The Mac CS6 "Serious Error" thread
Jun 3, 2012 9:12 AM
  Latest reply: briantho, Apr 14, 2013 12:40 AM
Branched to a new discussion.
Replies 1 2 3 4 5 6 ... 14 Previous Next
    Jun 25, 2012 8:50 PM   in reply to needles27
    Hmm, except my machine is already running on Software Only, I don't have a CUDA card.
    Jun 26, 2012 2:23 AM   in reply to EditorPete
    I've been getting loads of serious error crashes too. A lot of the problems for me seem to be media cache related, see the following thread for more info and system specs...
    http://forums.adobe.com/message/4510419
    Interstingly I too have the audio issues reported, my sound icon in the menu bar works inconsistently now so I took the Mac Pro to the apple store and it booted fine from the network system so there's definately some consistency there. I usually run an Apogee Duet for audio, not sure if anybody else does the same.
    I really think Adobe needs to broaden there beta test group to include a lot more mac users, for months before the release of CS6 people were releasing how to videos and blogging about new features but you do have to wonder why these issues were not dealt with when it seems pretty wide spread with mac users on the forums.
    I'd be more than willing to help beta test if needed, although it actually feels like that's what's happening already!
    Paul
    Mac Pro 5,1 12 x 2.93Ghz, 48GB Ram, 2 x 512 SSD, 2 x 2TB HD
    Nvidia Quadro 4000 (Hardware ME enabled)
    Latest OSX, Cuda and Nvidia drivers installed
    Jun 26, 2012 7:36 AM   in reply to genefama
    Back at post 111 genefama says a solution to the mutred audio problem has been found....Please share the answer, as what little hair I have left is falling out trying to figure this out.
    I have not had consistent serious errors (just 1 so far), but PP certainly seems not ready for prime time on my Mac Pro yet, ...love CS6, just wish PPro could be STABLE, it has plenty of features already, don't need more, just stability and smooth operation!! As always YMMV
    Jun 26, 2012 7:48 AM   in reply to Paul Joy (UK)
    I've concluded that GPU processing is simply not functional on Macs particularly with the AMD 6750 processor.  I am on a 2.2 i7 macbook pro and have found that turning on the GPU in project settings not only causes instability for PP and AME but also for other apps running at the same time.
    For example, just this morning we setup an export with GPU turned on and it reported 2 hrs to export.  During export, CPU utilization was very low and other apps were lagging.  We turned GPU off and the export time dropped to 20 mins, CPUs are maxed and other apps respond normally.
    Previously, turning on GPU processing caused repeated kernel panics.  That appears to have been resolved apparently by a recent OSX update.  Hard to believe that support for Macbook pros with the 6750 was actually a touted feature of this release.
    We have high hopes for 6.1.
    Jeff
    Jun 26, 2012 7:57 AM   in reply to Jeff_H
    I too have been getting stability back from having MPE turned off and using CPU for rendering and playback...still playback lags in both preview and progam monitors at times.
    Pete
    Jun 26, 2012 8:18 AM   in reply to geonew1952
    I tried everything to fix the muted audio.  This is what worked, though the last time I tried it the gray icon stuck around.  In general it works though.
    You have to run the script every time you restart your computer.  Save it to your dock for easy access.
    1. Go to Applications and open Utilities.
    2. Open Applescript Editor.
    3. Copy the following and paste it at the top half of the editor (copy everything below with the quotes in place):
    do shell script "launchctl stop com.apple.audio.coreaudiod" password "your_password" with administrator privileges
    4. Replace "your_password" with your login password. For example, if your login password is ILOVEMYSON2012 then it should look like this:
    do shell script "launchctl stop com.apple.audio.coreaudiod" password "ILOVEMYSON2012" with administrator privileges
    5. Now go to File > Save As (in the Applescript Editor menu bar).
    After "Save As" choose a name for the file. I called mine "AudioFix."
    Under "File Format" choose "Application."
    Save it to your Applications folder or wherever you like, and drag it to your dock.
    Run it whenever you restart your computer. You could even put it in the list of programs that open on start-up.
    If your problem is the same as mine, the volume indicator will pop on within a few seconds to half a minute after you run the script.
    Good luck!
    Gene
    Jun 26, 2012 8:20 AM   in reply to Jeff_H
    Hmmm..... guys, I was about to buy a refurb 17" MacBook Pro with the 6770 GPU while there's still some around (I need to do some more editing in the field).
    Are you telling me that CS6 is simply not stable even on this platform, the one that Adobe have been touting as the newly supported system?   Surely this is the one they've done the most testing on too....
    What to do..... what to do.....
    Jun 26, 2012 8:27 AM   in reply to ExactImage
    Based on what I've read, the Windows platform appears to be stable, just not the Mac. This is really surprising given that I'm sure there are a lot of Mac users out there using PPro.
    I'm sure Adobe will fix it...I really hope a fix is coming forward very, very soon.
    Jun 26, 2012 8:33 AM   in reply to genefama
    @genefama (Is there no way to quote a previous post???): I wasn't aware there was a script that could be run. I actually complained to Apple a month or so ago because of this problem. They ended up replacing my motherboard as they couldn't fix the issue. It would work when they loaded in a fresh OS (off an external drive) so they thought it was a software issue but after reloading the OS, then flattening the drive and starting from scratch, the problem still came back. Since having the motherboard replaced (which took some time for me to get everything back to how it was), I haven't had any issues.
    Thanks.
    Jun 26, 2012 8:34 AM   in reply to Kurrykid
    I can vouch for that.  I'm current;y staring at a windows screen while my MacPro sits idle (web & email!) because PP hasn't crashed on the PC at all - not once, while the Mac crashes several times a day.
    I'm a little concerned that even the Adobe employees who pop in from time to time have nothing much to say about whther Adobe have even managed to recreate the problem, which is of course the first thing needed before they can even begin to fix it.  Perhaps if they could give us that much feedback at least, then we can know they are working on it and not just ignoring us.
    Jun 26, 2012 8:47 AM   in reply to ExactImage
    I would be willing to help them resolve it as well by sending my crash reports, testing new settings...whatever is needed to get this bug resolved quickly. I haven't seen a request for any information from anyone at this point. In post #105, Kevin (from Adobe) says he'll pass it on but he's not seeing the isue. Based on his specs though, he's not using Lion which off course could be a factor.
    Jun 26, 2012 9:00 AM   in reply to Kurrykid
    I'm seeing it on Snow Leopard (MacPro) as well, so it's not limited to Lion.
    Jun 26, 2012 10:08 AM   in reply to Kurrykid
    Kurrykid,
    I tried everything.  This worked fairly well until yesterday when my computer crashed and I had to do a cold boot. Haven't been able to unmute since then. My computer's slowed way down too.  It's making me uneasy.  Through all this, Premiere Pro audio has worked via the "internal speaker," which on a Mac Pro is a joke. I'm fed up with computers.
    Jun 26, 2012 10:32 AM   in reply to ExactImage
    Again, although we've only done two test edits now on our new MacBook Pro 17" (Lion) mobile unit, I'm not seeing the issue yet. This one is the A1297 which uses the AMD 6770M and the i7 processor is 2.4 ghz. Will be having some real world editing soon overseas in a few weeks, I'll post when I get back. But wouldn't it be cool if Adobe fixes it first.
    Last night I loaded Premiere 5.5, but will start our editing on CS6 to see if the issue occurs +we need Prelude. I do really like the CS6 interface/workflow, its getting there.
    Jun 26, 2012 11:31 AM   in reply to EditorPete
    The 10.7.4 update disabled my audio. Audio MIDI setup would crash on loading and I couldn't access my device settings or 'unmute' as others have observed. Also, Finder would "hang" for about 30 seconds at the beginning of startup while the sound icon and a few other icons went missing from the menu bar. This is why I've rolled back and continue to work on 10.7.3. I thought it was just an incompatibility between my Focusrite audio device, and the OS. Possibly related to this?
    Jun 26, 2012 3:01 PM   in reply to needles27
    I read somewhere in this thread someone asking if anyone on a mac was not getting "serious errors", so I thought I'd mention that we have 3 macs running CS6 that are all working fine. All are on 10.7.4, and were built recently as a clean install without migrating data. A Mac Pro 2,1 and a 2007 Macbook Pro both with no cuda, and a Mac Pro 3,1 with a GTX285. CUDA drivers were not updated on the 3,1 as the drivers out of the box are the right version for another piece of software we use. I'm not sure if that lends support to the CUDA drivers being to blame? Dunno.
    The only problems we've had since upgrading from 5.5 are to do with AVCHD files that have been wrapped as .movs, which worked in 5.5. but don't in 6 (media constantly pending), but I think that's a seperate issue.
    Jun 26, 2012 3:04 PM   in reply to SimonHy
    @SimonHy,
    Thanks for adding this.  do you know (or can you find out) what CUDA driver version you are running?   I'm also on a Mc Pro 3,1 with GTX285 and I'm seeing the problem.
    Jun 26, 2012 3:17 PM   in reply to ExactImage
    Yeah no problem.
    CUDA Driver Version: 4.0.19
    GPU Driver Version: 7.18.18 270.05.25f01
    Jun 26, 2012 3:40 PM   in reply to needles27
    Jun 26, 2012 4:50 PM   in reply to SimonHy
    @SimonHy,
    What type of footage (codecs) are you editing?
    Jun 26, 2012 5:01 PM   in reply to needles27
    @needles27,  this could possibly be pointing us to a solution through your misfortune.  If downgrading to an older drive is causing the error to happen more frequently, is it possible that our issue IS the driver?  I know there are many reports of non CUDA enabled GPU's receiving the error, so possibly it is the GPU driver not the CUDA driver that is continually triggering this error?
    @ExactImage,  I've been editing only ProRes timelines, mixed format: mpg, avi, mov, P2, Canon 5D and 7D only, C300 only, Sony F3 only, all of which at some point or another have given me the "serious error".
    Jun 26, 2012 5:06 PM   in reply to ExactImage
    Sorry that hasn't helped out.
    I'm cutting a variety or media; AVCHD .mts files from an FS100, XDCAM HD422 and XDCAM EX (both imported using Sony's XDCAM transfer for Mac, so turned into the Apple flavour of XDCAM .mov), ProRes, DV, HDV and a couple h264 flavours from DSLRs and from a GoPro camera. I'm working in an XDCAM HD422 50i timeline.
    Jun 26, 2012 5:26 PM   in reply to SimonHy
    Hi. I posted my issues on another thread, but  this seems to be the place to consolodate. Updated:
    I am getting full-blown kernal panics (requiring hard power cycle to unfreeze), "serious error", and "Premiere Pro has encountered an error". The last of which allows me to save, but keeps re-posting the error dialogue. The resulting "save" in this state is a corrupted PrP proj.
    PrP projects seem to get corrupted just after I have dynamically linked  with After Effects and begin to tweak the resulting timeline in AE (masks, levels... regular stuff/no special plugins).
    I have seen all three crashes even after running Disk Warrior. It doesn't seem to be related to invoking dynamic link. I've also gotten it just by scrubbing in my timeline, or by switching render settings from "performance" to "memory".
    I have gotten "serious error" after creating a new admin user and importing a non corrupted project into it to try to begin again.
    Crashes:
    • "Premiere Pro has encountered an error.
    [/Volumes/BuildDisk/builds/tightykilt/shared/adobe/MediaCore/AudioRend erer/Make/Mac/../../Src/AudioRender/AudioPrefetch.cpp-87]"
    • "Sorry, a serious error has occurred that requires Adobe Premiere Pro to shut down. We will attempt to save your current project."
    • kernel panic
    Specifics:
    SYSTEM:
    Premiere Pro 6.0.1
    Mac OS 10.7.4
    MacPro5,1
    32 GB Ram
    PROJECT & MEDIA drive: Mercury Accelsior. Blackmagic Disk Speed Test: > 500 MB/s read/write
    CACHE drive: Internal SATA Raid 0. Blackmagic Disk Speed Test: > 400 MB/s read/write
    Nvidia Quadro 4000 Mac
    CUDA Driver Version: 4.2.10
    GPU Driver Version: 1.3.4.0 (270.00.00f06)
    Cineform 1.2.0.127 codec installed for access to GoPro footage
    FOOTAGE:
    • h.264 from GoPro Hero 2: 720p60, 1080p30
    • h.264 from Canon D5: 1080p30, 1080p24
    • h.264 from Canon D7: 720p60, 1080p30, 1080p24
    • ProRes 422 720p24 recompressed Hero 2 footage which is longer than 10 minutes to avoid sluggish response.
    SEQUENCE:
    • 720p24. I have tried both "no" compression, and DSLR PrP settings.
    PROCESS AFTER CRASH:
    • delete Premiere prefs. with Prefrence Manager Version 3.2.1 (3210)
    • trash cache files
    • repair permissions
    • restart
    • duplicate latest auto-save and try to avoid using dynamic link.
    I'm going to try disabling my GPU... If that doesn't work, I'm going to try pulling my Nvidia Quadro
    Benjamin
    Jun 26, 2012 10:44 PM   in reply to Benjamin Goldman
    I'm the sole user of my computer. I'd prefer to junk the entire "permission" concept altogether. If any non-user is bored enough to "Read and Write" on my computer then that's a non-risk I'm willing to take. I'm an open book.
    If I could bypass this permission crap I could finally rule it out as the cause of my permanently-muted audio, perenially-slow processing, and multiple-other glitches.
    It's infuriating how many times I run Disk Utilty—even in a row—only to find case after case of "unexpected" permissions that need "repairing."  Here's my view: THEY'RE ALL UNEXPECTED. I never wanted permissions on my computer to begin with.
    Does any Mac user on this thread know whether or not we can grant open access to everything on our computers and to every non-existent "Guest User" under the sun and be free and clear of this nonsense?
    Jun 27, 2012 5:16 AM   in reply to genefama
    For what it's worth: it may seem like "nonsense" to you, but file permissions are key to the UNIX underpinnings of OS X.  It's one of the ways that UNIX (and therefore OS X) is so secure from things like general hacking, viruses, and what have you.  I hate to say it, but you're not going to get "free and clear" of it unless you want to back-grade to OS 9.  Which was a turd of an OS.
    Now, why you have to keep correcting file permissions like that is an interesting mystery.  Without seeing what's actually being corrected, I can't really tell you what or why.  My strong suspicion, however, is that it has absolutely nothing at all to do with your Premiere Pro issues.  In fact I'll bet a paycheck on it.
    jas
    Jun 27, 2012 5:24 AM   in reply to Jason Van Patten
    If you have a second data drive (don't do this to your main boot drive) you can right click on it, choose get info, then in the lower left choose to ignore permissions for this drive.   However, that is not the pancea it may first appear to be.
    Jun 27, 2012 6:29 AM   in reply to Jason Van Patten
    My MacBook Pro 17 inch late 2011, 2.4Ghz i7, 8GB RAM with AMD Radeon 6770M suffers the same crashing problem and it knocked out the audio system.
    Not just muted, it also ruin other system such as iTunes won't play (stays at 0:00) and hitting spacebar for Preview don't work on video files (only shows the bigger version of the thumbnail).
    I've reinstall Lion (via Recovery mode) and updated to 10.7.4, now everything works normal again. Phew...
    What is wrong with Premiere Pro CS6 and the Mac?
    I hope Adobe engineers come up with the update that will address this issue once and for all ASAP..
    Jun 27, 2012 9:02 AM   in reply to Jason Van Patten
    Jason,
    Do you mean Premiere Pro has nothing to do with my permissions being screweed up or that my permissions being screwed up has nothing to do with Premiere Pro having problems, or both?
    Gene
    Jun 27, 2012 10:04 AM   in reply to genefama
    Gene
    I'd have to see which file perms are screwed up to say whether PPro is causing them.  I'm quite certain that the perms being screwed up have nothing to do with your PPro problems though.
    jas
    Jun 27, 2012 11:04 AM   in reply to Jason Van Patten
    About the only time you'd expect trouble with permissions is when saving, caching or rendering to a drive or folder that disallows you access.  You would expect to see a warning that you don't have permission to (whatever).
    If you really want to manage or screw up your permissions on a Mac disk, check out the freeware app Batchmod.  It will let you set permissions at the drive to the file level.  You should have a pretty good grasp of what is permissable, because as I said, you can really screw things up doing it wrong.
    While I'm writing, I might as well note that there seems to be NO smoking gun, no "usual suspects" on this Serious Error issue.  It occurs on towers, laptops, Snow Leopard, Lion, AMD, nVidia, AJA, BMD, etc., with no single action or pattern implicated.
    My educated guess is that it's an OS thing, coupled with Adobe engineering.  We can't count on Apple to step up and fix this, because, whether you want to call it a conspiracy theory or not, they don't have a compelling interest in fixing a competing NLE.  Therefore, IMO, it's up to Adobe to fix this on their own, or point the finger of blame where it belongs.  Doing nothing isn't an option, because word is going to get around that Pr on Mac is not a viable, dependable editing platform.
    Jun 27, 2012 11:08 AM   in reply to AudyErel
    AudyErel, since our laptops are identical (except for ram and probably additional software) and we are not yet having these issues I'm wondering if there is any third-party stuff happening that is causing the problems. We do not have any third-party codecs other than the stuff that comes with ProRes (via installing Motion, etc) and Avid DNxHD. On this mobile system we have not installed any third-party plugins for Premiere, or any for the Adobe suite.
    We do have drivers installed for a Sonnet card reader that interfaces via their Thunderbolt/eSATA interface and our external mini raid hard drive is connected to eSATA via a Sonnet express 34 card. So that would be all with any extra thrid party drivers that I can think of. We have the latest version of Lion and CS 6.
    Jun 27, 2012 1:43 PM   in reply to Jim Curtis
    No smoking gun. Bummer. Maybe it's actually our attitude
    Ok, that's it I'm switching back and dropping my membership to FCPX Anonymous. FCPX your looking hopeful! Ok, well maybe not. Not yet
    (But truth be known, I have a hidden copy on my laptop, but don't tell anyone.)
    Please forgive my lapse into insanity. At least 5.5 is looking promising in the short term.
    Jun 27, 2012 2:47 PM   in reply to Glitchdog
    MAC PRO 2 x 2.93 GHz 6 Core
    12 GB 1333 MJZ DDR3 Ram
    Kona 3 card
    Quadro 4000 graphics card
    OS 10.7.4
    CS6.0.1.31
    Video drive Apple XServe raid
    plus 2 TB G-raid & 3, 2 TB internal 7200 RPM drives
    I too am having the same problems...also losing renders when it crashes
    I'm just finishing up an hour show and in the last few days PPCS6 has been crashing at least 3 or 4 times a day.  It's also been acting very sluggish at times and i'm also getting stuttering playback.
    Timeline is DVCPROHD, 108060i and most of the material is that format, though I do have about 25 stills tiffs & JPGs along with a dozen or so HDV stock footage shots.  Also used the warp stabilizer on a half dozen aerials.
    Anyone have any suggestions.
