M2T files play perfectly from start to finish with Windows Media.
BUT when I import the M2T file into CS5.5 it leaves off about 5 minutes of audio but video is perfect. Why won't CS5.5 import the complete file including audio?
Any work around appreciated.
Unfortunately, I couldn't find anything that stands out as the source of this error.
But I do like that someone is finally making a solid state recorder that can use the superior NTFS formatting for the cards. Personally, I think ALL solid state recorders, including cameras, should be using NTFS.
Please Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
http://forums.adobe.com/thread/592070?tstart=30
For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
Does this happen with ALL of the MTS files from that recorder, or just some of them?
With truncated audio, the first thing that comes to my mind is that the Conforming process was not able to complete, but this would probably only affect some, but certainly not all, such files. Just for some background, see this ARTICLE on Conforming and Indexing files.
When you look at the Waveform Display, does that go "flat-line," when the Audio signal ceases, or does it continue to show up properly?
While a player accesses the source file, for both Audio and Video, PrPro accesses the CFA files for Audio, and the PEK files for Waveform Display.
Good luck,
Hunt
PS - someone asked about NTFS formatting. If you have your HDD formatted to FAT-32, then you also might be reaching the ~ 4GB file size limit. Something else to check.
Sorry for the late reply. I have a few M2T files that have dropped audio near the end in CS5.5. BUT the M2T file Does play in Windows Media including all audio.
The small program MediaInfo states that the audio track is 384 KBPS,48.0 KHz,2 channels,MPEG Audio (Version 1) (Layer 2).
I have tried breaking out to acc and wav but the audio is missing the section at the end.
I'm stumped.
PS This is recorded from my XH-A1 and firewire to CF card and a DN-60. I have three DN-60's and they all drop at the end MOST of the time.
UPDATE - I used my USB3 card reader to move the files from my CF Card. I have also found many more m2t files that drop off the last few minutes BUT as mentioned
above all these m2t files will play in Windows Media perfectly.
Still stumped! Any solution?
I guess no one has a solution to why the last few minutes of an m2t file, recorded to a DN-60 has audio drop off when imported into Premiere CS 5.5. A drop off that Strangely doesn't occur when played with Windows Media.
Message was edited by: ferdinandNGC
