Another Dual Layer Break Issue
Jun 26, 2012 8:12 AM
Encore CS5.1
After about 12 hours, I am no further forward... Having trawled through a number of posts on this and similar subjects I am really up against the buffers.
The requirement is simple - getting Abobe Encore CS5.1 to "see" my request to use a Chapter Marker it gives me as one of three in the Manual Option section during the build process.
I had no issues with DL authoring in CS4, but CS5 is giving me a lot of grief.
The outline:
I have a timeline of 67 minutes with 6 Chapter Markers. The first two are within the first 10 minutes, CH3 at 36 minutes, CH4 at 38 minutes, CH5 at 41 minutes and CH6 at 61 minutes.
I am using Verbatum DL +R DVDs (I have used no other these last three years) with a write speed of x4 or x2.4.
Once I have built the NEW project, imported the video and placed the Chapters as above (all except CH3 at fade-to-black points) I select 8.54 GB dual layer, Side one, Manual and proceed.
At the invitation to select the manual point Encore offers me CH3, CH4 and CH5. No matter what I select, it places the break point at about 33 minutes (about half way) and in doing so screws up my own Chapters by placing it's own (invisible in the timeline) chapter thereby shuffling all mine. As a result I lose sections or get repeated sections.
I tried building to Folders and using ImgBurn. This confirms the insistance on using a halfway point - same too building to an Image the chapter and cell are never my selected, always a cell at about the halway point.
Adobe Encore is not recognising my selection (at its own invitation).
I have deleted the project and cache - rebooted and built the project from scratch importing the video - creating the timeline and adding the Chapters - always the same.
I have followed some of the points given using Folders in ImgBurn - it simply is not working for me. It's almost like Encore is screwing the build and the build is the same as though the settings are held in cache.
As mentioned, I have cleared all previous builds and their files and deleted the media cache with no joy.
I'm getting to the point whereby the only choice left to me is to split the project timeline and build the project as two separate DVDs (as the timeline is only just over the capacity for a single sided DVD (3 minutes).
As for PCG Edit - doesn't seem to want to run on my workstation (PC i7 24GB RAM - 3 separate drives in RAID combo and separate OS SSD).
Can someone help me find out what has happened to Encore as it does appear that after every "upgrade" somthing gets a little worse judging by my CS4 experience.
Many Thanks
    Jun 26, 2012 9:07 AM   in reply to Drystonewall
    One reason Encore creates a new chapter (and the only reason I can think of that img burn would choke) is that there is simply too much material for a layer, no matter how you split the layers using your chapters.
    I don't see how that can be with material that barely warrants dual layer, but what else can it be.
    If that is the case and there is really no other place for a "silent" chapter (that you add, and can therefore plan for in your chapter selections - or nonselection in this case), you might reduce the datarate so that 2 chapters can now fit on one layer.
    You don't say, but you are running "as administrator," right?
    Jun 26, 2012 12:15 PM   in reply to Drystonewall
    I'm partly guessing, but one explanation offered here for the layer break issues is that Encore must split them so that neither side is over half. Sounds kinda obvious when I say it that way.
    The situation that always made sense to me is a single timeline with no chapters. There's no place to break it, so Encore adds a chapter. So split the DVD in to 3 sections. If you can add either 1 + 2 or 2 + 3 is more than one layer, Encore may think ahead of time that it can offer you the only breaks it sees, but in the end, it has no options.
    Imgburn should be able to do this, except it would have the same problem.
    I would look for an edit about midway through the middle timeline to add a fade and marker.
    Jun 26, 2012 1:48 PM   in reply to Drystonewall
    Yes, Encore has its issues. The move to 64 bit in CS6 is hopefully a sign of things to come. We shall see...
    Jun 27, 2012 2:16 PM   in reply to Stan Jones
    For all the dual layer discs I produce I make a single layer custom folder the same size as a dual layer disc, 8.4GB. This forces Encore not to add an extra chapter point or add any layer break. I then use Imgburn to produce the ISO file.
    Richard Knight