    Here is a crash report from the last mishap:
    6/27 crash
    Process:         Adobe Premiere Pro CS6 [494]
    Path:            /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/Adobe Premiere Pro CS6
    Identifier:      com.adobe.AdobePremierePro
    Version:         6.0.1 (6.0.1)
    Code Type:       X86-64 (Native)
    Parent Process:  launchd [157]
    Date/Time:       2012-06-27 14:27:06.545 -0700
    OS Version:      Mac OS X 10.7.4 (11E53)
    Report Version:  9
    Interval Since Last Report:          -2444 sec
    Per-App Interval Since Last Report:  20276 sec
    Anonymous UUID:                      CEB15D79-0990-47C1-8E2D-0FFD6041EDE8
    Crashed Thread:  9
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
    VM Regions Near 0:
        __TEXT                 0000000100000000-0000000100004000 [   16K] r-x/rwx SM=COW  /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/Adobe Premiere Pro CS6
    Application Specific Information:
    objc[494]: garbage collection is OFF
    Thread 0:: Dispatch queue: com.apple.main-thread
    0   libsystem_kernel.dylib                  0x00007fff9114567a mach_msg_trap + 10
    1   libsystem_kernel.dylib                  0x00007fff91144d71 mach_msg + 73
    2   com.apple.CoreFoundation                0x00007fff9135c50c __CFRunLoopServiceMachPort + 188
    3   com.apple.CoreFoundation                0x00007fff91364c74 __CFRunLoopRun + 1204
    4   com.apple.CoreFoundation                0x00007fff91364486 CFRunLoopRunSpecific + 230
    5   com.apple.HIToolbox                     0x00007fff939244d3 RunCurrentEventLoopInMode + 277
    6   com.apple.HIToolbox                     0x00007fff9392b781 ReceiveNextEventCommon + 355
    7   com.apple.HIToolbox                     0x00007fff9392b60e BlockUntilNextEventMatchingListInMode + 62
    8   com.apple.AppKit                        0x00007fff977d3e31 _DPSNextEvent + 659
    9   com.apple.AppKit                        0x00007fff977d3735 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
    10  com.apple.AppKit                        0x00007fff977d0071 -[NSApplication run] + 470
    11  com.adobe.premiere.frontend             0x000000010c720cd4 FE::MacApplication::RunSelf() + 44
    12  com.adobe.premiere.frontend             0x000000010c6cb4df FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 5681
    13  com.adobe.premiere.frontend             0x000000010c72224c AppMain + 380
    14  com.adobe.premiere.startup              0x000000010c8921d7 Run + 247
    15  com.adobe.AdobePremierePro              0x00000001000038b7 main + 647
    16  com.adobe.AdobePremierePro              0x000000010000361c start + 52
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib                  0x00007fff911477e6 kevent + 10
    1   libdispatch.dylib                       0x00007fff9422a78a _dispatch_mgr_invoke + 923
    2   libdispatch.dylib                       0x00007fff9422931a _dispatch_mgr_thread + 54
    Thread 2:
    0   libsystem_kernel.dylib                  0x00007fff91146bca __psynch_cvwait + 10
    1   libsystem_c.dylib                       0x00007fff9773f274 _pthread_cond_wait + 840
    2   com.apple.CoreServices.CarbonCore          0x00007fff93015a5e TSWaitOnCondition + 106
    3   com.apple.CoreServices.CarbonCore          0x00007fff92fa7ea6 TSWaitOnConditionTimedRelative + 127
    4   com.apple.CoreServices.CarbonCore          0x00007fff92fece81 MPWaitOnQueue + 181
    5   com.adobe.ASLFoundation.framework          0x00000001005bf300 _ZN3ASL12_GLOBAL__N_1L8TaskProcEPv + 160
    6   com.apple.CoreServices.CarbonCore          0x00007fff92fedce6 PrivateMPEntryPoint + 58
    7   libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    8   libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 3:
    5   com.adobe.dvacore.framework             0x00000001001f8f74 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr< dvacore::threads::AllocatedFunctionT<boost::function<void ()()> > >&, int) + 200
    6   com.adobe.dvacore.framework             0x00000001001f6273 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 115
    7   com.adobe.dvacore.framework             0x00000001001f3963 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9functi on0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 163
    8   com.adobe.boost_threads.framework          0x000000010012aace thread_proxy + 158
    9   libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    10  libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 4:
    Thread 5:
    1   com.adobe.dvatransport.framework          0x0000000100798f12 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_op eration>&) + 240
    2   com.adobe.dvatransport.framework          0x00000001007a30da boost::asio::detail::task_io_service::do_one(boost::asio::detail::sco ped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service::idle_thread_info*) + 512
    3   com.adobe.dvatransport.framework          0x00000001007a3467 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 291
    4   com.adobe.dvatransport.framework          0x000000010078ffbd SkyConnectionEnv::MainLoop() + 129
    5   com.adobe.dvatransport.framework          0x000000010079003b SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
    6   com.adobe.boost_threads.framework          0x000000010012aace thread_proxy + 158
    Thread 6:
    2   com.adobe.dvatransport.framework          0x00000001007a304b boost::asio::detail::task_io_service::do_one(boost::asio::detail::sco ped_lock<boost::asio::detail::posix_mutex>&, boost::asio::detail::task_io_service::idle_thread_info*) + 369
    4   com.adobe.dvatransport.framework          0x0000000100790c2a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver _service_base::work_io_service_runner>::run() + 42
    5   com.adobe.dvatransport.framework          0x0000000100793c33 boost_asio_detail_posix_thread_function + 19
    6   libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    7   libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 7:
    Thread 8:
    0   com.adobe.dvacore.framework             0x0000000100166056 _ZN7dvacore7utilityL19InitializeAllocatorEv + 6
    1   com.adobe.dvacore.framework             0x0000000100166305 dvacore::utility::SmallBlockAllocator::Dispose(void*, unsigned long) + 341
    2   com.adobe.dvacore.framework             0x000000010015a79e std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >::push_back(unsigned short) + 146
    3   com.adobe.dvacore.framework             0x00000001001e33d6 void jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::push_string::operator()<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >(__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, __gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >) const + 88
    4   com.adobe.dvacore.framework             0x00000001001e3775 boost::spirtnotthreadsafe::classic::match<boost::spirtnotthreadsafe:: classic::nil_t> boost::spirtnotthreadsafe::classic::impl::contiguous_parser_parse<boo st::spirtnotthreadsafe::classic::match<boost::spirtnotthreadsafe::cla s sic::nil_t>, boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::sequence<boost::spirtnotthreadsafe::classic::sequence<boost : :spirtnotthreadsafe::classic::chlit<char>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::alternative<boost::spirtnotthreadsafe::classic::differ e nce<boost::spirtnotthreadsafe::classic::anychar_parser, boost::spirtnotthreadsafe::classic::alternative<boost::spirtnotthread safe::classic::chlit<char>, boost::spirtnotthreadsafe::classic::chlit<char> > >, boost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsaf e::classic::chlit<char>, boost::spirtnotthreadsafe::classic::alternative<boost::spirtnotthread safe::classic::alternative<boost::spirtnotthreadsafe::classic::altern a tive<boost::spirtnotthreadsafe::classic::alternative<boost::spirtnott h readsafe::classic::alternative<boost::spirtnotthreadsafe::classic::al t ernative<boost::spirtnotthreadsafe::classic::alternative<boost::spirt n otthreadsafe::classic::alternative<boost::spirtnotthreadsafe::classic : :chlit<char>, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsaf e::classic::chlit<char>, boost::spirtnotthreadsafe::classic::fixed_loop<boost::spirtnotthreads afe::classic::xdigit_parser, int> > > > > > >, boost::spirtnotthreadsafe::classic::chlit<char> >, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::push_string>, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::iteration_policy>(boost::spirtnot threadsafe::classic::action<boost::spirtnotthreadsafe::classic::seque n ce<boost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthread s afe::classic::chlit<char>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::alternative<boost::spirtnotthreadsafe::classic::differ e nce<boost::spirtnotthreadsafe::classic::anychar_parser, boost::spirtnotthreadsafe::classic::alternative<boost::spirtnotthread safe::classic::chlit<char>, boost::spirtnotthreadsafe::classic::chlit<char> > >, boost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsaf e::classic::chlit<char>, boost::spirtnotthreadsafe::classic::alternative<boost::spirtnotthread safe::classic::alternative<boost::spirtnotthreadsafe::classic::altern a tive<boost::spirtnotthreadsafe::classic::alternative<boost::spirtnott h readsafe::classic::alternative<boost::spirtnotthreadsafe::classic::al t ernative<boost::spirtnotthreadsafe::classic::alternative<boost::spirt n otthreadsafe::classic::alternative<boost::spirtnotthreadsafe::classic : :chlit<char>, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsaf e::classic::chlit<char>, boost::spirtnotthreadsafe::classic::fixed_loop<boost::spirtnotthreads afe::classic::xdigit_parser, int> > > > > > >, boost::spirtnotthreadsafe::classic::chlit<char> >, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::push_string> const&, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&, boost::spirtnotthreadsafe::classic::skipper_iteration_policy<boost::s pirtnotthreadsafe::classic::iteration_policy> const&) + 229
    5   com.adobe.dvacore.framework             0x00000001001e19a1 boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::sequence<boost::spirtnotthreadsafe::classic::rule<bo o st::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator < unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsaf e::classic::rule<boost::spirtnotthreadsafe::classic::scanner<__gnu_cx x ::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::chlit<char> >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 45
    6   com.adobe.dvacore.framework             0x00000001001e3322 boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::action<boost::spirtnotthreadsafe::classic::sequence< b oost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsafe : :classic::rule<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx: : __normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::create_pair>, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::sequence<boost::spirtnotthreadsafe::classic::sequence<boost : :spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::classic : :scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::create_pair>::parse<boost::spirtnotthreadsafe::classic::scanner<__ gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 118
    7   com.adobe.dvacore.framework             0x00000001001e189d boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<c h ar>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsaf e::classic::chlit<char>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 185
    8   com.adobe.dvacore.framework             0x00000001001e1918 boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::optional<boost::spirtnotthreadsafe::classic::sequenc e <boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe:: c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 82
    9   com.adobe.dvacore.framework             0x00000001001dd676 boost::spirtnotthreadsafe::classic::impl::concrete_parser<boost::spir tnotthreadsafe::classic::sequence<boost::spirtnotthreadsafe::classic: : sequence<boost::spirtnotthreadsafe::classic::action<boost::spirtnotth r eadsafe::classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::begin_object>, boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > > >, boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::end_object> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t>::do_parse_virtual(boost::s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 68
    10  com.adobe.dvacore.framework             0x00000001001ddf3e boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::alternative<boost::spirtnotthreadsafe::classic::alte r native<boost::spirtnotthreadsafe::classic::alternative<boost::spirtno t threadsafe::classic::alternative<boost::spirtnotthreadsafe::classic:: a lternative<boost::spirtnotthreadsafe::classic::rule<boost::spirtnotth r eadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::alternative<boost::spirtnotthread safe::classic::alternative<boost::spirtnotthreadsafe::classic::altern a tive<boost::spirtnotthreadsafe::classic::alternative<boost::spirtnott h readsafe::classic::alternative<boost::spirtnotthreadsafe::classic::ru l e<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite r ator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 36
    11  com.adobe.dvacore.framework             0x00000001001e18fb boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::optional<boost::spirtnotthreadsafe::classic::sequenc e <boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe:: c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 53
    12  com.adobe.dvacore.framework             0x00000001001dd79a boost::spirtnotthreadsafe::classic::impl::concrete_parser<boost::spir tnotthreadsafe::classic::sequence<boost::spirtnotthreadsafe::classic: : sequence<boost::spirtnotthreadsafe::classic::action<boost::spirtnotth r eadsafe::classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::begin_array>, boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > > >, boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::end_array> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t>::do_parse_virtual(boost::s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 68
    13  com.adobe.dvacore.framework             0x00000001001ddf5e boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::alternative<boost::spirtnotthreadsafe::classic::alte r native<boost::spirtnotthreadsafe::classic::alternative<boost::spirtno t threadsafe::classic::alternative<boost::spirtnotthreadsafe::classic:: a lternative<boost::spirtnotthreadsafe::classic::rule<boost::spirtnotth r eadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::alternative<boost::spirtnotthread safe::classic::alternative<boost::spirtnotthreadsafe::classic::altern a tive<boost::spirtnotthreadsafe::classic::alternative<boost::spirtnott h readsafe::classic::alternative<boost::spirtnotthreadsafe::classic::ru l e<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite r ator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 68
    14  com.adobe.dvacore.framework             0x00000001001e18fb boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::optional<boost::spirtnotthreadsafe::classic::sequenc e <boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe:: c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 53
    15  com.adobe.dvacore.framework             0x00000001001dd79a boost::spirtnotthreadsafe::classic::impl::concrete_parser<boost::spir tnotthreadsafe::classic::sequence<boost::spirtnotthreadsafe::classic: : sequence<boost::spirtnotthreadsafe::classic::action<boost::spirtnotth r eadsafe::classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::begin_array>, boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > > >, boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::end_array> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t>::do_parse_virtual(boost::s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 68
    16  com.adobe.dvacore.framework             0x00000001001ddf5e boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::alternative<boost::spirtnotthreadsafe::classic::alte r native<boost::spirtnotthreadsafe::classic::alternative<boost::spirtno t threadsafe::classic::alternative<boost::spirtnotthreadsafe::classic:: a lternative<boost::spirtnotthreadsafe::classic::rule<boost::spirtnotth r eadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::alternative<boost::spirtnotthread safe::classic::alternative<boost::spirtnotthreadsafe::classic::altern a tive<boost::spirtnotthreadsafe::classic::alternative<boost::spirtnott h readsafe::classic::alternative<boost::spirtnotthreadsafe::classic::ru l e<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite r ator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 68
    17  com.adobe.dvacore.framework             0x00000001001e334a boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::action<boost::spirtnotthreadsafe::classic::sequence< b oost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsafe : :classic::rule<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx: : __normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::create_pair>, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::sequence<boost::spirtnotthreadsafe::classic::sequence<boost : :spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::classic : :scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::create_pair>::parse<boost::spirtnotthreadsafe::classic::scanner<__ gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 158
    18  com.adobe.dvacore.framework             0x00000001001e189d boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<c h ar>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsaf e::classic::chlit<char>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 185
    19  com.adobe.dvacore.framework             0x00000001001e1934 boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::optional<boost::spirtnotthreadsafe::classic::sequenc e <boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe:: c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 110
    20  com.adobe.dvacore.framework             0x00000001001dd676 boost::spirtnotthreadsafe::classic::impl::concrete_parser<boost::spir tnotthreadsafe::classic::sequence<boost::spirtnotthreadsafe::classic: : sequence<boost::spirtnotthreadsafe::classic::action<boost::spirtnotth r eadsafe::classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::begin_object>, boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > > >, boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::end_object> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t>::do_parse_virtual(boost::s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 68
    21  com.adobe.dvacore.framework             0x00000001001ddf3e boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::alternative<boost::spirtnotthreadsafe::classic::alte r native<boost::spirtnotthreadsafe::classic::alternative<boost::spirtno t threadsafe::classic::alternative<boost::spirtnotthreadsafe::classic:: a lternative<boost::spirtnotthreadsafe::classic::rule<boost::spirtnotth r eadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::alternative<boost::spirtnotthread safe::classic::alternative<boost::spirtnotthreadsafe::classic::altern a tive<boost::spirtnotthreadsafe::classic::alternative<boost::spirtnott h readsafe::classic::alternative<boost::spirtnotthreadsafe::classic::ru l e<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite r ator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 36
    22  com.adobe.dvacore.framework             0x00000001001e18fb boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::optional<boost::spirtnotthreadsafe::classic::sequenc e <boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe:: c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 53
    23  com.adobe.dvacore.framework             0x00000001001dd79a boost::spirtnotthreadsafe::classic::impl::concrete_parser<boost::spir tnotthreadsafe::classic::sequence<boost::spirtnotthreadsafe::classic: : sequence<boost::spirtnotthreadsafe::classic::action<boost::spirtnotth r eadsafe::classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::begin_array>, boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > > >, boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::end_array> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t>::do_parse_virtual(boost::s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 68
