David Patterson
Dragging "New Window" around tries to automatically combine with original window
Jun 25, 2012 9:28 AM
Tags: #dreamweaver #windows #multiple #cs6
I frequently need to have two separate design windows open and as I don't have a huge screen need to move the windows around.  However, since upgrading to CS6, as I drag the window around it keeps trying to automatically relink back into the original window.
It never did this in CS5.5, I cannot find anywhere to turn this 'feature' off and it is driving me up the wall.  Perhaps I will have to revert back to using CS 5.5 whilst performing this long exercise!
    Jun 25, 2012 10:40 AM   in reply to David Patterson
    Have you tried using the "tile" style windows? go to Window >> Tile. I find it much easier work in the mode rather than dragging the windows around, and I know the the tabs can be a pain
    Julia
    Jun 25, 2012 11:08 AM   in reply to David Patterson
    Does CS6 have that annoying "Enable Floating Document Window Docking" in DW?
    It sounds like the same thing I've been turning off in PS and ID under Preferences > Interface in those programs (I don't have CS6).
    Jun 25, 2012 11:22 AM   in reply to Jon Fritz II
    From what I've researched, I cannot find a way to turn it off. You can request a feature using this form:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform&product=1 2
    Let me know if there is anything else I can help you with!
    Julia
    Jun 25, 2012 3:59 PM   in reply to David Patterson
    I don't have a 30 inch display either and I find closing panels & tab groups helps a lot.
    To toggle the Properties panel on/off, use Ctrl+F3.
    To show Files panel, hit F8.
    To expand Results panel, hit F7.
    Nancy O.
