Migrated to FB 4.6 and ant build fails
Jun 26, 2012 8:30 AM
Tags: #problem #flash_builder #build #compile #4.6
We are trying to migrate to Flash Builder 4.6. Code compiles ok with eclipse but fails to compile with ant.
Keep getting the following error:
[compc] Error: could not find source for class mx.core:ScrollControlBase in namespace http://www.adobe.com/2006/mxml.
We are not using the ScrollControlBase class in the code so not sure why it fails on that.
The compc task s pretty straight forward and looks like this:
<compc
            output="${temp}/test.swc"
            fork="true" incremental="true"
            include-classes="${xml.includeClasses.classEntry.path}"
            target-player="13"
            <namespace uri="http://www.adobe.com/2006/mxml" manifest="${FLEX_HOME}/frameworks/mxml-manifest.xml"/>
            <include-namespaces uri="http://www.adobe.com/2006/mxml"/>
            <namespace uri="library://ns.adobe.com/flex/mx" manifest="${FLEX_HOME}/frameworks/mx-manifest.xml"/>
            <include-namespaces uri=">library://ns.adobe.com/flex/mx"/>
            <load-config filename="${build.flex-config}"/>
            <theme dir="${FLEX_HOME}/frameworks/themes/Halo">
              <include name="halo.swc" />
            </theme>
            <jvmarg value="-Xmx512M"/>
            <jvmarg value="-Xms256M"/>
            <source-path path-element="${FLEX_HOME}/frameworks/themes" />
            <external-library-path dir="${FLEX_HOME}/frameworks/libs/player/13.0">
                <include name="*.swc"/>
            </external-library-path>
            <external-library-path dir="${FLEX_HOME}/frameworks/libs">
            <external-library-path dir="${FLEX_HOME}/frameworks/libs/mx">
            <external-library-path dir="${FLEX_HOME}/frameworks/locale/en_US">
          </compc>
Please advise.