    24  com.adobe.dvacore.framework             0x00000001001ddf5e boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::alternative<boost::spirtnotthreadsafe::classic::alte r native<boost::spirtnotthreadsafe::classic::alternative<boost::spirtno t threadsafe::classic::alternative<boost::spirtnotthreadsafe::classic:: a lternative<boost::spirtnotthreadsafe::classic::rule<boost::spirtnotth r eadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::alternative<boost::spirtnotthread safe::classic::alternative<boost::spirtnotthreadsafe::classic::altern a tive<boost::spirtnotthreadsafe::classic::alternative<boost::spirtnott h readsafe::classic::alternative<boost::spirtnotthreadsafe::classic::ru l e<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite r ator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 68
    25  com.adobe.dvacore.framework             0x00000001001e334a boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::action<boost::spirtnotthreadsafe::classic::sequence< b oost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsafe : :classic::rule<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx: : __normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::create_pair>, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::sequence<boost::spirtnotthreadsafe::classic::sequence<boost : :spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::classic : :scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::chlit<char> >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::create_pair>::parse<boost::spirtnotthreadsafe::classic::scanner<__ gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 158
    26  com.adobe.dvacore.framework             0x00000001001e189d boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<c h ar>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::sequence<boost::spirtnotthreadsaf e::classic::chlit<char>, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 185
    27  com.adobe.dvacore.framework             0x00000001001e1934 boost::spirtnotthreadsafe::classic::parser_result<boost::spirtnotthre adsafe::classic::optional<boost::spirtnotthreadsafe::classic::sequenc e <boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe:: c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >::type boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > >::parse<boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__nor mal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > >(boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_ite rator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 110
    28  com.adobe.dvacore.framework             0x00000001001dd676 boost::spirtnotthreadsafe::classic::impl::concrete_parser<boost::spir tnotthreadsafe::classic::sequence<boost::spirtnotthreadsafe::classic: : sequence<boost::spirtnotthreadsafe::classic::action<boost::spirtnotth r eadsafe::classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::begin_object>, boost::spirtnotthreadsafe::classic::optional<boost::spirtnotthreadsaf e::classic::sequence<boost::spirtnotthreadsafe::classic::rule<boost:: s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t>, boost::spirtnotthreadsafe::classic::kleene_star<boost::spirtnotthread safe::classic::sequence<boost::spirtnotthreadsafe::classic::chlit<cha r >, boost::spirtnotthreadsafe::classic::rule<boost::spirtnotthreadsafe::c lassic::scanner<__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t, boost::spirtnotthreadsafe::classic::nil_t> > > > > >, boost::spirtnotthreadsafe::classic::action<boost::spirtnotthreadsafe: :classic::chlit<char>, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::end_object> >, boost::spirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_itera tor<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> >, boost::spirtnotthreadsafe::classic::nil_t>::do_parse_virtual(boost::s pirtnotthreadsafe::classic::scanner<__gnu_cxx::__normal_iterator<unsi g ned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, boost::spirtnotthreadsafe::classic::scanner_policies<boost::spirtnott hreadsafe::classic::skipper_iteration_policy<boost::spirtnotthreadsaf e ::classic::iteration_policy>, boost::spirtnotthreadsafe::classic::match_policy, boost::spirtnotthreadsafe::classic::action_policy> > const&) const + 68
    29  com.adobe.dvacore.framework             0x00000001001e1653 boost::spirtnotthreadsafe::classic::parse_info<__gnu_cxx::__normal_it erator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > boost::spirtnotthreadsafe::classic::impl::phrase_parser<boost::spirtn otthreadsafe::classic::space_parser>::parse<__gnu_cxx::__normal_itera t or<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >(__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > const&, __gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > const&, jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > const&, boost::spirtnotthreadsafe::classic::space_parser const&) + 179
    30  com.adobe.dvacore.framework             0x00000001001e2254 jsonnotthreadsafe::grammar<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >::variant jsonnotthreadsafe::parse<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, __gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > >(__gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, __gnu_cxx::__normal_iterator<unsigned short const*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >) + 244
    31  com.adobe.dvacore.framework             0x00000001001dd378 dvacore::serialization::JSONParse(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 72
    32  com.adobe.ImporterHost.framework          0x00000001044b8fec dvacore::serialization::Serializer<ML::ImporterState>::FromString(std ::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 28
    33  com.adobe.ImporterHost.framework          0x00000001044a4b10 ML::FileImporter::RestoreImporterStateFromMediaAcceleratorDatabase(st d::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData const&, dvacore::utility::Guid, dvacore::utility::Guid, int&) + 1036
    34  com.adobe.ImporterHost.framework          0x00000001044a938c ML::FileImporter::Open(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool) + 1722
    35  com.adobe.ImporterHost.framework          0x00000001044f939a ML::ImporterModule::CreateMediaInfo(ASL::InterfaceRef<BE::Deprecated: :IMediaInfo, BE::Deprecated::IMediaInfo>&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >&, int, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, boost::shared_ptr<MF::StillSequence> const&, bool&, bool, bool, bool) const + 1486
    36  com.adobe.ImporterHost.framework          0x00000001044ee363 ML::ImporterFactory::CreateFileMediaInfoInner(std::basic_string<unsig ned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, boost::shared_ptr<MF::StillSequence> const&, bool&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, bool) + 2715
    37  com.adobe.ImporterHost.framework          0x00000001044ed179 ML::ImporterFactory::CreateFileMediaInfo(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, bool, bool&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, bool) + 257
    38  com.adobe.ProjectSupport.framework          0x0000000104d4c621 ML::Media::FindMediaInfo(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, ASL::ParamRect<int>, dvamediatypes::FrameRate, dvamediatypes::FrameRate, dvamediatypes::PixelAspectRatio, bool, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&) + 753
    39  com.adobe.ProjectSupport.framework          0x0000000104d4db67 ML::MediaInfoProvider::ProvideMediaInfo(dvacore::utility::Guid const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, dvamediatypes::FrameRate const&, dvamediatypes::PixelAspectRatio const&, ASL::ParamRect<int> const&, dvamediatypes::FrameRate const&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&) + 457
    40  com.adobe.Backend.framework             0x0000000101650d94 BE::Media::RelinkMediaInfo() + 998
    41  com.adobe.Backend.framework             0x0000000101641809 non-virtual thunk to BE::Media::CheckMediaInfoRelink(bool) + 57
    42  com.adobe.Backend.framework             0x0000000101646d24 _ZN2BE12_GLOBAL__N_1L22HandleOneRelinkRequestEv + 500
    43  com.adobe.dvacore.framework             0x00000001001e6a3a dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost:: function<void ()()> const&) + 52
    44  com.adobe.dvacore.framework             0x00000001001e4f1d dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr<dvacor e::threads::(anonymous namespace)::SubExecutorImpl> const&) + 267
    45  com.adobe.dvacore.framework             0x00000001001f62c2 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 194
    46  com.adobe.dvacore.framework             0x00000001001f3963 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9functi on0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 163
    47  com.adobe.boost_threads.framework          0x000000010012aace thread_proxy + 158
    48  libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    49  libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 9 Crashed:
    0   ???                                     000000000000000000 0 + 0
    1   com.adobe.AdobeXMPFiles                 0x00000001012339f7 WXMPFiles_CloseFile_1 + 426905
    2   com.adobe.AdobeXMPFiles                 0x0000000101233e19 WXMPFiles_CloseFile_1 + 427963
    3   com.adobe.AdobeXMPFiles                 0x0000000101239f11 WXMPFiles_CloseFile_1 + 452787
    4   com.adobe.AdobeXMPFiles                 0x00000001011ce21c WXMPFiles_CloseFile_1 + 11198
    5   com.adobe.AdobeXMPFiles                 0x00000001011cb111 WXMPFiles_OpenFile_1 + 86
    6   com.adobe.ImporterHost.framework          0x000000010449ebed TXMPFiles<std::string>::OpenFile(char const*, unsigned int, unsigned int) + 29
    7   com.adobe.ImporterHost.framework          0x000000010450639e ML::MetadataManager::ReadMetadata(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, MF::BinaryData&, bool*, bool*) + 958
    8   com.adobe.ImporterHost.framework          0x00000001044c7e4f ML::FileImporter::ReadXMPData() + 519
    9   com.adobe.ImporterHost.framework          0x00000001044a4d76 ML::FileImporter::RestoreImporterStateFromMediaAcceleratorDatabase(st d::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData const&, dvacore::utility::Guid, dvacore::utility::Guid, int&) + 1650
    10  com.adobe.ImporterHost.framework          0x00000001044a938c ML::FileImporter::Open(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool) + 1722
    11  com.adobe.ImporterHost.framework          0x00000001044f939a ML::ImporterModule::CreateMediaInfo(ASL::InterfaceRef<BE::Deprecated: :IMediaInfo, BE::Deprecated::IMediaInfo>&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >&, int, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, boost::shared_ptr<MF::StillSequence> const&, bool&, bool, bool, bool) const + 1486
    12  com.adobe.ImporterHost.framework          0x00000001044ee363 ML::ImporterFactory::CreateFileMediaInfoInner(std::basic_string<unsig ned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, boost::shared_ptr<MF::StillSequence> const&, bool&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, bool) + 2715
    13  com.adobe.ImporterHost.framework          0x00000001044ed179 ML::ImporterFactory::CreateFileMediaInfo(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, bool, bool&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, bool) + 257
    14  com.adobe.ProjectSupport.framework          0x0000000104d4c621 ML::Media::FindMediaInfo(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, ASL::ParamRect<int>, dvamediatypes::FrameRate, dvamediatypes::FrameRate, dvamediatypes::PixelAspectRatio, bool, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&) + 753
    15  com.adobe.ProjectSupport.framework          0x0000000104d4db67 ML::MediaInfoProvider::ProvideMediaInfo(dvacore::utility::Guid const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, dvamediatypes::FrameRate const&, dvamediatypes::PixelAspectRatio const&, ASL::ParamRect<int> const&, dvamediatypes::FrameRate const&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&) + 457
    16  com.adobe.Backend.framework             0x0000000101650d94 BE::Media::RelinkMediaInfo() + 998
    17  com.adobe.Backend.framework             0x0000000101641809 non-virtual thunk to BE::Media::CheckMediaInfoRelink(bool) + 57
    18  com.adobe.Backend.framework             0x0000000101646d24 _ZN2BE12_GLOBAL__N_1L22HandleOneRelinkRequestEv + 500
    19  com.adobe.dvacore.framework             0x00000001001e6a3a dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost:: function<void ()()> const&) + 52
    20  com.adobe.dvacore.framework             0x00000001001e4f1d dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr<dvacor e::threads::(anonymous namespace)::SubExecutorImpl> const&) + 267
    21  com.adobe.dvacore.framework             0x00000001001f62c2 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 194
    22  com.adobe.dvacore.framework             0x00000001001f3963 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9functi on0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 163
    23  com.adobe.boost_threads.framework          0x000000010012aace thread_proxy + 158
    24  libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    25  libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 10:
    0   com.adobe.MXFHandler.framework          0x000000011d22342c DYLD-STUB$$strlen + 0
    1   com.adobe.AdobeXMPFiles                 0x00000001012327dd WXMPFiles_CloseFile_1 + 422271
    2   com.adobe.AdobeXMPFiles                 0x0000000101232c10 WXMPFiles_CloseFile_1 + 423346
    3   com.adobe.AdobeXMPFiles                 0x00000001012339c0 WXMPFiles_CloseFile_1 + 426850
    4   com.adobe.AdobeXMPFiles                 0x0000000101233e19 WXMPFiles_CloseFile_1 + 427963
    5   com.adobe.AdobeXMPFiles                 0x0000000101239f11 WXMPFiles_CloseFile_1 + 452787
    6   com.adobe.AdobeXMPFiles                 0x00000001011ce21c WXMPFiles_CloseFile_1 + 11198
    7   com.adobe.AdobeXMPFiles                 0x00000001011cb111 WXMPFiles_OpenFile_1 + 86
    8   com.adobe.ImporterHost.framework          0x000000010449f0ae TXMPFiles<std::string>::TXMPFiles(char const*, unsigned int, unsigned int) + 120
    9   com.adobe.ImporterHost.framework          0x0000000104504c49 ML::MetadataManager::(anonymous namespace)::GetXMPFormat(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 217
    10  com.adobe.ImporterHost.framework          0x0000000104505061 _ZN2ML15MetadataManager12_GLOBAL__N_1L14GetXMPDateTimeERKSbItSt11char _traitsItEN7dvacore7utility19SmallBlockAllocator12STLAllocatorItEEE + 97
    11  com.adobe.ImporterHost.framework          0x0000000104505221 ML::MetadataManager::GetMetadataModificationTime(std::basic_string<un signed short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 17
    12  com.adobe.ImporterHost.framework          0x00000001044da39f ML::Importer::GetFileCurrentMediaState(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) const + 39
    13  com.adobe.ImporterHost.framework          0x00000001044a579d ML::FileImporter::GetMediaState(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 103
    14  com.adobe.ImporterHost.framework          0x00000001044a924a ML::FileImporter::Open(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool) + 1400
    15  com.adobe.ImporterHost.framework          0x00000001044f939a ML::ImporterModule::CreateMediaInfo(ASL::InterfaceRef<BE::Deprecated: :IMediaInfo, BE::Deprecated::IMediaInfo>&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >&, int, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, boost::shared_ptr<MF::StillSequence> const&, bool&, bool, bool, bool) const + 1486
    16  com.adobe.ImporterHost.framework          0x00000001044ee363 ML::ImporterFactory::CreateFileMediaInfoInner(std::basic_string<unsig ned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, boost::shared_ptr<MF::StillSequence> const&, bool&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, bool) + 2715
    17  com.adobe.ImporterHost.framework          0x00000001044ed179 ML::ImporterFactory::CreateFileMediaInfo(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, bool, bool&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, bool) + 257
    18  com.adobe.ProjectSupport.framework          0x0000000104d4c621 ML::Media::FindMediaInfo(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, ASL::ParamRect<int>, dvamediatypes::FrameRate, dvamediatypes::FrameRate, dvamediatypes::PixelAspectRatio, bool, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&) + 753
    19  com.adobe.ProjectSupport.framework          0x0000000104d4db67 ML::MediaInfoProvider::ProvideMediaInfo(dvacore::utility::Guid const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, dvamediatypes::FrameRate const&, dvamediatypes::PixelAspectRatio const&, ASL::ParamRect<int> const&, dvamediatypes::FrameRate const&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&) + 457
    20  com.adobe.Backend.framework             0x0000000101650d94 BE::Media::RelinkMediaInfo() + 998
    21  com.adobe.Backend.framework             0x0000000101641809 non-virtual thunk to BE::Media::CheckMediaInfoRelink(bool) + 57
    22  com.adobe.Backend.framework             0x0000000101646d24 _ZN2BE12_GLOBAL__N_1L22HandleOneRelinkRequestEv + 500
    23  com.adobe.dvacore.framework             0x00000001001e6a3a dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost:: function<void ()()> const&) + 52
    24  com.adobe.dvacore.framework             0x00000001001e4f1d dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr<dvacor e::threads::(anonymous namespace)::SubExecutorImpl> const&) + 267
    25  com.adobe.dvacore.framework             0x00000001001f62c2 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 194
    26  com.adobe.dvacore.framework             0x00000001001f3963 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9functi on0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 163
    27  com.adobe.boost_threads.framework          0x000000010012aace thread_proxy + 158
    28  libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    29  libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 11:
    0   libsystem_kernel.dylib                  0x00007fff91146d52 __read_nocancel + 10
    1   libsystem_c.dylib                       0x00007fff97737c25 _sread + 19
    2   libsystem_c.dylib                       0x00007fff97738166 __srefill1 + 30
    3   libsystem_c.dylib                       0x00007fff97738a2e _fseeko + 769
    4   libsystem_c.dylib                       0x00007fff97738acb fseeko + 79
    5   libMXF_SDK.dylib.4.4.3                  0x0000000232d8bf84 MXF::SDK::Platform::fileSeek(__sFILE*, long long) + 14
    6   libMXF_SDK.dylib.4.4.3                  0x0000000232c69ffc MXF::SDK::DataIO::File::FileImpl::seek(unsigned long long) + 80
    7   libMXF_SDK.dylib.4.4.3                  0x0000000232c687d6 MXF::SDK::DataIO::File::FileDataSource::seek(unsigned long long) + 14
    8   libMXF_SDK.dylib.4.4.3                  0x0000000232d4d032 MXF::SDK::MXFIO::Reader::Impl::loadRIP() + 114
    9   libMXF_SDK.dylib.4.4.3                  0x0000000232d4b905 MXF::SDK::MXFIO::Reader::loadRIP() + 13
    10  com.adobe.ImporterP2.framework          0x00000001cd753d28 ImporterP2::MediaFileDescriptor::OpenFile(boost::shared_ptr<ImporterP 2::MXFDataSourceManager>) + 588
    11  com.adobe.ImporterP2.framework          0x00000001cd73fc22 ImporterP2::ImporterP2::OnOpenFile8(void**, imFileOpenRec8*) + 1822
    12  com.adobe.ImporterP2.framework          0x00000001cd7512d5 PrImportModule<ImporterP2::ImporterP2>::ImportEntry(ASL::ResourceColl ection const&, int, imStdParms*, void*, void*) + 415
    13  com.adobe.ImporterP2.framework          0x00000001cd750e9d xImportEntry + 93
    14  com.adobe.ImporterHost.framework          0x00000001044fd154 ML::LocalImporterModule::CallImportModuleGuarded(int, void*, void*, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 138
    15  com.adobe.ImporterHost.framework          0x00000001044fd5c9 ML::LocalImporterModule::CallImportModule(int, void*, void*) + 825
    16  com.adobe.ImporterHost.framework          0x00000001044f2a22 ML::ImporterInstance::DoOpen(bool) + 308
    17  com.adobe.ImporterHost.framework          0x00000001044f2b58 ML::ImporterInstance::Open() + 64
    18  com.adobe.ImporterHost.framework          0x00000001044a95ef ML::FileImporter::Open(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool) + 2333
