URLRequest("mapa_monteria.swf"));
//mostar el boton cerrar
btn_cerrar.visible = true;
//Posicion x que va a tener el host
cont.x = 10;
cont.y = 120;
stage.addChild(cont);
stage.addChild(btn_cerrar);
cont.addChild(newMedia);
and in the top of the actions have this code to load the swf
stop();
btn_cerrar.visible = false;
//Listener para cada una de las variables
//Creacion de la variable cargador
var newMedia:Loader;
var cont:Sprite;
//Listener y funciones para boton cerrar, asi como la visibilidad
btn_cerrar.addEventListener(MouseEvent.CLICK, cerrar)
function cerrar(Event:MouseEvent){
cont.removeChild(newMedia);
newMedia.unload();
newMedia = null;
As you can see works fine, but there is a little problem, if you press one city and then other city (with out pressing the close button) it doesn't hide the first city.
It is a way for each time that press a button the other ones keep hiding????
You can see it here
Thanks ...
cerrar();
newMedia = new Loader();
cont = new Sprite();
cont.x = 10;
cont.y = 120;
stop();
var cont:Sprite;
function cerrar(event:MouseEvent = null){
if (cont.contains(newMedia))
if (newMedia != null)
newMedia.unload();
newMedia = null;
Thanks for your reply .... it's not working .... here is the full code. Please tell me if i send you the .fla
import flash.events.MouseEvent;
import flash.display.Loader;
import flash.display.Sprite;
import flash.net.URLRequest;
stop();
var cont:Sprite;
newMedia.unload();
newMedia = null;
//Boton Monteria
cont = new Sprite;
cont.x = 10;
cont.y = 120;
//Boton Cucuta
btn_cucuta.addEventListener(MouseEvent.CLICK, cucpress)
function cucpress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_cucuta.swf"));
cont.x = 10;
cont.y = 120;
//Boton Santa Marta
btn_sta.addEventListener(MouseEvent.CLICK, stapress)
function stapress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_sta.swf"));
cont.x = 10;
cont.y = 120;
//Boton Villavicencio
btn_vll.addEventListener(MouseEvent.CLICK, villpress)
function villpress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_villavicencio.swf"));
btn_cerrar.visible=true;
cont.x = 10;
cont.y = 120;
//Boton Cartagena
btn_ctg.addEventListener(MouseEvent.CLICK, ctgpress)
function ctgpress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_cartagena.swf"));
cont.x = 10;
cont.y = 120;
//Boton Bogota
btn_bogota.addEventListener(MouseEvent.CLICK, bogpress)
function bogpress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_bogota.swf"));
cont.x = 10;
cont.y = 120;
//Boton Cali
btn_cali.addEventListener(MouseEvent.CLICK, calipress)
function calipress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_cali.swf"));
cont.x = 10;
cont.y = 120;
//Boton Barranquilla
btn_bll.addEventListener(MouseEvent.CLICK, bllpress)
function bllpress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_barranquilla.swf"));
cont.x = 10;
cont.y = 120;
//Boton Medellin
btn_mdll.addEventListener(MouseEvent.CLICK, mllpress)
function mllpress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_medellin.swf"));
cont.x = 10;
cont.y = 120;
//Boton Dosquebradas
btn_dq.addEventListener(MouseEvent.CLICK, dqpress)
function dqpress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_dosquebradas.swf"));
cont.x = 10;
cont.y = 120;
//Boton Ibague
btn_ibague.addEventListener(MouseEvent.CLICK, ibgpress)
function ibgpress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_ibague.swf"));
cont.x = 10;
cont.y = 120;
//Boton Tunja
btn_tunja.addEventListener(MouseEvent.CLICK, tunjapress)
function tunjapress(Event:MouseEvent){
cont = new Sprite;
newMedia.load(new URLRequest("mapa_tunja.swf"));
cont.x = 10;
cont.y = 120;
Hi ... i was busy for a long time, so that's why i can't uset it ...
this is the function cerrar:
newMedia.unload();
newMedia = null;
But how do i call it from each button??? ...
Thanks a lot .... you can seet here how its working