    19  com.adobe.ImporterHost.framework          0x00000001044f939a ML::ImporterModule::CreateMediaInfo(ASL::InterfaceRef<BE::Deprecated: :IMediaInfo, BE::Deprecated::IMediaInfo>&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >&, int, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, boost::shared_ptr<MF::StillSequence> const&, bool&, bool, bool, bool) const + 1486
    20  com.adobe.ImporterHost.framework          0x00000001044ee363 ML::ImporterFactory::CreateFileMediaInfoInner(std::basic_string<unsig ned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, boost::shared_ptr<MF::StillSequence> const&, bool&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, bool) + 2715
    21  com.adobe.ImporterHost.framework          0x00000001044ed179 ML::ImporterFactory::CreateFileMediaInfo(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, dvamediatypes::FrameRate const&, dvamediatypes::FrameRate const&, ASL::ParamRect<int> const&, dvamediatypes::PixelAspectRatio const&, bool, bool&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, bool) + 257
    22  com.adobe.ProjectSupport.framework          0x0000000104d4c621 ML::Media::FindMediaInfo(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, ASL::ParamRect<int>, dvamediatypes::FrameRate, dvamediatypes::FrameRate, dvamediatypes::PixelAspectRatio, bool, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&) + 753
    23  com.adobe.ProjectSupport.framework          0x0000000104d4db67 ML::MediaInfoProvider::ProvideMediaInfo(dvacore::utility::Guid const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, MF::BinaryData&, std::map<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >, std::less<std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > >, dvacore::utility::SmallBlockAllocator::STLAllocator<std::pair<std::ba sic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > > > >&, bool, dvamediatypes::FrameRate const&, dvamediatypes::PixelAspectRatio const&, ASL::ParamRect<int> const&, dvamediatypes::FrameRate const&, ASL::InterfaceRef<BE::Deprecated::IMediaInfo, BE::Deprecated::IMediaInfo>&) + 457
    24  com.adobe.Backend.framework             0x0000000101650d94 BE::Media::RelinkMediaInfo() + 998
    25  com.adobe.Backend.framework             0x0000000101641809 non-virtual thunk to BE::Media::CheckMediaInfoRelink(bool) + 57
    26  com.adobe.Backend.framework             0x0000000101646d24 _ZN2BE12_GLOBAL__N_1L22HandleOneRelinkRequestEv + 500
    27  com.adobe.dvacore.framework             0x00000001001e6a3a dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost:: function<void ()()> const&) + 52
    28  com.adobe.dvacore.framework             0x00000001001e4f1d dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr<dvacor e::threads::(anonymous namespace)::SubExecutorImpl> const&) + 267
    29  com.adobe.dvacore.framework             0x00000001001f62c2 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 194
    30  com.adobe.dvacore.framework             0x00000001001f3963 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9functi on0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 163
    31  com.adobe.boost_threads.framework          0x000000010012aace thread_proxy + 158
    32  libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    33  libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 12:
    0   libsystem_kernel.dylib                  0x00007fff91146bca __psynch_cvwait + 10
    1   libsystem_c.dylib                       0x00007fff9773f2a6 _pthread_cond_wait + 890
    2   com.apple.CoreServices.CarbonCore          0x00007fff92fa7ec4 TSWaitOnConditionTimedRelative + 157
    3   com.apple.CoreServices.CarbonCore          0x00007fff92fece81 MPWaitOnQueue + 181
    4   com.adobe.dvacore.framework             0x00000001001f8f74 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr< dvacore::threads::AllocatedFunctionT<boost::function<void ()()> > >&, int) + 200
    5   com.adobe.dvacore.framework             0x00000001001f6273 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 115
    Thread 13:
    1   libsystem_c.dylib                       0x00007fff9773f274 _pthread_cond_wait + 840
    2   com.apple.CoreServices.CarbonCore          0x00007fff93015a5e TSWaitOnCondition + 106
    3   com.apple.CoreServices.CarbonCore          0x00007fff92fa7ea6 TSWaitOnConditionTimedRelative + 127
    4   com.apple.CoreServices.CarbonCore          0x00007fff92fece81 MPWaitOnQueue + 181
    5   com.adobe.dvacore.framework             0x00000001001f8f74 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr< dvacore::threads::AllocatedFunctionT<boost::function<void ()()> > >&, int) + 200
    6   com.adobe.dvacore.framework             0x00000001001f6273 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore:: threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 115
    7   com.adobe.dvacore.framework             0x00000001001f3963 _ZN7dvacore7threads12_GLOBAL__N_1L12LaunchThreadERKSsRKN5boost9functi on0IvEENS0_14ThreadPriorityERKNS4_8functionIFvvEEESE_ + 163
    8   com.adobe.boost_threads.framework          0x000000010012aace thread_proxy + 158
    9   libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    10  libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 14:
    Thread 15:
    0   libsystem_kernel.dylib                  0x00007fff9114567a mach_msg_trap + 10
    1   libsystem_kernel.dylib                  0x00007fff91144d71 mach_msg + 73
    2   libcuda_270.05.25.dylib                 0x0000000116bacd88 cudbgGetAPIVersion + 232808
    3   libcuda_270.05.25.dylib                 0x0000000116b355e8 cuGraphicsGLRegisterBuffer + 330776
    4   libcuda_270.05.25.dylib                 0x0000000116bae5d2 cudbgGetAPIVersion + 239026
    5   libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    6   libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 16:
    2   com.apple.CoreFoundation                0x00007fff9135c50c __CFRunLoopServiceMachPort + 188
    3   com.apple.CoreFoundation                0x00007fff91364c74 __CFRunLoopRun + 1204
    4   com.apple.CoreFoundation                0x00007fff91364486 CFRunLoopRunSpecific + 230
    5   com.apple.AVCVideoServices              0x00000001226f4ad0 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 186
    6   libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    7   libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 17:
    Thread 18:
    Thread 19:
    0   libsystem_kernel.dylib                  0x00007fff91146e42 __semwait_signal + 10
    1   libsystem_c.dylib                       0x00007fff976f1dea nanosleep + 164
    2   com.adobe.ScriptLayerPPro.framework          0x0000000106cd06fb ScObjects::Thread::sleep(unsigned int) + 59
    3   com.adobe.ScriptLayerPPro.framework          0x0000000106cbc259 ScObjects::BridgeTalkThread::run() + 169
    4   com.adobe.ScriptLayerPPro.framework          0x0000000106cd0a66 ScObjects::Thread::go(void*) + 166
    Thread 20:
    0   libsystem_kernel.dylib                  0x00007fff91146d7a __recvfrom + 10
    1   ServiceManager-Launcher.dylib           0x000000011875e5ec Invoke + 45721
    2   ServiceManager-Launcher.dylib           0x000000011875d813 Invoke + 42176
    3   ServiceManager-Launcher.dylib           0x000000011875cbe0 Invoke + 39053
    4   ServiceManager-Launcher.dylib           0x000000011875cc66 Invoke + 39187
    5   ServiceManager-Launcher.dylib           0x000000011875830f Invoke + 20412
    6   ServiceManager-Launcher.dylib           0x0000000118758616 Invoke + 21187
    7   ServiceManager-Launcher.dylib           0x0000000118758cd7 Invoke + 22916
    8   ServiceManager-Launcher.dylib           0x0000000118758f41 Invoke + 23534
    9   ServiceManager-Launcher.dylib           0x000000011875b61d Invoke + 33482
    10  ServiceManager-Launcher.dylib           0x000000011875b775 Invoke + 33826
    11  ServiceManager-Launcher.dylib           0x000000011875bfb2 Invoke + 35935
    12  ServiceManager-Launcher.dylib           0x000000011875c0ad Invoke + 36186
    13  ServiceManager-Launcher.dylib           0x000000011874ed6b Login + 480
    14  ServiceManager-Launcher.dylib           0x00000001187527ad Login + 15394
    15  ServiceManager-Launcher.dylib           0x000000011875c412 Invoke + 37055
    16  ServiceManager-Launcher.dylib           0x000000011875e253 Invoke + 44800
    17  libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    18  libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 21:
    Thread 22:: com.apple.CFSocket.private
    0   libsystem_kernel.dylib                  0x00007fff91146df2 __select + 10
    1   com.apple.CoreFoundation                0x00007fff913adc8b __CFSocketManager + 1355
    Thread 23:
    0   libsystem_kernel.dylib                  0x00007fff911477e6 kevent + 10
    1   com.adobe.MediaFoundation.framework          0x0000000100d212a3 _ZN2MF22DirectoryChangeMonitor12_GLOBAL__N_1L20EventQueueThreadProcEP v + 435
    Thread 24:: com.apple.audio.IOThread.client
    2   com.apple.audio.CoreAudio               0x00007fff968ddeb3 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, unsigned int) + 93
    3   com.apple.audio.CoreAudio               0x00007fff968ddf05 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, unsigned int) + 37
    4   com.apple.audio.CoreAudio               0x00007fff968d7568 HALC_ProxyIOContext::IOWorkLoop() + 888
    5   com.apple.audio.CoreAudio               0x00007fff968d7151 HALC_ProxyIOContext::IOThreadEntry(void*) + 73
    6   com.apple.audio.CoreAudio               0x00007fff968d700c HALB_IOThread::Entry(void*) + 78
    Thread 25:
    2   com.apple.CoreServices.CarbonCore          0x00007fff93013c02 TS_exception_listener_thread + 100
    3   libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    4   libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 26:
    0   com.adobe.Backend.framework             0x0000000101aae662 BE::(anonymous namespace)::XMLValueIterator::operator()(ASL::ImmutableString const&, unsigned long, BE::OutputValueBase const&) + 784
    1   com.adobe.Backend.framework             0x00000001015a50f9 BE::CompositeOutputValue::ForAll(BE::CompositeOutputValue::ForAllFunc &) const + 77
    2   com.adobe.Backend.framework             0x0000000101aafba4 BE::(anonymous namespace)::XMLValueWriter::WriteComposite(BE::(anonymous namespace)::XMLWriterContext&, ASL::ImmutableString const&, unsigned long, BE::CompositeOutputValue const&, ASL::InterfaceRef<BE::IProgress, BE::IProgress>) + 838
    3   com.adobe.Backend.framework             0x0000000101aae914 BE::(anonymous namespace)::XMLValueIterator::operator()(ASL::ImmutableString const&, unsigned long, BE::OutputValueBase const&) + 1474
    4   com.adobe.Backend.framework             0x00000001015a5147 BE::CompositeOutputValue::ForAll(BE::CompositeOutputValue::ForAllFunc &) const + 155
    5   com.adobe.Backend.framework             0x0000000101ab03cd BE::XMLWriter::WriteValues(BE::CompositeOutputValue const&, std::map<dvacore::utility::Guid, ASL::ObjectPtr<BE::OutputValueEntry, ASL::AtomicValue>, std::less<dvacore::utility::Guid>, std::allocator<std::pair<dvacore::utility::Guid const, ASL::ObjectPtr<BE::OutputValueEntry, ASL::AtomicValue> > > > const&) + 1121
    6   com.adobe.Backend.framework             0x00000001015bd93b BE::Serializer::SaveObject(ASL::InterfaceRef<ASL::ASLUnknown, ASL::ASLUnknown>, ASL::ImmutableString const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<BE::IProgress, BE::IProgress>, long long) + 2219
    7   com.adobe.Backend.framework             0x00000001016ab9f6 int BE::Serializer::Save<ASL::InterfaceRef<BE::Project, BE::IProject> >(ASL::InterfaceRef<BE::Project, BE::IProject>, ASL::ImmutableString const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<BE::IProgress, BE::IProgress>, long long) + 1014
    8   com.adobe.Backend.framework             0x00000001016a2104 BE::Project::Save(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, ASL::InterfaceRef<BE::IProgress, BE::IProgress>) + 1438
    9   com.adobe.Backend.framework             0x00000001016d177d BE::ProjectProxy::Save(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, ASL::InterfaceRef<BE::IProgress, BE::IProgress>) + 147
    10  com.adobe.premiere.frontend             0x000000010c6fc2da FE::DocumentManager::AttemptPanicProjectSave() + 536
    11  com.adobe.premiere.frontend             0x000000010c6c9e3e FE::Application::AttemptPanicProjectSave() + 24
    12  com.adobe.premiere.frontend             0x000000010c7217cc UnixInterruptSignal(int) + 44
    13  com.adobe.dvacore.framework             0x0000000100279b35 _ZN12_GLOBAL__N_1L13SignalHandlerEiP9__siginfoPv + 261
    14  libsystem_c.dylib                       0x00007fff9778fcfa _sigtramp + 26
    15  com.aja.DeviceAJASerial                 0x00000002f96e96a3 CExt422::m_getVTRTcType() + 259
    16  com.aja.DeviceAJASerial                 0x00000002f96e9940 CExt422::m_getVTRInfo() + 192
    17  com.aja.DeviceAJASerial                 0x00000002f96eb360 CExt422::m_checkDevice(bool, bool) + 1664
    18  com.aja.DeviceAJASerial                 0x00000002f96eff12 CExt422::m_getMode() + 114
    19  com.aja.DeviceAJASerial                 0x00000002f96e53b4 CExt::m_vvwThread() + 1220
    20  com.aja.DeviceAJASerial                 0x00000002f96e42cf _vvwThread(void*) + 31
    21  libsystem_c.dylib                       0x00007fff9773b8bf _pthread_start + 335
    22  libsystem_c.dylib                       0x00007fff9773eb75 thread_start + 13
    Thread 27:
    0   libsystem_kernel.dylib                  0x00007fff91147192 __workq_kernreturn + 10
    1   libsystem_c.dylib                       0x00007fff9773d594 _pthread_wqthread + 758
    2   libsystem_c.dylib                       0x00007fff9773eb85 start_wqthread + 13
    Thread 28:: Dispatch queue: com.apple.root.default-priority
    0   com.adobe.ImporterMP3.framework          0x0000000162e9bf50 CPolyphase::Apply(float (&) [2][18][32], float*) + 1968
    1   com.adobe.ImporterMP3.framework          0x0000000162e8dbaf CMp3Decode::Decode(void*, int, int*, int, unsigned char*, int*, int, unsigned int*, unsigned int*) + 3455
    Thread 29:
    Thread 30:
    Thread 31:
    3   com.apple.CoreServices.CarbonCore          0x00007fff92fa7c9b TSWaitOnSemaphoreCommon + 358
    4   com.apple.CoreServices.CarbonCore          0x00007fff92fdb6d6 AsyncFileThread(void*) + 219
    Thread 9 crashed with X86 Thread State (64-bit):
      rax: 0x000000010ea51530  rbx: 0x0000000119084e70  rcx: 0x0000000119084e8f  rdx: 0x0000000000000000
      rdi: 0x000000010ea4dcf8  rsi: 0x00000002f9e72258  rbp: 0x00000001190852d0  rsp: 0x0000000119084e08
       r8: 0x0000000119084e70   r9: 0x000000010ea47408  r10: 0x00000000be2ab6b8  r11: 0x000000009828f613
      r12: 0x0000000000000000  r13: 0x00000001190852e0  r14: 0x0000000000000000  r15: 0x00000002f9e72258
      rip: 0x0000000000000000  rfl: 0x0000000000010203  cr2: 0x0000000000000000
    Logical CPU: 14
    Binary Images:
           0x100000000 -        0x100003ff7 +com.adobe.AdobePremierePro (6.0.1 - 6.0.1) <235A9737-DBF6-33F7-E3C0-BE780C209731> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/Adobe Premiere Pro CS6
           0x100008000 -        0x10000cff7 +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120201) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/A dobeCrashReporter
           0x100012000 -        0x1000f6fe7 +com.adobe.amtlib (amtlib 6.0.0.75 - 6.0.0.75) <07A3E1E1-55C3-BA5B-A0B0-60250809ED61> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
           0x100107000 -        0x10010efff +com.adobe.boost_date_time.framework (6.0.1 - 6.0.1.14) <E62E7675-0ECB-9EBF-D25F-74696ADF95DC> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boos t_date_time
           0x100129000 -        0x100138fff +com.adobe.boost_threads.framework (6.0.1 - 6.0.1.14) <F162CA9B-EE48-03D9-DF70-B469F5037495> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_ threads
           0x100159000 -        0x100323fe7 +com.adobe.dvacore.framework (6.0.1 - 6.0.1.14) <8D990AF8-7A2A-0558-C1B9-3ACA3ED6AD31> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
           0x100531000 -        0x10055bff7 +com.adobe.dvamediatypes.framework (6.0.1 - 6.0.1.14) <98C334F4-4874-73B8-36B2-A9B7F8610D80> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamed iatypes
           0x10058e000 -        0x10058fff7 +com.adobe.PRM.framework (6.0.1 - 6.0.1.0) <CEDDAE9A-2D3C-9DD6-9970-C9CE3584DE17> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
           0x100595000 -        0x1005f7ff7 +com.adobe.ASLFoundation.framework (6.0.1 - 6.0.1.0) <31FF1663-FED7-53D2-DACF-57D06089EF28> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFou ndation
           0x1006ed000 -        0x10070afff +com.adobe.ASLMessaging.framework (6.0.1 - 6.0.1.0) <D610A756-E095-8C24-2A0B-A7F4C3AE74B2> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMess aging
           0x100738000 -        0x100739fff +com.adobe.Memory.framework (6.0.1 - 6.0.1.0) <0D8C1C1D-902E-FDF7-5A65-76CBABD671E2> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
           0x100740000 -        0x10074ffff +com.adobe.ASLUnitTesting.framework (6.0.1 - 6.0.1.0) <808597E9-755A-86B7-A787-25CE7562DF85> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUn itTesting
           0x10076a000 -        0x10076dfff +com.adobe.boost_system.framework (6.0.1 - 6.0.1.14) <10207FB6-09BB-52FB-B130-5E71A526E8FC> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_s ystem
           0x100773000 -        0x1007d9ff7 +com.adobe.dvatransport.framework (6.0.1 - 6.0.1.14) <69F85FAA-8BFC-8749-C8E0-6DFE38A5C74A> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatran sport
           0x10085a000 -        0x10088eff7 +com.adobe.dvamarshal.framework (6.0.1 - 6.0.1.14) <C25CABFE-675D-9AEC-CEAF-AC06ADD008B8> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarsha l
           0x100914000 -        0x100af9fef +com.adobe.dynamiclink.framework (6.0.1 - 6.0.1.14) <9CC848BF-A4DB-3F6F-93AF-68027E37659D> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamicl ink
           0x100cfb000 -        0x100d61ff7 +com.adobe.MediaFoundation.framework (6.0.1 - 6.0.1.0) <E3A490D5-82CB-5D50-7927-0578EA0040B0> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/Medi aFoundation
           0x100de9000 -        0x100e95ff7 +com.adobe.AudioRenderer.framework (6.0.1 - 6.0.1.0) <2EA4787A-347E-4227-2390-90F172346FAD> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioR enderer
           0x100f54000 -        0x100f7efff +com.adobe.dvacaptioning.framework (6.0.1 - 6.0.1.14) <CDADEEED-0127-3F7A-3BCF-CC6CD12C281B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacap tioning
           0x100fb4000 -        0x10100bfff +com.adobe.dvatemporalxmp.framework (6.0.1 - 6.0.1.14) <AC601AFA-E402-E238-BDCB-0828B387D82F> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvate mporalxmp
           0x10103f000 -        0x10104bfff +com.adobe.boost_signals.framework (6.0.1 - 6.0.1.14) <0A6F7D25-2F10-EDF1-C249-E424D428BBFA> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_ signals
           0x101063000 -        0x1010bdff7 +com.adobe.dvametadata.framework (6.0.1 - 6.0.1.14) <229E5B72-9EBF-EBEC-1049-358890BF84BC> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametad ata
           0x10115a000 -        0x1011baff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.146729) <88C23D1F-50F3-13DD-7C60-F9530B29513E> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
           0x1011c4000 -        0x10127bfef +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.4 -f 51 - 66.146729) <D961D69F-E61B-BFB0-81D4-7924221B8E1B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeX MPFiles
           0x1012ae000 -        0x1020e5fff +com.adobe.Backend.framework (6.0.1 - 6.0.1.0) <96D23F9F-7251-4220-99D4-9B4AB0E8BB2E> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
           0x102b69000 -        0x102cadff7 +com.adobe.ImageRenderer.framework (6.0.1 - 6.0.1.0) <74409E76-8B38-7E4E-77BB-DA617BB8DBCC> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageR enderer
           0x102e0f000 -        0x102e58ff7 +com.adobe.MLFoundation.framework (6.0.1 - 6.0.1.0) <F7B5A0D2-FD2B-65FF-1738-875A761FAFEF> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFound ation
           0x102ec8000 -        0x102f1cff7 +com.adobe.VideoFrame.framework (6.0.1 - 6.0.1.0) <CD865B28-B00A-3B91-410D-4F4FB597959B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFram e
           0x102f6c000 -        0x102fa8fff +com.adobe.PluginSupport.framework (6.0.1 - 6.0.1.0) <979EF250-E245-2007-5114-CF6F75E3B5C5> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/PluginSupport.framework/Versions/A/Plugin Support
           0x102fee000 -        0x10301aff7 +com.adobe.SweetPeaSupport.framework (6.0.1 - 6.0.1.0) <863F0FE1-2731-0C67-055D-7EE0EFCC17A9> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/Swee tPeaSupport
           0x103052000 -        0x103095ff7 +com.adobe.AudioSupport.framework (6.0.1 - 6.0.1.0) <ECCF4BDA-9784-F7F4-FA4A-F33F1E393F31> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSu pport
           0x1030df000 -        0x1030e2fff +com.adobe.MediaUtils.framework (6.0.1 - 6.0.1.0) <201246DB-B51B-88FC-DCDC-C7747B848F8F> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtil s
           0x1030e9000 -        0x10310cfff +com.adobe.AudioFilterHost.framework (6.0.1 - 6.0.1.0) <67084A93-3001-64E4-28C3-EE036222E7CF> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/Audi oFilterHost
           0x10313b000 -        0x103181fff +com.adobe.AudioFilters.framework (6.0.1 - 6.0.1.0) <854392B5-CCC9-E49B-32A1-881E9F61142B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFi lters
           0x1031de000 -        0x103646fef +com.adobe.dvaui.framework (6.0.1 - 6.0.1.14) <2E93FCA8-FFD0-9A59-9CA5-95934BA2C4C0> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
           0x103bb6000 -        0x103e75fe7 +com.adobe.UIFramework.framework (6.0.1 - 6.0.1.14) <2E3DFE33-7100-8993-732D-6D5B2CC607B3> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramew ork
           0x1041fb000 -        0x104350ff7 +com.adobe.VideoRenderer.framework (6.0.1 - 6.0.1.0) <E6E2B9CB-1378-55A2-2076-D4D52276D386> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoR enderer
           0x104467000 -        0x1045f8ff7 +com.adobe.ImporterHost.framework (6.0.1 - 6.0.1.0) <EDBA9E76-98E4-8AC4-EEFF-F9FC9EBE06B8> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ImporterHost.framework/Versions/A/Importe rHost
           0x104775000 -        0x104867fef +com.adobe.ExporterHost.framework (6.0.1 - 6.0.1.0) <BA9432C4-4D36-26D6-64E6-429C428BE0D5> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ExporterHost.framework/Versions/A/Exporte rHost
           0x104957000 -        0x1049dbff7 +com.adobe.PlayerHost.framework (6.0.1 - 6.0.1.0) <FFE36131-2314-B5F2-AAB8-37367A75838C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHos t
           0x104a70000 -        0x104ae4ff7 +com.adobe.RecorderHost.framework (6.0.1 - 6.0.1.0) <E6E743A5-8735-E898-E29D-3B1456A77B16> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/RecorderHost.framework/Versions/A/Recorde rHost
           0x104b67000 -        0x104b79ff7 +com.adobe.ProjectConverterHost.framework (6.0.1 - 6.0.1.0) <1E7BCBC9-FB15-6292-E04B-7507F90F1A39> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A /ProjectConverterHost
           0x104b96000 -        0x104c88fff +com.adobe.VideoFilterHost.framework (6.0.1 - 6.0.1.0) <A675BE76-A620-B22A-3334-2EAB29E9513E> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/Vide oFilterHost
           0x104d49000 -        0x104d61fff +com.adobe.ProjectSupport.framework (6.0.1 - 6.0.1.0) <EED05C53-842F-967C-4395-0CE9D67D8921> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/Proje ctSupport
           0x104d89000 -        0x104e54ff7 +com.adobe.AMEWrapper.framework (6.0.1 - 6.0.1.0) <34537491-C810-FE9B-46C1-62F3F2E3286C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrappe r
           0x104f1e000 -        0x10501cff7 +com.adobe.EncoderHost.framework (6.0.1 - 6.0.1.0) <78D40799-92D7-974B-F5D8-DA83B6FC6CDC> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderH ost
           0x105111000 -        0x1051b1ff7 +com.adobe.MBCProvider.framework (6.0.1 - 6.0.1.14) <BC755689-A67B-2009-7A69-4EB5F4FC3049> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvi der
           0x105225000 -        0x105a89ff7 +com.adobe.Mezzanine.framework (6.0.1 - 6.0.1.14) <5D5A67D7-BDDD-C9B1-4585-FD756697B638> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
           0x105f7d000 -        0x105f97ff7 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
           0x105fa0000 -        0x105ff9fff +com.adobe.BravoInitializer.framework (6.0.1 - 6.0.1.0) <AC39E535-8C35-2ED5-25E6-79B615A524F7> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/Bra voInitializer
           0x106073000 -        0x1061ecfff +com.adobe.ACE (AdobeACE 2.19.18.19243 - 2.19.18.19243) <7F28B188-1D1B-20C9-BBB9-B74FCC12ECAD> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
           0x1061ff000 -        0x10657cfff +com.adobe.AGM (AdobeAGM 4.26.17.19243 - 4.26.17.19243) <19B59987-1020-E125-DC86-EA48FC81A890> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
           0x1065e8000 -        0x106607fff +com.adobe.BIB (AdobeBIB 1.2.02.19243 - 1.2.02.19243) <B7D7EE28-D604-2989-B099-62AEF4885C21> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
           0x10660e000 -        0x10696ffef +com.adobe.CoolType (AdobeCoolType 5.10.31.19243 - 5.10.31.19243) <8BFF14FB-AA14-1CBF-C2A3-715363B5A841> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeC oolType
           0x1069bc000 -        0x106a74ff7 +com.adobe.dvaworkspace.framework (6.0.1 - 6.0.1.14) <BF54C3D2-6F87-1A10-FBB9-3CD2AA385F30> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvawork space
           0x106b81000 -        0x106dcffff +com.adobe.ScriptLayerPPro.framework (6.0.1 - 6.0.1.14) <5BCEB2C6-A842-B5A5-B49A-D70B48920525> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/Scri ptLayerPPro
           0x1070c9000 -        0x107186fff +com.adobe.AdobeExtendScript (ExtendScript 4.2.12 - 4.2.12.18602) <0957DFA6-0593-CE4B-8638-00F32113B07B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/Ad obeExtendScript
           0x1071d0000 -        0x10727efef +com.adobe.AdobeScCore (ScCore 4.2.12 - 4.2.12.18602) <9CEE95E5-2FC6-5E58-02A4-138EA6F8D894> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScC ore
           0x1072bb000 -        0x10738afff +com.adobe.dvaeve.framework (6.0.1 - 6.0.1.14) <E9B926FA-FE8A-50C3-ADF5-3FC1753F57C7> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
           0x1074fd000 -        0x107559ff7 +com.adobe.MediaCoreUI.framework (6.0.1 - 6.0.1.0) <AFD91DF9-5572-0019-8CF0-3E8717614BD0> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCor eUI
           0x1075bc000 -        0x1077b2fff +com.adobe.SettingsUI.framework (6.0.1 - 6.0.1.0) <E46C7D1F-C767-5A4C-44D0-ADF676F94ED9> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsU I
           0x107a10000 -        0x107c10fff +com.adobe.HSL.framework (6.0.1 - 6.0.1.14) <E104CB38-5492-5D11-D3DB-1436E580F445> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
           0x107dec000 -        0x108133ff7 +com.adobe.Dialogs.framework (6.0.1 - 6.0.1.14) <1CA7918F-A7B5-6004-C00B-4FE0C874A3D6> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
           0x1083ed000 -        0x108417ff7 +com.adobe.HandlerAudioMiniMixer.framework (6.0.1 - 6.0.1.14) <FB0820EA-433A-CC50-069B-560EC68C6A0C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/ A/HandlerAudioMiniMixer
           0x108451000 -        0x108500fff +com.adobe.HandlerAudioMixer.framework (6.0.1 - 6.0.1.14) <DF976C38-F2FC-4934-EADF-058B2B1DA46A> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/Ha ndlerAudioMixer
           0x1085bb000 -        0x10866aff7 +com.adobe.HandlerCapture.framework (6.0.1 - 6.0.1.14) <5EAD806F-56CC-810C-BE76-329FC293708C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/Handl erCapture
           0x108739000 -        0x108765fff +com.adobe.HandlerCSXS.framework (6.0.1 - 6.0.1.14) <B8012F03-8E7C-5CDA-FFC1-50D02A694256> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerC SXS
           0x1087b6000 -        0x108a33fff +com.adobe.HandlerEffectControls.framework (6.0.1 - 6.0.1.14) <8CBD5516-C973-0E61-DBD7-46214292687A> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/ A/HandlerEffectControls
           0x108c2d000 -        0x108ca0fff +com.adobe.HandlerEffects.framework (6.0.1 - 6.0.1.14) <FA66004B-3B5A-32BD-8A23-CE65036A22CA> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/Handl erEffects
           0x108d17000 -        0x108d23ff7 +com.adobe.HandlerEvents.framework (6.0.1 - 6.0.1.14) <B5C76AA7-E126-40B3-7F31-64C8E422A8BC> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/Handle rEvents
           0x108d46000 -        0x108d58fff +com.adobe.HandlerGetProperties.framework (6.0.1 - 6.0.1.14) <B2A63715-4F91-F774-4944-31A6D20375AC> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A /HandlerGetProperties
           0x108d78000 -        0x108d90fff +com.adobe.HandlerHistory.framework (6.0.1 - 6.0.1.14) <33912380-5E61-79CD-05CB-AA07C736A788> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/Handl erHistory
           0x108dbc000 -        0x108df7ff7 +com.adobe.HandlerInfo.framework (6.0.1 - 6.0.1.14) <3EF418ED-EF2E-A29A-C09D-9387C6881C02> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerI nfo
           0x108e58000 -        0x108e88fff +com.adobe.HandlerMarkerList.framework (6.0.1 - 6.0.1.14) <7C86998D-CC40-E231-B271-B85F79CBFE2B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerMarkerList.framework/Versions/A/Ha ndlerMarkerList
           0x108eda000 -        0x108f36fff +com.adobe.HandlerMetadataEditor.framework (6.0.1 - 6.0.1.14) <EE5FC077-02D8-57D6-8443-1E59696F1227> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/ A/HandlerMetadataEditor
           0x108fca000 -        0x1090a1ff7 +com.adobe.HandlerMediaBrowser.framework (6.0.1 - 6.0.1.14) <26BA0479-F0D3-729D-E0CF-0328D83C2C25> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/ HandlerMediaBrowser
           0x1091b5000 -        0x1091e6fff +com.adobe.HandlerMulticam.framework (6.0.1 - 6.0.1.14) <87F0BB5F-C206-D237-9C71-3C736D00CD53> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerMulticam.framework/Versions/A/Hand lerMulticam
           0x109235000 -        0x109319fef +com.adobe.HandlerProgramMonitor.framework (6.0.1 - 6.0.1.14) <089C735E-66CC-03DB-95BD-6C827575C3C8> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/ A/HandlerProgramMonitor
           0x10940d000 -        0x109618ff7 +com.adobe.HandlerProject.framework (6.0.1 - 6.0.1.14) <3FDCAD6E-E36F-2C96-E8F4-63911A3CA665> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerProject.framework/Versions/A/Handl erProject
           0x1097eb000 -        0x109952fef +com.adobe.HandlerSourceMonitor.framework (6.0.1 - 6.0.1.14) <3A6C0D47-6C24-E27E-BC4E-06CF9D6D826C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A /HandlerSourceMonitor
           0x109a56000 -        0x109a68ff7 +com.adobe.HandlerTimecode.framework (6.0.1 - 6.0.1.14) <BB0D7699-742C-C5F6-C7FD-028DB773B332> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerTimecode.framework/Versions/A/Hand lerTimecode
           0x109a8b000 -        0x109d38ff7 +com.adobe.HandlerTimeline.framework (6.0.1 - 6.0.1.14) <2EB26666-71EB-A254-B2FD-5E85AD006F8A> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/Hand lerTimeline
           0x109f41000 -        0x109faaff7 +com.adobe.FontEngine.framework (6.0.1 - 6.0.1.14) <A9667306-9E8E-C691-4AFD-789809E0F350> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngin e
           0x10a03b000 -        0x10a05aff7 +com.adobe.TitleLayer.framework (6.0.1 - 6.0.1.14) <A73C6E72-1AD4-9A59-DB14-97A32716C79D> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLaye r
           0x10a1f7000 -        0x10a205fff +com.adobe.TitleImageManager.framework (6.0.1 - 6.0.1.14) <4F3F31D7-BF19-CA4E-8F79-DA8A2FA75ECE> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/Ti tleImageManager
           0x10a21d000 -        0x10a2a8ff7 +com.adobe.TitleCharacterFactory.framework (6.0.1 - 6.0.1.14) <EC4043FC-9AC6-966E-4927-4463C3362E11> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/ A/TitleCharacterFactory
           0x10a302000 -        0x10a3faff7 +com.adobe.TitleCG.framework (6.0.1 - 6.0.1.14) <E1A9DD08-D4D7-6D54-D3EC-E4B633C31E84> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
           0x10a48b000 -        0x10a833fff +com.adobe.TitleLayout.framework (6.0.1 - 6.0.1.14) <16C761C0-8A96-77DB-90CB-973E9FA41341> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLay out
           0x10ae2e000 -        0x10aeaffef +com.adobe.TitleRenderer.framework (6.0.1 - 6.0.1.14) <09477D7D-5569-4A4D-47E7-4D066FE10280> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleR enderer
           0x10af5f000 -        0x10b7bdfe7 +com.adobe.premiere.HandlerTitler (1.0 - 1.0) <584EA1FA-BFBB-A445-6C5B-CD7C0D1E0A9C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/Handle rTitler
           0x10c0a6000 -        0x10c1f3ff7 +WRServices (??? - ???) <58A30CB8-5C47-93D1-BC68-1204A0C2674F> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRService s
           0x10c267000 -        0x10c28cff7 +com.adobe.HandlerTools.framework (6.0.1 - 6.0.1.14) <FB0095D8-866B-0003-AEE3-34BD2D0525D7> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerTools.framework/Versions/A/Handler Tools
           0x10c2d5000 -        0x10c31fff7 +com.adobe.HandlerTrim.framework (6.0.1 - 6.0.1.14) <07355B9D-1D2C-FB25-4759-149BF49A37A6> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerTrim.framework/Versions/A/HandlerT rim
           0x10c379000 -        0x10c38aff7 +com.adobe.HandlerVSTEditor.framework (6.0.1 - 6.0.1.14) <C84AF86A-4AA2-E40E-5BF7-E45E063C4207> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/HandlerVSTEditor.framework/Versions/A/Han dlerVSTEditor
           0x10c3aa000 -        0x10c3caff7 +com.adobe.CSXSManager.framework (6.0.1 - 6.0.1.14) <99B95D10-FD64-AC90-4203-5C66EE59DA8F> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSMana ger
           0x10c3fa000 -        0x10c5aafef +com.adobe.PlugPlug (3.0.0.383 - 3.0.0.383) <908DBB12-D2AC-1844-BD2A-F1C483424917> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
           0x10c661000 -        0x10c68dfff +com.adobe.PrRegistration.framework (6.0.1 - 6.0.1.14) <06DF8776-7ECF-1ED1-73CA-02CD5C62610B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/PrRegistration.framework/Versions/A/PrReg istration
           0x10c6b0000 -        0x10c798ff7 +com.adobe.premiere.frontend (1.0 - 1.0) <16514331-E6AF-7572-812E-F1964AA40D43> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
           0x10c88b000 -        0x10c8affe7 +com.adobe.premiere.startup (1.0 - 1.0) <32930BA3-24D5-00FD-2022-1D3DA7CCAA9E> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/Startup.framework/Versions/A/Startup
           0x10c8d2000 -        0x10cbaafe6 +libxerces-c-3.0.dylib (??? - ???) <46020284-EEA8-7D7B-388C-BF23A318C997> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/libxerces-c-3.0.dylib
           0x10cd2b000 -        0x10cd4ffe7 +com.mainconcept.mc.enc.dv (9.1 - 9.1.6.7339) <F977AE49-D347-16CB-0AE7-D3B10569BC69> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/mc_enc_dv.framework/Versions/9/mc_enc_dv
           0x10cd63000 -        0x10cd63fff  libmx.A.dylib (2026.0.0 - compatibility 1.0.0) <C23BF0A1-7E6D-35EF-85FE-651EE2C13D53> /usr/lib/libmx.A.dylib
           0x10cd66000 -        0x10ce38ff7 +com.adobe.exo.framework (6.0.1 - 6.0.1.14) <C3A03556-8DA7-F996-43BA-3D10514424A2> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/exo.framework/Versions/A/exo
           0x10cf9c000 -        0x10cfe1fff +com.adobe.dynamiclinkui.framework (6.0.1 - 6.0.1.14) <B63B029B-7620-8720-B37E-0CB929B40B77> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynami clinkui
           0x10d04f000 -        0x10d0befff +com.adobe.QT32Client.framework (6.0.1 - 6.0.1.0) <9BDE7CEB-F1BA-9029-2C0A-4C1BA410EBD1> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Clien t
           0x10d154000 -        0x10d180fff +com.adobe.amefoundation.framework (6.0.1 - 6.0.1.0) <00C0A690-4853-0851-8C9B-0A8229774F8C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefou ndation
           0x10d1c4000 -        0x10d1f5ff7 +com.adobe.ameproperties.framework (6.0.1 - 6.0.1.0) <99DFA94A-3E3E-3EA4-3CD2-C48136705979> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/ameproperties.framework/Versions/A/amepro perties
           0x10d241000 -        0x10d349ff7 +com.adobe.dvametadataDB.framework (6.0.1 - 6.0.1.14) <325841FC-A540-A655-AC44-48E2B43B9E18> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvamet adataDB
           0x10d3a7000 -        0x10d43bff7 +com.adobe.dvametadataUI.framework (6.0.1 - 6.0.1.14) <E02AFC3E-69AF-C4FD-7D69-57868851D6BF> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvamet adataUI
           0x10d511000 -        0x10d51fff7 +com.adobe.dvamarkerUI.framework (6.0.1 - 6.0.1.14) <9EF48DC6-6505-7758-3A6C-6153B12F3D14> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarke rUI
           0x10d542000 -        0x10d567fff +com.adobe.dvastoryparser.framework (6.0.1 - 6.0.1.14) <D423A71F-D27E-8DAF-13AE-C1BE1D44BFA2> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvast oryparser
           0x10d595000 -        0x10d5fbfff +com.adobe.DynamicLinkMedia.framework (6.0.1 - 6.0.1.0) <3E4FCDA0-8655-2CC0-70A0-557C5934B36E> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/Dyn amicLinkMedia
           0x10d6ac000 -        0x10d722fff +com.adobe.TimeWarpFilter.framework (6.0.1 - 6.0.1.0) <F904F4A4-5F26-B679-A000-67468864B981> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/TimeWarpFilter.framework/Versions/A/TimeW arpFilter
           0x10d795000 -        0x10d7d6fff +com.adobe.TransmitHost.framework (6.0.1 - 6.0.1.0) <51B3CE3C-B6FF-FF80-B09F-514000335518> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/TransmitHost.framework/Versions/A/Transmi tHost
           0x10d821000 -        0x10d873fef +com.adobe.DisplaySurface.framework (6.0.1 - 6.0.1.0) <422356EE-E1DD-7225-8291-F71428081589> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/Displ aySurface
           0x10d8da000 -        0x10d997fef +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <C735F37D-4D03-1648-4A2E-F94E65070BD0> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
           0x10d9bf000 -        0x10da94ff7 +com.adobe.GPUFoundation.framework (6.0.1 - 6.0.1.0) <F174C5A7-3000-9FD2-4BDF-B971C7AB26A3> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFou ndation
           0x10db2b000 -        0x10db53ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <9BDD08A8-2DD8-A570-7A7B-EDAA7097D61B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeB IBUtils
           0x10db5a000 -        0x10db60fff  com.apple.agl (3.2.0 - AGL-3.2.0) <AB0B5D3F-BA2A-3366-830A-EF9258C18276> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
           0x10db67000 -        0x10db83ff7 +com.adobe.AMEAppFoundation.framework (6.0.1 - 6.0.1.0) <7D8DFE26-C8CC-8332-6B56-2BC3CD3E6B7B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AME AppFoundation
           0x10dbb8000 -        0x10dbddfff +com.adobe.PostEncodeHost.framework (6.0.1 - 6.0.1.0) <BFBC0E2E-C01B-EEFD-BAC7-81451A4FF23C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostE ncodeHost
           0x10dc12000 -        0x10dc16ff7 +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346) <13D5CEF7-6090-CD66-8DA0-190771950F76> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
           0x10dc1c000 -        0x10dca9ff7 +com.adobe.PProDynamicLinkServer.framework (6.0.1 - 6.0.1.14) <DEF7998E-35C6-608E-8147-170841C876AB> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/ A/PProDynamicLinkServer
           0x10dda5000 -        0x10ddb2ff7 +com.adobe.dvamediaui.framework (6.0.1 - 6.0.1.14) <C48A5B20-A7B1-0593-DB72-59DB7CF6080E> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediau i
           0x10ddd7000 -        0x10dddefff +com.adobe.dvacaptioningui.framework (6.0.1 - 6.0.1.14) <B8DD1FE3-BD8F-4DC1-2B74-B6B1EAF065BE> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvac aptioningui
           0x10ddeb000 -        0x10de59fef +com.adobe.headlights.LogSessionFramework (??? - 2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSessio n
           0x10dead000 -        0x10deb3ff7 +com.adobe.AppServices.framework (6.0.1 - 6.0.1.0) <F933CD29-A411-E202-BA5F-6C7FD7B6D04A> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServi ces
           0x10eb45000 -        0x10eb4fff7 +com.adobe.ImporterPhotoshopProxy.framework (6.0.1 - 6.0.1.0) <96692747-D9B0-D7D8-2B42-5B065BA86E30> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterPhotoshopProxy.bundle/Conten ts/MacOS/ImporterPhotoshopProxy
           0x10eb83000 -        0x10ebb1ff7  GLRendererFloat (??? - ???) <E33704BC-AA25-3279-A585-ABC6B3176D3E> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat .bundle/GLRendererFloat
           0x10efc2000 -        0x10efc3ff7 +libcuda.dylib (4.2.10 - compatibility 1.1.0) <DEAD4D33-A552-A5DF-C21E-DC78BF9538A7> /usr/local/cuda/lib/libcuda.dylib
           0x10efeb000 -        0x10efedfff  com.apple.textencoding.unicode (2.4 - 2.4) <FD4695F4-6110-36C6-AC06-86453E30FF6E> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
           0x10eff2000 -        0x10eff8fef  libcldcpuengine.dylib (1.50.69 - compatibility 1.0.0) <303313AD-2D57-37A5-922B-3194C5DCD007> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine .dylib
           0x1109e4000 -        0x1109efff7 +CUDA (4.2.10 - compatibility 1.1.0) <FC7BE7EA-EE98-6705-1785-0889C80AED4A> /Library/Frameworks/CUDA.framework/Versions/A/CUDA
           0x1109f5000 -        0x1109f8ff7  libCoreFSCache.dylib (??? - ???) <70D5EB80-24F5-3837-9302-EBD4CFCE5CBA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreFSCache.dylib
           0x110c00000 -        0x110d99fff  GLEngine (??? - ???) <61484217-C41D-3A65-86BD-397ACC0D069F> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle /GLEngine
           0x110dcd000 -        0x110ec6fff  libGLProgrammability.dylib (??? - ???) <7396EE13-5FA6-3E78-88D0-2502CFE79A97> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LProgrammability.dylib
           0x110fd7000 -        0x110fd9fff +com.adobe.Opacity.framework (6.0.1 - 6.0.1.0) <2788148E-0FAD-6661-1A50-1A435962B4F9> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/Opacity.bundle/Contents/MacOS/Opacit y
           0x110fdf000 -        0x110fdfff7 +com.adobe.PProAEFilter.Mosaic (??? - 1.0) <C70B1E03-30AA-C556-41C8-CE4957E678B2> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/Mosaic.bundle/Contents/MacOS/Mosaic
           0x110ff5000 -        0x110ff7fff +com.adobe.Motion.framework (6.0.1 - 6.0.1.0) <9E8D9CBC-133A-4609-D7DA-E60294D2927E> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/Motion.bundle/Contents/MacOS/Motion
           0x1138a8000 -        0x1138acfff  com.apple.audio.AudioIPCPlugIn (1.2.2 - 1.2.2) <D4D40031-05D5-3D8B-A9A5-490D9483E188> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/Aud ioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
           0x1138b1000 -        0x1138b6fff  com.apple.audio.AppleHDAHALPlugIn (2.2.0 - 2.2.0f3) <4EC4981B-68AE-357E-960F-3D4603A61E9F> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHAL PlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
           0x1138d8000 -        0x1138d8ff5 +cl_kernels (??? - ???) <237A3C5B-A058-4D99-9EE7-0906659B393D> cl_kernels
           0x113ff1000 -        0x113ff3fff +com.adobe.TransmitDesktopAudio.framework (6.0.1 - 6.0.1.0) <AEF2558D-C4F1-18C3-2239-0FCE5D8E92DC> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/TransmitDesktopAudio.bundle/Contents /MacOS/TransmitDesktopAudio
           0x114d69000 -        0x114d69ffd +cl_kernels (??? - ???) <E57AEE95-ABDC-4EB7-A712-DC15F35D90C8> cl_kernels
           0x114d6c000 -        0x114d75ff7 +libMXF_SDK_GenericContainer_AES3.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_AES3.dylib.4.4.3
           0x116ac7000 -        0x116bffff7 +libcuda_270.05.25.dylib (4.2.10 - 4.2.10) <B0EE565B-EAC1-3E8E-09FC-610B4F895946> /Library/Frameworks/CUDA.framework/Versions/A/Libraries/libcuda_270.0 5.25.dylib
           0x116cdb000 -        0x116ce0fff +com.adobe.TransmitFullScreen.framework (6.0.1 - 6.0.1.0) <4B9618E8-C6E7-AADB-CF93-604705E7B7A0> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/TransmitFullScreen.bundle/Contents/M acOS/TransmitFullScreen
           0x116cf9000 -        0x117455fef +libgpgpucomp.dylib (??? - ???) <14C54128-9AA4-A717-27FD-86F2ECB45BFD> /Library/Frameworks/CUDA.framework/Versions/A/Libraries/libgpgpucomp. dylib
           0x1182dc000 -        0x1182e2fff +libMXF_SDK_GenericContainer_AVI.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_AVI.dylib.4.4.3
           0x118564000 -        0x118565ffc +cl_kernels (??? - ???) <DC153B9C-5ED2-419E-83DB-AFD343E95F41> cl_kernels
           0x118582000 -        0x1185fcfef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
           0x11868e000 -        0x1186b4ff7 +com.adobe.ape (3.3.8.19346 - 3.3.8.19346) <79E11A18-8AF4-2515-59F7-4CBE161BF020> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
           0x1186c6000 -        0x1186c8ff7 +com.adobe.ImporterColorMatte.framework (6.0.1 - 6.0.1.0) <76F3AD05-D88A-077D-8AB4-5797F6BD4D50> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterColorMatte.bundle/Contents/M acOS/ImporterColorMatte
           0x1186cf000 -        0x1186d1fff +com.adobe.PProAEFilter.Fast_Blur (??? - 1.0) <81A46E2E-4442-21BD-929D-54C12C1A064B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/Fast_Blur.bundle/Contents/MacOS/Fast _Blur
           0x1186e8000 -        0x1186ebfe7 +com.adobe.AEFilterGarbageMatte8.framework (6.0.1 - 6.0.1.0) <536BF881-46E9-A3E3-AB41-1F5624474AF0> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/AEFilterGarbageMatte8.bundle/Content s/MacOS/AEFilterGarbageMatte8
           0x11870a000 -        0x11870efe7 +com.adobe.AEFilterTrackMatteKey.framework (6.0.1 - 6.0.1.0) <E8646567-1B81-E839-02AF-9447781545AC> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/AEFilterTrackMatteKey.bundle/Content s/MacOS/AEFilterTrackMatteKey
           0x118738000 -        0x11873eff7 +com.adobe.AEFilterColorFast.framework (6.0.1 - 6.0.1.0) <CCF330A4-D222-E6F9-9FB1-5AC74969A229> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/AEFilterColorFast.bundle/Contents/Ma cOS/AEFilterColorFast
           0x118749000 -        0x118774fff +ServiceManager-Launcher.dylib (389.0.0 - compatibility 2.5.0) <7AE35754-3413-206D-4B92-579AAA25B4F8> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
           0x118805000 -        0x118809ff7 +com.adobe.PProAEFilter.Change_Color (??? - 1.0) <37DE0D73-74E6-BB7D-EA8C-43AF9D1B7272> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/Change_Color.bundle/Contents/MacOS/C hange_Color
           0x1189b9000 -        0x1189beff7 +com.adobe.AEFilterCrop.framework (6.0.1 - 6.0.1.0) <000D3C22-045E-D846-2698-886CDAF84A40> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/AEFilterCrop.bundle/Contents/MacOS/A EFilterCrop
           0x1189c5000 -        0x1189c8fff +com.adobe.AEFilterLumaKey.framework (6.0.1 - 6.0.1.0) <B2A7F6D8-2AA6-A8BF-A81F-ED3BB8B5879F> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/AEFilterLumaKey.bundle/Contents/MacO S/AEFilterLumaKey
           0x1189f0000 -        0x1189f9fff +libMXF_SDK_GenericContainer_MPEG_MPEGPS.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MPEGPS.dylib.4.4.3
           0x11918f000 -        0x11919dfef +com.adobe.PremiereFiltersMetaPlugin.framework (6.0.1 - 6.0.1.0) <9297F96F-7F8A-AF6B-6E63-BD674B7BAA38> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Conte nts/MacOS/PremiereFiltersMetaPlugin
           0x1191ee000 -        0x1191f3ff7 +com.adobe.ExporterCoreAudio.framework (6.0.1 - 6.0.1.0) <AEBD2119-EDB0-BCA4-B4ED-ADC519BB9571> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ExporterCoreAudio.bundle/Contents/Ma cOS/ExporterCoreAudio
           0x119383000 -        0x1193a3fff +com.adobe.VXMLPresetReader.framework (6.0.1 - 6.0.1.0) <D7AAB21A-2CFC-0A51-3947-4BFBA438C544> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/VXMLPresetReader.framework/VXMLPresetRead er
           0x119581000 -        0x119592ff7 +com.adobe.TransitionsMetaPlugin.framework (6.0.1 - 6.0.1.0) <E5FD298F-A375-F7E9-8EA0-672F4CB8EAFE> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/ MacOS/TransitionsMetaPlugin
           0x1195a3000 -        0x1195b7fef +com.adobe.TransmitDV.framework (6.0.1 - 6.0.1.0) <AD1473BB-7A3B-C3B7-FD58-1261DDC6D8AA> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/TransmitDV.bundle/Contents/MacOS/Tra nsmitDV
           0x1195d0000 -        0x1195deff7 +com.adobe.AudioConverter.framework (6.0.1 - 6.0.1.0) <2BBD19FC-D3DC-0FF7-94D8-A8C80BF10DB8> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AudioConverter.framework/Versions/A/Audio Converter
           0x11d215000 -        0x11d22afff +com.adobe.MXFHandler.framework (6.0.1 - 6.0.1.0) <3A037703-0DE3-4662-2720-134343DDBA7E> /Library/Application Support/Adobe/*/MXFHandler
           0x11d2c8000 -        0x11d2cdfff +libMXF_SDK_Modules_DataIO.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_Modules_Da taIO.dylib.1.3.3
           0x11d2d9000 -        0x11d2daff3 +cl_kernels (??? - ???) <31546952-0F56-427F-B8F5-75B45D91B60F> cl_kernels
           0x11d35f000 -        0x11d365fe7 +com.adobe.ImporterTiff.framework (6.0.1 - 6.0.1.0) <C44BF25B-6561-DA21-220C-898357975D4C> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterTiff.bundle/Contents/MacOS/I mporterTiff
           0x11d36c000 -        0x11d370ff7 +com.adobe.ImporterAiff.framework (6.0.1 - 6.0.1.0) <A4517395-E01B-1F87-5144-2CE2611A66F7> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterAiff.bundle/Contents/MacOS/I mporterAiff
           0x11d3a8000 -        0x11d3aefff +libMXF_SDK_GenericContainer_Binary.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_Binary.dylib.1.3.3
           0x11d420000 -        0x11d431fff +com.adobe.ExporterMPEGPreview.framework (6.0.1 - 6.0.1.0) <B0292221-112F-8083-BCD6-5C55DD645B69> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/ MacOS/ExporterMPEGPreview
           0x11d443000 -        0x11d44dfff +libMXF_SDK_GenericContainer_AES3_S302M.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_AES3_S302M.dylib.4.4.3
           0x11d457000 -        0x11d49dfff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A /UpdaterNotifications
           0x11d4e8000 -        0x11d4f4ff7 +libMXF_SDK_GenericContainer_D10.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_D10.dylib.4.4.3
           0x11e133000 -        0x11e13dfe7 +libMXF_SDK_GenericContainer_MPEG_ESAudio.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_ESAudio.dylib.4.4.3
           0x11e1e9000 -        0x11e1f8ffd +com.mainconcept.mc.enc.mpa (9.1 - 9.1.6.7339) <F18E0114-7877-9C34-39D4-4421D8F16278> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/9/mc_enc_mp a
           0x11e2dd000 -        0x11e2f7fef +libMXF_SDK_GenericContainer_DV.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_DV.dylib.4.4.3
           0x11e37b000 -        0x11e386fff +libMXF_SDK_GenericContainer_MPEG_MPEGTS.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MPEGTS.dylib.4.4.3
           0x11e3ed000 -        0x11e3fbfff +libMXF_SDK_GenericContainer_JPEG2000.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_JPEG2000.dylib.4.4.3
           0x11e407000 -        0x11e417fff +libMXF_SDK_GenericContainer_MPEG_MPEG2Video.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MPEG2Video.dylib.4.4.3
           0x11e4d4000 -        0x11e4e7ff7 +libMXF_SDK_GenericContainer_MPEG_MPEG4.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MPEG4.dylib.4.4.3
           0x11e555000 -        0x11e55efff +libMXF_SDK_GenericContainer_SystemScheme1.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_SystemScheme1.dylib.4.4.3
           0x11e98c000 -        0x11e9a6fe7 +com.adobe.ImporterJPEG.framework (6.0.1 - 6.0.1.0) <2BEB6D38-C14C-6EE7-1AE5-814FAE9B8387> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterJPEG.bundle/Contents/MacOS/I mporterJPEG
           0x11ecc1000 -        0x11ecccfff +libMXF_SDK_Metadata_RP224.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_Metadata_R P224.dylib.4.4.3
           0x11f0a5000 -        0x11f0b6fff +libMXF_SDK_GenericContainer_Wave.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_Wave.dylib.4.4.3
           0x11f5b2000 -        0x11f5beffa +libMXF_SDK_XMLUtils.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_XMLUtils.d ylib.4.4.3
           0x11f6d2000 -        0x11f6e6ff7 +com.adobe.QTParser.framework (6.0.1 - 6.0.1.0) <78B14B51-A202-C6F7-0561-D57BC49769B7> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
           0x11f912000 -        0x11f923ff7 +libMXF_SDK_MetaMetadata_BinaryLoader.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetada ta_BinaryLoader.dylib.4.4.3
           0x11f933000 -        0x11f942ff7 +libMXF_SDK_GenericContainer_AIFF.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_AIFF.dylib.1.3.3
           0x11fb5a000 -        0x11fb72ffb +libMXF_SDK_MetaMetadata_XSDLoader.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetada ta_XSDLoader.dylib.4.4.3
           0x120bba000 -        0x120bf2ff7 +libMOG_Framework.dylib.2.2.4 (??? - ???) <7A97623B-F09F-CA33-B9EA-1202FA569605> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMOG_Framework.dyli b.2.2.4
           0x120c11000 -        0x120c1dfff +libMXF_SDK_GenericContainer_Blind.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_Blind.dylib.1.3.3
           0x120cb4000 -        0x120cd6ff8 +libMXF_SDK_MetaMetadata_XSDLoader2.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_MetaMetada ta_XSDLoader2.dylib.4.4.3
           0x1213e4000 -        0x1213f2fff +libMXF_SDK_GenericContainer_MPEG_MP4.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_MP4.dylib.1.3.3
           0x121634000 -        0x121661ff8 +libMXF_SDK_GenericContainer_MPEG_AVC.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_MPEG_AVC.dylib.1.3.3
           0x1216da000 -        0x1216e8fff +libMXF_SDK_GenericContainer_VC3.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_GenericCon tainer_VC3.dylib.1.3.3
           0x121b93000 -        0x121bc0fff +com.adobe.ExporterQuickTimeHost.framework (6.0.1 - 6.0.1.0) <B4A189BB-8FAC-C2EF-0F6B-75CA13E4CFEA> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Content s/MacOS/ExporterQuickTimeHost
           0x1226e4000 -        0x12271aff7  com.apple.AVCVideoServices (1.0 - 42) <0FE92F5F-0B45-B50D-139C-493FD47930CB> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVC VideoServices
           0x123a67000 -        0x123ac8ff7 +com.adobe.PlayerMediaCore.framework (6.0.1 - 6.0.1.0) <EE65A166-BFD4-CC8D-CE3B-13B1C55B2177> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacO S/PlayerMediaCore
           0x123b3d000 -        0x123b73fef +com.adobe.RendererCPU.framework (6.0.1 - 6.0.1.0) <168768CD-A73D-193C-6F62-BA876FD7B369> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/RendererCPU.framework/Versions/A/Renderer CPU
           0x123baf000 -        0x123d5cfef +com.adobe.RendererGPU.framework (6.0.1 - 6.0.1.0) <888410E2-5581-2109-17F9-0CBD482A8FDF> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/RendererGPU.framework/Versions/A/Renderer GPU
           0x123e43000 -        0x124024ff7  com.apple.audio.codecs.Components (2.2 - 2.2) <1DF409FA-F561-31C5-900A-42F41B2C1856> /System/Library/Components/AudioCodecs.component/Contents/MacOS/Audio Codecs
           0x124200000 -        0x124242fff +com.adobe.ImporterQuickTime.framework (6.0.1 - 6.0.1.0) <0C07C0DE-CF49-6539-8175-B32BA6F1ABA6> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterQuickTime.bundle/Contents/Ma cOS/ImporterQuickTime
           0x12428d000 -        0x124331fe7 +com.adobe.IPPMPEGDecoder.framework (6.0.1 - 6.0.1.0) <F364AC8F-9FFD-EDEE-4B4B-DF54E6BECA3B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMP EGDecoder
           0x12436f000 -        0x12457dfff +com.aja.RecordAJADpx (1.0 - 1.0) <EB34EDB6-B040-F288-2DBD-A6E31419BC12> /Library/Application Support/Adobe/*/RecordAJADpx.bundle/Contents/MacOS/RecordAJADpx
           0x12470f000 -        0x12491dfff +com.aja.RecordAJAMov (1.0 - 1.0) <08819175-3D5D-0293-2BCD-D01A0EBDBE59> /Library/Application Support/Adobe/*/RecordAJAMov.bundle/Contents/MacOS/RecordAJAMov
           0x124aaf000 -        0x124c57ff7 +com.aja.TransmitAJA (1.0 - 1.0) <D17EDC86-C88E-A966-E32D-8F245AFE543D> /Library/Application Support/Adobe/*/TransmitAJA.bundle/Contents/MacOS/TransmitAJA
           0x12630d000 -        0x12633eff3 +libMXF_SDK_XMLBuilder.dylib.1.3.3 (1.3.3 - compatibility 1.3.3) <73E5E3AE-A51C-D3F8-B036-433778DB90BD> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK_XMLBuilder .dylib.1.3.3
           0x126716000 -        0x126717fff +com.adobe.PProAEFilter.Bevel_Edges (??? - 1.0) <5E4AECC7-BC97-14B6-F05D-D7B7AB20FF25> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/Bevel_Edges.bundle/Contents/MacOS/Be vel_Edges
           0x1335d4000 -        0x1335d9fff +com.adobe.PProAEFilter.Twirl (??? - 1.0) <8061A847-CB91-9A3E-CE0C-0D52EECC6A01> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/Twirl.bundle/Contents/MacOS/Twirl
           0x13ec47000 -        0x13ec4eff7 +com.adobe.ImporterWave.framework (6.0.1 - 6.0.1.0) <118EBA39-733D-E6D9-3AE0-1C864A310904> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterWave.bundle/Contents/MacOS/I mporterWave
           0x13fc08000 -        0x13fc4efe7 +com.adobe.pip (??? - 6.0.0.1654) <3576D8F9-E2F9-6EB8-6684-C2FE6B0A3731> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
           0x14e9e4000 -        0x14ea77ff7  unorm8_bgra.dylib (1.50.69 - compatibility 1.0.0) <5FB796A4-1AD0-3B4D-AA83-F8A46E039224> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/un orm8_bgra.dylib
           0x1539de000 -        0x153a30ff7 +com.adobe.ImporterMPEG.framework (6.0.1 - 6.0.1.0) <F302604C-DD2C-0CA9-5386-BD704C4996C3> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterMPEG.bundle/Contents/MacOS/I mporterMPEG
           0x156302000 -        0x156395ff7  unorm8_argb.dylib (1.50.69 - compatibility 1.0.0) <62C3F70B-9B04-39BD-BE29-582A1DE89A90> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/un orm8_argb.dylib
           0x160377000 -        0x160429fe3 +com.mainconcept.mc.mfimport (9.1 - 9.1.6.7339) <CD59C8E3-4EB4-C35D-599A-DC92B2D84E50> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/mc_mfimport.framework/Versions/9/mc_mfimp ort
           0x162e7c000 -        0x162eacff7 +com.adobe.ImporterMP3.framework (6.0.1 - 6.0.1.0) <DEA6DF6D-F0A4-727A-E00B-1B34696EA611> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterMP3.bundle/Contents/MacOS/Im porterMP3
           0x16923b000 -        0x1692a6fef +com.adobe.AVCIntraDecoder.framework (6.0.1 - 6.0.1.0) <ABF193DB-53D9-02F2-4887-621CA4B21F74> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/AVCIntraDecoder.framework/Versions/A/AVCI ntraDecoder
           0x170521000 -        0x1705d7fe3 +com.mainconcept.mc.mux.mp2 (9.1 - 9.1.6.7339) <044A2A73-237E-1E1B-F879-B1AE42814501> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/9/mc_mux_mp 2
           0x17b7e4000 -        0x17b806fff +com.adobe.ImporterFastMPEG.framework (6.0.1 - 6.0.1.0) <B3CF885E-FCBB-803D-B967-EF1F5702D9B1> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterFastMPEG.bundle/Contents/Mac OS/ImporterFastMPEG
           0x1801e4000 -        0x180da1fff +com.adobe.PProAEFilter.Stabilizer (??? - 1.0) <967B7E75-18B4-5C2F-2195-8AB7EC50C6FD> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/Stabilizer.bundle/Contents/MacOS/Sta bilizer
           0x1c0014000 -        0x1c011cfef +com.mainconcept.mc.enc.mp2v (9.1 - 9.1.6.7339) <B02A0C50-AB7E-B512-52D7-2BDB1C1573C2> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/9/mc_enc_m p2v
           0x1c0229000 -        0x1c0331ff7 +com.adobe.ExporterP2.framework (6.0.1 - 6.0.1.0) <13BA4269-C485-260A-C539-A9E1DB490A69> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ExporterP2.bundle/Contents/MacOS/Exp orterP2
           0x1cd71e000 -        0x1cd788fff +com.adobe.ImporterP2.framework (6.0.1 - 6.0.1.0) <BFB86DBD-72AC-5EF2-A3B2-6602FEB4060B> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterP2.bundle/Contents/MacOS/Imp orterP2
           0x200000000 -        0x2007e6fff  com.apple.GeForceGLDriver (7.18.18 - 7.1.8) <B1C5CF64-DB24-31CC-95D6-5F81E7244435> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeFo rceGLDriver
           0x232c5a000 -        0x232e46fef +libMXF_SDK.dylib.4.4.3 (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libMXF_SDK.dylib.4.4. 3
           0x24262a000 -        0x2428f6ff6 +libxerces-c-3.0.dylib (??? - ???) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libxerces-c-3.0.dylib
           0x253000000 -        0x2533d5fef +libxqilla.5.dylib (6.0.0 - compatibility 6.0.0) /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-ins/Common/MOG/Frameworks/libxqilla.5.dylib
           0x2f9600000 -        0x2f9815ff7 +com.aja.DeviceAJASerial (1.0 - 1.0) <5AF3EB39-2CA0-69D7-BCFA-B05D8892A5F6> /Library/Application Support/Adobe/*/DeviceAJASerial.bundle/Contents/MacOS/DeviceAJASerial
           0x931a00000 -        0x931a9fff7 +com.adobe.ImporterXDCAMHD.framework (6.0.1 - 6.0.1.0) <9BF4BAC9-7225-BEA4-41E4-7CD42DE12755> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Plug-Ins/Common/ImporterXDCAMHD.bundle/Contents/MacO S/ImporterXDCAMHD
           0x931b38000 -        0x931cecfe7 +com.mainconcept.mc.dec.mp2v (9.1 - 9.1.6.7339) <FEDF523A-E855-CAB6-8AE2-579CFF7DEE54> /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/9/mc_dec_m p2v
        0x7fff6e3f3000 -     0x7fff6e427baf  dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
        0x7fff8c3f8000 -     0x7fff8c3f8fff  com.apple.vecLib (3.7 - vecLib 3.7) <9A58105C-B36E-35B5-812C-4ED693F2618F> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
        0x7fff8c446000 -     0x7fff8c44cfff  libmacho.dylib (800.0.0 - compatibility 1.0.0) <165514D7-1BFA-38EF-A151-676DCD21FB64> /usr/lib/system/libmacho.dylib
        0x7fff8c476000 -     0x7fff8c578fff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <AFBB22B7-07AE-3F2E-B88C-70BEEBFB8A86> /usr/lib/libxml2.2.dylib
        0x7fff8c57b000 -     0x7fff8c58fff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/LangAnalysis.framework/Versions/A/LangAnalysis
        0x7fff8c590000 -     0x7fff8c5c0ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <3FC86118-7553-38F7-8916-B329D2E94476> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/DictionaryServices.framework/Versions/A/DictionaryServices
        0x7fff8c5c1000 -     0x7fff8c8e5fff  com.apple.AddressBook.framework (6.1.2 - 1090) <65FE6A36-F3F8-37FE-8B88-50F20F278779> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBo ok
        0x7fff8c8e6000 -     0x7fff8c8e9fff  com.apple.help (1.3.2 - 42) <BF14DE49-F7E8-336F-81FB-BBDF2DB3AC09> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Hel p.framework/Versions/A/Help
        0x7fff8c944000 -     0x7fff8c971fff  com.apple.quartzfilters (1.7.0 - 1.7.0) <CE1EDD58-7273-38F9-AD33-871A8BA7ABF3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzFilters.framework/Versions/A/QuartzFilters
        0x7fff8c972000 -     0x7fff8c97dff7  com.apple.DisplayServicesFW (2.5.4 - 323.3) <5E7F7A88-9313-3C31-87BD-80F3361DA338> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/ A/DisplayServices
        0x7fff8c9c7000 -     0x7fff8c9c7fff  com.apple.Cocoa (6.6 - ???) <7EC4D759-B2A6-3A99-AC75-809FED1500C6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
        0x7fff8d244000 -     0x7fff8d245fff  libdnsinfo.dylib (395.11.0 - compatibility 1.0.0) <853BAAA5-270F-3FDC-B025-D448DB72E1C3> /usr/lib/system/libdnsinfo.dylib
        0x7fff8d246000 -     0x7fff8d599fff  com.apple.FinderKit (1.0.3 - 1.0.3) <D0BF82AD-69D6-3190-804C-6CF061BA22EF> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/Find erKit
        0x7fff8d59a000 -     0x7fff8d610fff  com.apple.CoreSymbolication (2.2 - 73.2) <126415E3-3A35-315B-B4B7-507CDBED0D58> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Version s/A/CoreSymbolication
        0x7fff8d611000 -     0x7fff8d64ffff  com.apple.bom (11.0 - 183) <F300B9EC-995E-33A7-9175-9F07D4B68F16> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
        0x7fff8d650000 -     0x7fff8d7a9fff  com.apple.audio.toolbox.AudioToolbox (1.7.2 - 1.7.2) <0AD8197C-1BA9-30CD-98F1-4CA2C6559BA8> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToo lbox
        0x7fff8d7c9000 -     0x7fff8d7edfff  com.apple.Kerberos (1.0 - 1) <1F826BCE-DA8F-381D-9C4C-A36AA0EA1CB9> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
        0x7fff8d84b000 -     0x7fff8d859fff  com.apple.NetAuth (3.2 - 3.2) <F0D60E34-37A9-308D-B44E-E3450906173A> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAut h
        0x7fff8d85a000 -     0x7fff8d8aefff  libFontRegistry.dylib (??? - ???) <822DD341-C735-36C9-9521-E8E98807D09D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
        0x7fff8d8af000 -     0x7fff8d8d5fff  com.apple.framework.familycontrols (3.0 - 300) <93828BC1-3D83-3A93-99A5-F0E7951AFC6C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A /FamilyControls
        0x7fff8d8d6000 -     0x7fff8d8e8ff7  libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
        0x7fff8d8e9000 -     0x7fff8d929ff7  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <5328C0AB-F169-3786-A3EC-9E82E960CAAF> /usr/lib/libcups.2.dylib
        0x7fff8d92a000 -     0x7fff8d93ffff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <C061ECBB-7061-3A43-8A18-90633F943295> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
        0x7fff8e707000 -     0x7fff8e70eff7  com.apple.CommerceCore (1.0 - 17) <3894FE48-EDCE-30E9-9796-E2F959D92704> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Fr ameworks/CommerceCore.framework/Versions/A/CommerceCore
        0x7fff8e70f000 -     0x7fff8e725ff7  com.apple.ImageCapture (7.0.1 - 7.0.1) <BF4EC1CC-C998-3529-A69F-765774C66A6F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ima geCapture.framework/Versions/A/ImageCapture
        0x7fff8e7ee000 -     0x7fff8f18bc9f  com.apple.CoreGraphics (1.600.0 - ???) <1DB9C92C-DFA8-36ED-B513-998134462148> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/CoreGraphics
        0x7fff8f18c000 -     0x7fff8f2c2fff  com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vImage.framework/Versions/A/vImage
        0x7fff8f2c3000 -     0x7fff8f30fff7  com.apple.SystemConfiguration (1.11.3 - 1.11) <0A7F1982-B4EA-3424-A0C7-FE46C6224F03> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/S ystemConfiguration
        0x7fff8f310000 -     0x7fff8f4afff7  com.apple.QuartzCore (1.7 - 270.4) <97E20A5F-652B-3E85-8C46-DCB777248ECD> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
        0x7fff8f4c5000 -     0x7fff8f507ff7  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <BB770C22-8C57-365A-8716-4A3C36AE7BFB> /usr/lib/system/libcommonCrypto.dylib
        0x7fff8f508000 -     0x7fff8f56aff7  com.apple.Symbolication (1.3 - 91) <B072970E-9EC1-3495-A1FA-D344C6E74A13> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/ Symbolication
        0x7fff8f5e0000 -     0x7fff8f63aff7  com.apple.ImageCaptureCore (3.0.3 - 3.0.3) <12C722EE-3A13-3937-ABDF-EDC922F4C299> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/Imag eCaptureCore
        0x7fff8f63b000 -     0x7fff8f668ff7  com.apple.opencl (1.50.69 - 1.50.69) <57939F7D-3626-30E2-883D-8A7CCB3F8763> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
        0x7fff8f669000 -     0x7fff8f70efff  com.apple.ink.framework (1.4 - 110) <F93B76B3-E57C-3805-B20D-03717A3F91DD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink .framework/Versions/A/Ink
        0x7fff8f70f000 -     0x7fff8f71dff7  com.apple.AppleFSCompression (37 - 1.0) <8981D804-EBFE-35D5-9F79-6689DCCBA43A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versio ns/A/AppleFSCompression
        0x7fff8f908000 -     0x7fff8f95ffff  com.apple.Suggestions (1.1 - 85.1) <DE511C42-D2F2-309C-80EE-53862245DE22> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Su ggestions
        0x7fff8f960000 -     0x7fff8f9e5ff7  com.apple.Heimdal (2.2 - 2.0) <FF0BD9A4-6FB0-31E3-ABFB-563FBBEC45FC> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimda l
        0x7fff8f9e6000 -     0x7fff8f9f1ff7  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
        0x7fff8f9f2000 -     0x7fff8ffd6fff  libBLAS.dylib (??? - ???) <C34F6D88-187F-33DC-8A68-C0C9D1FA36DF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libBLAS.dylib
        0x7fff8ffd7000 -     0x7fff8ffdbfff  libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <2B1215A0-1B43-39C3-B4F4-392D71D08FFA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dy l ib
        0x7fff8ffe4000 -     0x7fff90017ff7  com.apple.GSS (2.2 - 2.0) <971395D0-B9D0-3FDE-B23F-6F9D0A2FB95F> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
        0x7fff90018000 -     0x7fff9001cfff  libdyld.dylib (195.6.0 - compatibility 1.0.0) <FFC59565-64BD-3B37-90A4-E2C3A422CFC1> /usr/lib/system/libdyld.dylib
        0x7fff9001d000 -     0x7fff903c6fef  com.apple.MediaToolbox (1.0 - 705.78) <A4DF8258-0CB9-3244-BF12-3AD02B1952B0> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/M ediaToolbox
        0x7fff9063e000 -     0x7fff90684fff  libcurl.4.dylib (7.0.0 - compatibility 7.0.0) <2C442396-1006-3765-92D2-60869D4641CE> /usr/lib/libcurl.4.dylib
        0x7fff90685000 -     0x7fff906b0ff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <E71220D3-8015-38EC-B97D-7FDB383C2BDC> /usr/lib/libxslt.1.dylib
        0x7fff90705000 -     0x7fff90706ff7  libremovefile.dylib (21.1.0 - compatibility 1.0.0) <739E6C83-AA52-3C6C-A680-B37FE2888A04> /usr/lib/system/libremovefile.dylib
        0x7fff90707000 -     0x7fff90975ff7  com.apple.QuartzComposer (5.0 - 236.7) <D556126B-3D67-3E37-82E0-D06532DE0C89> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qua rtzComposer.framework/Versions/A/QuartzComposer
        0x7fff90976000 -     0x7fff90a08ff7  com.apple.CorePDF (3.1 - 3.1) <F81F99A9-7FF6-3A6A-92C7-78C76BA35777> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePD F
        0x7fff90a09000 -     0x7fff90a18ff7  libxar-nossl.dylib (??? - ???) <A6ABBFB9-E4ED-38AD-BBBB-F9958B9CEFB5> /usr/lib/libxar-nossl.dylib
        0x7fff90a43000 -     0x7fff90a50fff  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <528BAA66-C38C-3093-84B5-92A7832CE7BC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dyli b
        0x7fff90a51000 -     0x7fff90a6dff7  com.apple.GenerationalStorage (1.0 - 126.1) <509F52ED-E54B-3FEF-B3C2-759387B826E6> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versi ons/A/GenerationalStorage
        0x7fff90a6e000 -     0x7fff90a8bff7  com.apple.openscripting (1.3.3 - ???) <BDCCCBA9-F440-30BD-8378-FAB5AF685A5D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ope nScripting.framework/Versions/A/OpenScripting
        0x7fff90a8c000 -     0x7fff90a8ffff  libRadiance.dylib (??? - ???) <CD89D70D-F177-3BAE-8A26-644EA7D5E28E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
        0x7fff90a90000 -     0x7fff90a95ff7  libsystem_network.dylib (??? - ???) <5DE7024E-1D2D-34A2-80F4-08326331A75B> /usr/lib/system/libsystem_network.dylib
        0x7fff90af8000 -     0x7fff90bedfff  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
        0x7fff90c41000 -     0x7fff90c45ff7  com.apple.CommonPanels (1.2.5 - 94) <37C6540B-F8D1-355A-806C-F93D8FB522AB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Com monPanels.framework/Versions/A/CommonPanels
        0x7fff90c46000 -     0x7fff90c98ff7  libGLU.dylib (??? - ???) <E2EF0336-3A5F-3532-AEB0-6CCF04851B72> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LU.dylib
        0x7fff90c99000 -     0x7fff90d3bfff  com.apple.securityfoundation (5.0 - 55116) <A9311EF6-B7F7-3DA5-84E8-21BC9B2C3C69> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/Se curityFoundation
        0x7fff90d3c000 -     0x7fff90d6bfff  com.apple.shortcut (2.1 - 2.1) <43C186C0-6B0F-39FA-976A-C307CC410495> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Short cut
        0x7fff90d6c000 -     0x7fff90de2fff  com.apple.ISSupport (1.9.8 - 56) <2BEEF162-893F-356C-BD4E-8668F044A917> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSu pport
        0x7fff90df5000 -     0x7fff90e08ff7  libCRFSuite.dylib (??? - ???) <0B76941F-218E-30C8-B6DE-E15919F8DBEB> /usr/lib/libCRFSuite.dylib
        0x7fff90e09000 -     0x7fff90e0bfff  libCVMSPluginSupport.dylib (??? - ???) <1C73D331-6F6C-3872-A011-1C41FBF49F2A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC VMSPluginSupport.dylib
        0x7fff90e0c000 -     0x7fff90e7cfff  com.apple.datadetectorscore (3.0 - 179.4) <9C01D16F-75A9-3BDD-B91A-F0F32261A2E7> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Version s/A/DataDetectorsCore
        0x7fff90ef2000 -     0x7fff90f2dfff  libsystem_info.dylib (??? - ???) <35F90252-2AE1-32C5-8D34-782C614D9639> /usr/lib/system/libsystem_info.dylib
        0x7fff90f38000 -     0x7fff90f89ff7  com.apple.CoreMediaIO (212.0 - 3199.1.1) <D8C364AF-A1E8-3215-ABF5-188B50A80B18> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMedia IO
        0x7fff90f8a000 -     0x7fff91114fff  com.apple.QTKit (7.7.1 - 2330) <4B5363D4-4854-342F-8B95-DE6559075B46> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
        0x7fff91115000 -     0x7fff9112ffff  com.apple.CoreMediaAuthoring (2.0 - 891) <C7A92C52-AD9F-3CF1-86D5-C0714118935C> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versio ns/A/CoreMediaAuthoring
        0x7fff91130000 -     0x7fff91150fff  libsystem_kernel.dylib (1699.26.8 - compatibility 1.0.0) <1DDC0B0F-DB2A-34D6-895D-E5B2B5618946> /usr/lib/system/libsystem_kernel.dylib
        0x7fff91151000 -     0x7fff91154fff  com.apple.AppleSystemInfo (1.0 - 1) <111B6F69-3FBD-3860-BCF8-1DF02D9BED28> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/ A/AppleSystemInfo
        0x7fff91155000 -     0x7fff9115afff  libGIF.dylib (??? - ???) <8763F67F-A881-30B6-B20E-D395B4D9FD58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
        0x7fff911c3000 -     0x7fff91207ff7  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <22B2A10A-34B5-3787-88C9-B2722FE79504> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
        0x7fff91208000 -     0x7fff91256fff  libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
        0x7fff9125e000 -     0x7fff9129ffff  com.apple.QD (3.40 - ???) <47674D2C-BE88-388E-B1B0-03F08BFFE5FD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/QD.framework/Versions/A/QD
        0x7fff912a0000 -     0x7fff9130bff7  com.apple.framework.IOKit (2.0 - ???) <6C604894-7F61-3130-8499-20791D14577F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
        0x7fff9132c000 -     0x7fff91500ff7  com.apple.CoreFoundation (6.7.2 - 635.21) <62A3402E-A4E7-391F-AD20-1EF20236CE1B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFo undation
        0x7fff9150f000 -     0x7fff9151dfff  com.apple.HelpData (2.1.2 - 72.2) <363E36C5-F7C0-34A6-83D3-97C8FB6511F0> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpD ata
        0x7fff9151e000 -     0x7fff9193bff7  com.apple.SceneKit (125.3 - 125.4) <12AD6DBE-F3A3-34D6-BA01-B211BEAFD48F> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/Scene Kit
        0x7fff9193c000 -     0x7fff9197cfff  libtidy.A.dylib (??? - ???) <E500CDB9-C010-3B1A-B995-774EE64F39BE> /usr/lib/libtidy.A.dylib
        0x7fff91a2f000 -     0x7fff91a73ff7  com.apple.MediaKit (12 - 602) <0C2CBEDA-412F-3DDF-9C74-44114E5E0DB9> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/Media Kit
        0x7fff91a74000 -     0x7fff91abbff7  com.apple.CoreMedia (1.0 - 705.78) <F6EA2328-FD3E-3057-80C7-C9845837F863> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
        0x7fff91abc000 -     0x7fff91b9bff7  com.apple.ImageIO.framework (3.1.2 - 3.1.2) <FFA7532B-336A-3F0B-9AB9-2A35B56ED887> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/ImageIO
        0x7fff91b9c000 -     0x7fff91bbcfff  libPng.dylib (??? - ???) <F4D84592-C450-3076-88E9-8E6517C7EF33> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
        0x7fff91bbd000 -     0x7fff91bbffff  com.apple.TrustEvaluationAgent (2.0 - 1) <1F31CAFF-C1C6-33D3-94E9-11B721761DDF> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Vers ions/A/TrustEvaluationAgent
        0x7fff91bc0000 -     0x7fff91be9fff  com.apple.CoreVideo (1.7 - 70.3) <9A9D4058-9935-3B0A-B1A6-27EB78D02249> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
        0x7fff91bea000 -     0x7fff91becff7  com.apple.print.framework.Print (7.4 - 247.3) <626C58D5-2841-3329-8C32-9F4A8353F3E7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Pri nt.framework/Versions/A/Print
        0x7fff91bf7000 -     0x7fff91c36ff7  libGLImage.dylib (??? - ???) <49BB4404-68F1-3839-A5C9-983405B59F52> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG LImage.dylib
        0x7fff91c37000 -     0x7fff91cbbff7  com.apple.ApplicationServices.ATS (317.11.0 - ???) <082DEAFE-8A93-3AF2-B4E5-30012E725929> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/ATS
        0x7fff91cbc000 -     0x7fff91cccff7  com.apple.opengl (1.7.7 - 1.7.7) <0CA11278-746C-353A-923B-BCC0047190C3> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
        0x7fff91ccf000 -     0x7fff91cd2fff  libCoreVMClient.dylib (??? - ???) <934D0D11-C34F-3C06-A352-21BB8FFE9774> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libC oreVMClient.dylib
        0x7fff91e62000 -     0x7fff91f62fff  com.apple.QuickLookUIFramework (3.2 - 500.16) <0BACF8C4-5A7B-31EE-B4AA-3CCF8615C9A8> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Qui ckLookUI.framework/Versions/A/QuickLookUI
        0x7fff91f63000 -     0x7fff91f67fff  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
        0x7fff91f68000 -     0x7fff91fd1fff  com.apple.coreui (1.2.2 - 165.10) <F427BF39-3E01-3DC6-A63D-BFC50FE6C72E> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
        0x7fff91fd2000 -     0x7fff92247ff7  com.apple.imageKit (2.1.2 - 1.0) <5BAA52A9-F359-31E4-8109-74EBCEB626B4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/Ima geKit.framework/Versions/A/ImageKit
        0x7fff924fe000 -     0x7fff92539fff  com.apple.LDAPFramework (3.2 - 120.2) <A2675243-9122-308D-A5C8-9C1C4FE7639D> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
        0x7fff9253a000 -     0x7fff92ccefef  com.apple.CoreAUC (6.16.11 - 6.16.11) <3D40FEA5-AFE7-3752-A52E-D0F80304320A> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAU C
        0x7fff92ccf000 -     0x7fff92dadfff  com.apple.DiscRecording (6.0.4 - 6040.4.1) <E6D5835F-EE3C-3814-A2EE-6962B5570EF1> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRec ording
        0x7fff92f1b000 -     0x7fff92f20fff  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
        0x7fff92f64000 -     0x7fff93280fff  com.apple.CoreServices.CarbonCore (960.24 - 960.24) <6F99A26B-788F-37B9-860F-508906EC06D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CarbonCore.framework/Versions/A/CarbonCore
        0x7fff93281000 -     0x7fff9329dfff  com.apple.frameworks.preferencepanes (15.0 - 15.0) <A1ABA9DB-2C8A-3C96-976A-21E63194F7B2> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/Prefe rencePanes
        0x7fff93491000 -     0x7fff93491fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/vecLib
        0x7fff936a1000 -     0x7fff936f4fff  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <E3FE9B47-2276-3316-B2D2-85784AD2D9B3> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleV A
        0x7fff936f5000 -     0x7fff936fbfff  libGFXShared.dylib (??? - ???) <8A61FA67-EB3C-319D-AE3C-64936FB26BAC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG FXShared.dylib
        0x7fff936fc000 -     0x7fff937afff7  com.apple.CoreText (220.20.0 - ???) <0E979362-15E4-3955-BF54-B5961361D1CC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreText.framework/Versions/A/CoreText
        0x7fff937e6000 -     0x7fff9382fff7  com.apple.framework.CoreWLAN (2.1.2 - 212.2) <5E421E2D-50EA-340E-A5EE-C848DD6FC34F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
        0x7fff9383a000 -     0x7fff93840fff  IOSurface (??? - ???) <77C6757B-D357-3E34-9424-48F962B5CC9C> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
        0x7fff93841000 -     0x7fff93842fff  libunc.dylib (24.0.0 - compatibility 1.0.0) <337960EE-0A85-3DD0-A760-7134CF4C0AFF> /usr/lib/system/libunc.dylib
        0x7fff93843000 -     0x7fff93845fff  libquarantine.dylib (36.6.0 - compatibility 1.0.0) <0EBF714B-4B69-3E1F-9A7D-6BBC2AACB310> /usr/lib/system/libquarantine.dylib
        0x7fff93846000 -     0x7fff93863fff  libxpc.dylib (77.19.0 - compatibility 1.0.0) <9F57891B-D7EF-3050-BEDD-21E7C6668248> /usr/lib/system/libxpc.dylib
        0x7fff93864000 -     0x7fff93869fff  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
        0x7fff9386a000 -     0x7fff93897fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <7BEBB139-50BB-3112-947A-F4AA168F991C> /usr/lib/libSystem.B.dylib
        0x7fff938d6000 -     0x7fff93915fff  com.apple.AE (527.7 - 527.7) <B82F7ABC-AC8B-3507-B029-969DD5CA813D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/AE.framework/Versions/A/AE
        0x7fff9391a000 -     0x7fff93921fff  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <0AB51EE2-E914-358C-AC19-47BC024BDAE7> /usr/lib/system/libcopyfile.dylib
        0x7fff93922000 -     0x7fff93c4eff7  com.apple.HIToolbox (1.9 - ???) <B7D2A06B-7BE5-3355-BF7D-8139100B9B97> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIT oolbox.framework/Versions/A/HIToolbox
        0x7fff93c5a000 -     0x7fff93cd0fff  libc++.1.dylib (28.1.0 - compatibility 1.0.0) <DA22E4D6-7F20-3BEA-9B89-2FBA735C2EE1> /usr/lib/libc++.1.dylib
        0x7fff93cd1000 -     0x7fff93cd6fff  com.apple.OpenDirectory (10.7 - 146) <A674AB55-6E3D-39AE-9F9B-9865D0193020> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDir ectory
        0x7fff93cd7000 -     0x7fff93d37fff  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <3A7521E6-5510-3FA7-AB65-79693A7A5839> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvDSP.dylib
        0x7fff93d38000 -     0x7fff93d39fff  liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
        0x7fff93d3a000 -     0x7fff93d5efff  com.apple.RemoteViewServices (1.4 - 44.1) <EA3837DF-A3A3-37FF-AE11-D50048D5F21A> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versio ns/A/RemoteViewServices
        0x7fff93d5f000 -     0x7fff94226fff  FaceCoreLight (1.4.7 - compatibility 1.0.0) <BDD0E1DE-CF33-3AF8-B33B-4D1574CCC19D> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/ FaceCoreLight
        0x7fff94227000 -     0x7fff94235fff  libdispatch.dylib (187.9.0 - compatibility 1.0.0) <1D5BE322-A9B9-3BCE-8FAC-076FB07CF54A> /usr/lib/system/libdispatch.dylib
        0x7fff94236000 -     0x7fff9424dfff  com.apple.CFOpenDirectory (10.7 - 146) <E6D4F114-678B-3957-9C59-9206ECDA756E> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Framewo rks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
        0x7fff9424e000 -     0x7fff94332fff  com.apple.CoreServices.OSServices (478.46 - 478.46) <70BEE269-8F4D-3FDC-B1AD-A591C0CB37E5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/OSServices.framework/Versions/A/OSServices
        0x7fff943fa000 -     0x7fff94475ff7  com.apple.print.framework.PrintCore (7.1 - 366.3) <C5F39A82-0E77-3AD6-906A-20DD2EE8D374> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/PrintCore.framework/Versions/A/PrintCore
        0x7fff94476000 -     0x7fff94b51ff7  libclh.dylib (4.0.3 - 4.0.3) <B00A31B8-AF78-32B0-8983-AEE8EFC6C150> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libc lh.dylib
        0x7fff94bed000 -     0x7fff94f06fff  com.apple.Foundation (6.7.2 - 833.25) <22AAC369-B63C-3C55-8AC6-C3ECBA44DA7B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
        0x7fff94f07000 -     0x7fff94f9dff7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <642D8D54-F9F5-3FBB-A96C-EEFE94C6278B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libvMisc.dylib
        0x7fff94f9e000 -     0x7fff950aafff  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <3A8E1F89-5E26-3C8B-B538-81F5D61DBF8A> /usr/lib/libcrypto.0.9.8.dylib
        0x7fff95106000 -     0x7fff95125fff  libresolv.9.dylib (46.1.0 - compatibility 1.0.0) <0635C52D-DD53-3721-A488-4C6E95607A74> /usr/lib/libresolv.9.dylib
        0x7fff95126000 -     0x7fff9528dfff  com.apple.CFNetwork (520.4.3 - 520.4.3) <31D7A595-375E-341A-8E97-21E73CC62E4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/CFNetwork.framework/Versions/A/CFNetwork
        0x7fff9528e000 -     0x7fff95295fff  libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <B3F07872-63B1-3AAF-A313-9B2886822C58> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage . A.dylib
        0x7fff952fb000 -     0x7fff952fcff7  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
        0x7fff952fd000 -     0x7fff954fffff  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <38CD6ED3-C8E4-3CCD-89AC-9C3198803101> /usr/lib/libicucore.A.dylib
        0x7fff95500000 -     0x7fff95529fff  libJPEG.dylib (??? - ???) <64D079F9-256A-323B-A837-84628B172F21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
        0x7fff9552a000 -     0x7fff9552afff  com.apple.Carbon (153 - 153) <AF0F9910-E3C3-3922-AA92-A39000655E0F> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
        0x7fff95578000 -     0x7fff95583fff  com.apple.CommonAuth (2.2 - 2.0) <77E6F0D0-85B6-30B5-B99C-F57104DD2EBA> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/Com monAuth
        0x7fff95584000 -     0x7fff955dcfff  libTIFF.dylib (??? - ???) <A0FF68DE-2935-30E7-B61C-4D9D70E14AD0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
        0x7fff955dd000 -     0x7fff955f3fff  libGL.dylib (??? - ???) <6A473BF9-4D35-34C6-9F8B-86B68091A9AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libG L.dylib
        0x7fff955f4000 -     0x7fff955faff7  com.apple.phonenumbers (1.0 - 47) <BC6C2FE2-99C0-3AD6-AA9C-C88780FFFCCF> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/P honeNumbers
        0x7fff955fb000 -     0x7fff955fbfff  com.apple.quartzframework (1.5 - 1.5) <2C13AE76-C86B-3D48-A583-121689190F74> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
        0x7fff9560c000 -     0x7fff95615ff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <A4D651E3-D1C6-3934-AD49-7A104FD14596> /usr/lib/system/libsystem_notify.dylib
        0x7fff95616000 -     0x7fff95628ff7  libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
        0x7fff95638000 -     0x7fff95638fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <82DDF6F5-FBC3-323D-B71D-CF7ABC5CF568> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
        0x7fff95639000 -     0x7fff95752fff  com.apple.DesktopServices (1.6.3 - 1.6.3) <20812ECE-CACC-3D44-8108-025EF6B45C14> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versi ons/A/DesktopServicesPriv
        0x7fff95753000 -     0x7fff95a75fe7  com.apple.JavaScriptCore (7534.56 - 7534.56.6) <675725F8-37C4-3B80-ADB0-7B6AE908A908> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaSc riptCore
        0x7fff95a82000 -     0x7fff95b87fff  libFontParser.dylib (??? - ???) <759645F2-8CB1-358C-AF41-BA3797CD0F60> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
        0x7fff95b88000 -     0x7fff95c95fff  libJP2.dylib (??? - ???) <5BE8CFA7-00C2-3BDE-BC20-5FF6DC18B415> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
        0x7fff95cf0000 -     0x7fff95d2afe7  com.apple.DebugSymbols (2.1 - 87) <ED2B177C-4146-3715-91DF-D99A8ED5449A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/D ebugSymbols
        0x7fff95d2b000 -     0x7fff9622efe7  com.apple.RawCamera.bundle (3.13.0 - 627) <4593B038-1A60-5ADB-565D-5BDFA28A53F2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamer a
        0x7fff9624c000 -     0x7fff96277fff  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <7D3CDB0A-840F-3856-8F84-B4A50E66431B> /usr/lib/libpcre.0.dylib
        0x7fff96278000 -     0x7fff962ccff7  com.apple.ScalableUserInterface (1.0 - 1) <33563775-C662-313D-B7FA-3D575A9F3D41> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /ScalableUserInterface.framework/Versions/A/ScalableUserInterface
        0x7fff962cd000 -     0x7fff966fafff  libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks /vecLib.framework/Versions/A/libLAPACK.dylib
        0x7fff966fb000 -     0x7fff96734fe7  libssl.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <79AAEC98-1258-3DA4-B1C0-4120049D390B> /usr/lib/libssl.0.9.8.dylib
        0x7fff96735000 -     0x7fff967b8fef  com.apple.Metadata (10.7.0 - 627.32) <38735923-2EB5-3133-BE36-BDD65A7E47DB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/Metadata.framework/Versions/A/Metadata
        0x7fff967b9000 -     0x7fff9689de5f  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <871E688B-CF57-3BC7-80D6-F6476DFF109B> /usr/lib/libobjc.A.dylib
        0x7fff9689e000 -     0x7fff968b0ff7  libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
        0x7fff968b1000 -     0x7fff96919ff7  com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <DFD8F4DE-3B45-3A2E-9CBE-FD8D5DD30923> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
        0x7fff96936000 -     0x7fff96940ff7  liblaunch.dylib (392.38.0 - compatibility 1.0.0) <6ECB7F19-B384-32C1-8652-2463C1CF4815> /usr/lib/system/liblaunch.dylib
        0x7fff96946000 -     0x7fff96b70fe7  com.apple.CoreData (104.1 - 358.14) <6BB64605-8DA7-337D-A2AB-A3346A421CBD> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
        0x7fff96b71000 -     0x7fff96c0bff7  com.apple.SearchKit (1.4.0 - 1.4.0) <4E70C394-773E-3A4B-A93C-59A88ABA9509> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/SearchKit.framework/Versions/A/SearchKit
        0x7fff96c0c000 -     0x7fff96ef5ff7  com.apple.security (7.0 - 55148.1) <E9C46204-1336-3D90-BC67-5162FC7079D2> /System/Library/Frameworks/Security.framework/Versions/A/Security
        0x7fff96ef6000 -     0x7fff96f1efff  com.apple.PerformanceAnalysis (1.11 - 11) <8D4C6382-DD92-37A2-BCFC-E89951320848> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versi ons/A/PerformanceAnalysis
        0x7fff96f1f000 -     0x7fff96f2dff7  libkxld.dylib (??? - ???) <C2FC894F-3716-32C3-967E-6AD5E2697045> /usr/lib/system/libkxld.dylib
        0x7fff96f2e000 -     0x7fff96f34ff7  libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
        0x7fff97290000 -     0x7fff976c3ff7  com.apple.VideoToolbox (1.0 - 705.78) <7F115540-88CF-3087-951A-7073F7D58F4D> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/V ideoToolbox
        0x7fff976ed000 -     0x7fff977cafef  libsystem_c.dylib (763.13.0 - compatibility 1.0.0) <41B43515-2806-3FBC-ACF1-A16F35B7E290> /usr/lib/system/libsystem_c.dylib
        0x7fff977cb000 -     0x7fff983d1ff7  com.apple.AppKit (6.7.3 - 1138.47) <CAF5783F-F80B-30E7-929F-BBA6D96C5C44> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
        0x7fff983e5000 -     0x7fff983e5fff  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
        0x7fff983e6000 -     0x7fff983f1ff7  com.apple.speech.recognition.framework (4.0.21 - 4.0.21) <6540EAF2-E3BF-3D2E-B4C1-F106180D6F20> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Spe echRecognition.framework/Versions/A/SpeechRecognition
        0x7fff983f6000 -     0x7fff9841dfff  com.apple.framework.internetaccounts (1.2 - 3) <483427CA-8140-355D-B668-78F5A5F1A1D6> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions /A/InternetAccounts
        0x7fff9841e000 -     0x7fff9841efff  com.apple.ApplicationServices (41 - 41) <89B6AD5B-5C75-3E83-8C2B-AA7F4C55E400> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/A pplicationServices
        0x7fff9841f000 -     0x7fff98454fff  com.apple.securityinterface (5.0 - 55022.4) <09EC371E-0B6E-3849-A6C9-F8E9DB17BBCD> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/Sec urityInterface
        0x7fff98455000 -     0x7fff9854fff7  com.apple.DiskImagesFramework (10.7.4 - 331.6) <C7860B00-E1CF-3851-9A3B-9F145B7F498F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/Dis kImages
        0x7fff98550000 -     0x7fff98550fff  com.apple.audio.units.AudioUnit (1.7.2 - 1.7.2) <04C10813-CCE5-3333-8C72-E8E35E417B3B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
        0x7fff9855f000 -     0x7fff985f2ff7  com.apple.PDFKit (2.6.3 - 2.6.3) <49BF9CDC-E902-3CAC-9C04-3302545907D5> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDF Kit.framework/Versions/A/PDFKit
        0x7fff9865f000 -     0x7fff9866bfff  com.apple.DirectoryService.Framework (10.7 - 146) <65C78AE3-89B8-3372-8359-31FD520781D5> /System/Library/Frameworks/DirectoryService.framework/Versions/A/Dire ctoryService
        0x7fff9866c000 -     0x7fff9866dfff  libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
        0x7fff9866e000 -     0x7fff988e1fff  com.apple.CoreImage (7.98 - 1.0.1) <73485E4E-1407-3913-AB3C-B54986A3E01C> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks /CoreImage.framework/Versions/A/CoreImage
        0x7fff988e2000 -     0x7fff988f9fff  com.apple.MultitouchSupport.framework (231.4 - 231.4) <10A978D1-8781-33F0-BE45-60C9171F7278> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Version s/A/MultitouchSupport
        0x7fff988fa000 -     0x7fff98957ff7  com.apple.QuickLookFramework (3.2 - 500.16) <46017A4B-9E2B-329C-A8D9-2C11DE6C1A47> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
        0x7fff98993000 -     0x7fff98a34ff7  com.apple.LaunchServices (480.33 - 480.33) <45EF2044-3396-3910-9B5B-C8F7777D5F56> /System/Library/Frameworks/CoreServices.framework/Versions/A/Framewor ks/LaunchServices.framework/Versions/A/LaunchServices
        0x7fff98a35000 -     0x7fff98a60ff7  com.apple.CoreServicesInternal (113.17 - 113.17) <B1DF81C3-9C23-3BAE-9DE8-21EAFEEB97B8> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Vers ions/A/CoreServicesInternal
        0x7fff98a61000 -     0x7fff98a6eff7  libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <3373D310-3B10-3DD1-B754-B7B138CD448D> /usr/lib/libbz2.1.0.dylib
        0x7fff98a6f000 -     0x7fff98a6ffff  com.apple.CoreServices (53 - 53) <043C8026-8EDD-3241-B090-F589E24062EF> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServ ices
        0x7fff98aaf000 -     0x7fff98ab0ff7  libsystem_sandbox.dylib (??? - ???) <96D38E74-F18F-3CCB-A20B-E8E3ADC4E166> /usr/lib/system/libsystem_sandbox.dylib
        0x7fff98ab1000 -     0x7fff98b24fff  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
        0x7fff98b25000 -     0x7fff98b2afff  libcache.dylib (47.0.0 - compatibility 1.0.0) <1571C3AB-BCB2-38CD-B3B2-C5FC3F927C6A> /usr/lib/system/libcache.dylib
        0x7fff98b2b000 -     0x7fff98b32fff  com.apple.NetFS (4.0 - 4.0) <433EEE54-E383-3505-9154-45B909FD3AF0> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
        0x7fff98b33000 -     0x7fff98b36ff7  com.apple.securityhi (4.0 - 1) <37DF1BF8-ACE0-3C4A-81AA-BBA9744EB0A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Sec urityHI.framework/Versions/A/SecurityHI
        0x7fff98b43000 -     0x7fff98c40ff7  com.apple.avfoundation (2.0 - 180.40) <ED3DCB15-7E88-34FD-9E56-4ECAD10A6E7E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFounda tion
        0x7fff98c41000 -     0x7fff98c47fff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <CEA34337-63DE-302E-81AA-10D717E1F699> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskA rbitration
        0x7fff98c50000 -     0x7fff98c79ff7  com.apple.framework.Apple80211 (7.2.1 - 721.3) <4BA49D6F-373B-3F4E-A2B3-453C2ED66318> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/App le80211
        0x7fff99124000 -     0x7fff9920efff  com.apple.backup.framework (1.3.3 - 1.3.3) <6C49FBCF-D6AF-3351-BBBF-A98A622CA517> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
        0x7fff9920f000 -     0x7fff9926bff7  com.apple.HIServices (1.21 - ???) <9645CFA8-63BE-3A0D-A636-56D9827E6C8C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/HIServices.framework/Versions/A/HIServices
        0x7fff9926c000 -     0x7fff99281fff  com.apple.FileSync.framework (6.0.1 - 502.2) <65A5CD1B-766D-33F8-8AC1-0984499838E9> /System/Library/PrivateFrameworks/FileSync.framework/Versions/A/FileS ync
        0x7fff99282000 -     0x7fff99389fe7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <EE02BB01-64C9-304D-9719-A35F5CD6D04C> /usr/lib/libsqlite3.dylib
        0x7fff9938a000 -     0x7fff99392fff  libsystem_dnssd.dylib (??? - ???) <D9BB1F87-A42B-3CBC-9DC2-FC07FCEF0016> /usr/lib/system/libsystem_dnssd.dylib
        0x7fff99393000 -     0x7fff9945aff7  com.apple.ColorSync (4.7.4 - 4.7.4) <590AFCDA-F10E-31FE-9B01-DA5FFE74C2BB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/F rameworks/ColorSync.framework/Versions/A/ColorSync
    External Modification Summary:
      Calls made by other processes targeting this process:
        task_for_pid: 14
        thread_create: 0
        thread_set_state: 0
      Calls made by this process:
        task_for_pid: 0
        thread_create: 0
        thread_set_state: 0
      Calls made by all processes on this machine:
        task_for_pid: 1052
        thread_create: 0
        thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=494.5M resident=246.9M(50%) swapped_out_or_unallocated=247.6M(50%)
    Writable regions: Total=8.4G written=8.0G(94%) resident=7.2G(85%) swapped_out=1.0G(12%) unallocated=1.3G(15%)
    REGION TYPE                      VIRTUAL
    (null) (reserved)                    20K        reserved VM address space (unallocated)
    ATS (font support)                 31.9M
    ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
    CG backing stores                  14.1M
    CG image                            112K
    CG raster data                      452K
    CG shared images                   3408K
    CoreGraphics                         16K
    CoreImage                             8K
    CoreServices                       1440K
    IOKit                              23.0M
    IOKit (reserved)                     16K        reserved VM address space (unallocated)
    MALLOC                              5.4G
    MALLOC guard page                    32K
    Memory tag=240                        4K
    Memory tag=242                       12K
    Memory tag=243                        4K
    Memory tag=249                      192K
    Memory tag=251                       84K
    OpenCL                               40K
    OpenGL GLSL                        1244K
    OpenGL GLSL (reserved)              128K        reserved VM address space (unallocated)
    STACK GUARD                        56.1M
    Stack                              23.3M
    VM_ALLOCATE                        26.7G
    __CI_BITMAP                          80K
    __DATA                             44.0M
    __IMAGE                             528K
    __LINKEDIT                        158.7M
    __RC_CAMERAS                        248K
    __TEXT                            335.8M
    __UNICODE                           544K
    mapped file                        93.2M
    shared memory                     136.4M
    TOTAL                              33.0G
    TOTAL, minus reserved VM space     33.0G
    Model: MacPro5,1, BootROM MP51.007F.B03, 12 processors, 6-Core Intel Xeon, 2.93 GHz, 12 GB, SMC 1.39f11
    Graphics: NVIDIA Quadro 4000, NVIDIA Quadro 4000, PCIe, 2048 MB
    Memory Module: DIMM 1, 2 GB, DDR3 ECC, 1333 MHz, 0x802C, 0x394A53463235363732415A2D314734443100
    Memory Module: DIMM 2, 2 GB, DDR3 ECC, 1333 MHz, 0x802C, 0x394A53463235363732415A2D314734443100
    Memory Module: DIMM 3, 2 GB, DDR3 ECC, 1333 MHz, 0x802C, 0x394A53463235363732415A2D314734443100
    Memory Module: DIMM 5, 2 GB, DDR3 ECC, 1333 MHz, 0x802C, 0x394A53463235363732415A2D314734443100
    Memory Module: DIMM 6, 2 GB, DDR3 ECC, 1333 MHz, 0x802C, 0x394A53463235363732415A2D314734443100
    Memory Module: DIMM 7, 2 GB, DDR3 ECC, 1333 MHz, 0x802C, 0x394A53463235363732415A2D314734443100
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.198.4.20)
    Bluetooth: Version 4.0.5f11, 2 service, 18 devices, 1 incoming serial ports
    Network Service: Ethernet 2, Ethernet, en1
    PCI Card: Apple 2 Port 4Gbps Fibre Channel Card, sppci_fibrechannel, Slot-4
    PCI Card: NVIDIA Quadro 4000, sppci_displaycontroller, Slot-1
    PCI Card: NVIDIA Quadro 4000, NVDA,Parent, Slot-1
    PCI Card: pcif1d0,c0ff, sppci_video, Slot-2@8,12,0
    Serial ATA Device: HL-DT-ST DVD-RW GH61N
    Serial ATA Device: Hitachi HDS723020BLA642, 2 TB
    Fibre Channel Device: SCSI Target Device @ 0
    USB Device: hub_device, 0x0424  (SMSC), 0x2503, 0xfd300000 / 2
    USB Device: Apple Optical USB Mouse, apple_vendor_id, 0x0304, 0xfd320000 / 4
    USB Device: KEYBOARD, 0x4320, 0x0201, 0xfd330000 / 3
    USB Device: Shure Digital, 0x14ed  (Shure Inc.), 0x2904, 0x3a200000 / 2
    USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x5a100000 / 2
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 3
    FireWire Device: built-in_hub, 800mbit_speed
    Jun 27, 2012 2:54 PM   in reply to RBemendo
    I have my media on a 2 TB drive and there are 743.31 GB of space left.
    I just posted a crash report today so it's at the end of this thread.
    thx...jw
    Jun 27, 2012 3:27 PM   in reply to jwffvm
    I'd like to add that I am getting the "Serious error" whenever I try to submit a clip for speech analysis.
    JW the Adobe people don't like when you post crash reports here, it clutters up the thread and isn't the best way to get it to the engineers who are the only ones who understand it anyway. If you want to submit the crash report go to the bug report page and attach it as a file there.
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Jun 27, 2012 3:34 PM   in reply to benwinter
    Thanks Ben,
    I didn't know.  Will do so next time.
    thx...jw
    Jun 28, 2012 10:38 AM   in reply to Glitchdog
    As I remember other than the CS6 master collection my MacBook was installed with: VLC player, Any Video Converter, 5DtoRGB converter, Adobe CS5 master collection, Final Cut Pro X, Motion, Compressor, Red Giant Magic Bullet Suite plug-ins for After Effects & FCPX (which include Colorista II, Denoiser II, Looks, Mojo, Grinder, Knoll light, Trapcode, etc),  Twixtor plug-in and Ableton.
    I am now trying to reinstall CS6 back to my newly restored Lion 10.7.4, fingers crossed.
1 2 3 4 5 6 ... 14 Previous Next
Actions
Bookmarked By (6)
