I'm trying to load Premiere CS 5.5.2 and it is stuck on "Loading ExporterQuicktimeHost.bundle".
I have read through this document, which was recommended by Todd Kopriva, but it does not solve the problem. I only have AC3MovieImport and Perian installed in the Quicktime Library and when I temporarily remove these the problem still occurs. Nothing has changed with a firewall as far as I know.
However, the one thing that changed just before this problem started is that I was reorganizing media files for past projects, so I had to reconnect a lot of files that were offline. I'm not sure how this coud affect the start up of Premiere even when I an opening up without a specific project.
Thank you for your help.
Same deal. Yesterday everything was fine. Today, totally stalled on the ExporterQuicktimeHost.
Just got off the phone with Adobe support and they told me to call Apple as it is a permissions problem. That's all he could tell me even though I haven't installed anything or changed my system or updates anything.
We opened my system to the "root" user and the application opened just fine. Very annoying.
This is happening to me, too!
I tried everything from that old CS5 documentation for AE, that stuff from Todd Kopriva about firewalls and removing QuickTime components, and absolutely nothing has worked. Additionally, I've uninstalled and reinstalled everything, and trashed all relevant preferences in /Library. I've done all this from within the "root" user. I've cleared PRAM on my machine, and repaired and verified all disks involved, to no avail.
Adobe's phone support is baffled.
This has brought my work to a griding halt.
The plot thickens.
This morning, Adobe was able to get Premiere Pro working on the "root" user account, but not any other user.
I called Apple, and with them I repaired the disk permissions and repaired the disk from Lion's repair partition. I also cleared the "Caches" folder from the user Library, and tried in Safe Mode.
A senior support representative at Apple informed me that getting Premiere Pro to work on the root account wasn't helpful, because pretty much anything will work in the root account. He had me create a totally brand new administrative user account, and the application is still hanging on ExporterQuickTimeHost.bundle, so this can't be a permissions problem. This is certainly a problem with the application, because the new user account is a totally fresh environment.
I'll keep you all posted.
Adobe just told me that they do not agree with Apple's assessment that running the application in the root account is meaningless. Adobe told me to call back Apple and have them guide me through "resetting access control" for the specific user account I normally use, "full write for everything."
I am about to call Apple and will report back here.
Hi Everyone,
I used "Solution 2" from this Adobe page and was successful.
http://helpx.adobe.com/x-productkb/multi/startup-screen-hangs-premiere -after.html
I originally had tried to do this about a month ago, but it looked like there were no plugins in the Library/Quicktime folder. This time when I checked though, there were several plugins.
I moved all the plugins to a temporary folder on the desktop and restarted Premiere. It loaded no problem. I then started to place back some of the plugins one by one and restarted Premiere each time to see if the problem still existed.
Eric -- Deleted four components, "AC3MovieImport" and "Flip4Mac WMV Advanced/Export/Import.components" Corrected the Host.bundle launch problem -- PremierPro 5.5 back up & running.
Thanks for the explanation & fix! A big help.
Side note: Still have many editing codec compinents within QT folder, including some from Apple and DVCProHD, that I use dauly, Checked out on a second MacPro.
SUCCESS! Apple solved my problem!
Adobe told me to go back to Apple to reset access control.
Here's what Apple had me do, and this worked:
To everyone who encounters thread this in the future, I hope this helps!
I found a good article on "How to Repair User Level Permissions" on Snow Leopard which discusses using "reset ACL."
I tried this technique, but still no go. Premier CS6 still hangs on launch at "loading ExportQuickTimeHost.bundle." In addition, both After Effects CS6 and Adobe Media Encoder will not open.
I am dead in the water. If anyone could point me in the right direction, it would be greatly appreciated.
Thanks again,
Kevin
Kevin,
I found this blog post for instructions in Snow Leopard. You'll need your install disc. Aside from requiring an optical disc, it looks pretty similar to what I had to do in Lion.
http://www.macobserver.com/tmo/article/how_to_resolve_user-level_permi ssions_issues_mac_os_x/
Let us know if that works.
-- Seth.
Kevin -- Am also on 10.6.8 using PPro 5.5; solved this same "Host.bundle" problem with the direction from another Forum post here: http://forums.adobe.com/message/2808379#2808379
Read #22 by another seth (monger) from May 12, 2010. In the Mac/Library/QuickTime folder, I began deleting odd codecs and after my first attempt, it worked. Thanks goes to seth.
The QuickTime repair all link has all the tips we need here: http://blogs.adobe.com/toddkopriva/2011/02/troubleshooting-quicktime-e rrors-with-after-effects.html
Kevin,
Sorry, didn't see that in the thread. It was the exact same article, too.
What version of Snow Leopard are you running? Adobe says that CS6 will run on Snow Leopard, but you'll need at least Mac OS X v10.6.8.
The nuclear option is a total reinstallation of the OS.
Seth,
Here's the latest twist. Since removing codecs from my Mac/Library/QuickTime folder didn't work, I took a look in my username/Library/QuickTime folder and removed the two files I found there... Voila, after a restart, PP and AE will now both successfully launch!
Below are the names of the files I removed.
AC3MovieImport.component
Perian.component
I have to admit, I am not the least bit confident this is going to last. I'm just soooo greatful I wasn't in the middle of a major project.
Thanks again for your advice.
Kevin
I have been having this issue periodically on CS5.5 and now on CS6, very frustrating. I would typically fix it by what bdaul said in #27, then I would replace the 2 QT.bundle files with the same named files from the Package Contents of the Media Encoder and that seemed to work SOMETIMES. But on CS6 the problem seemed impossible to fix. Then I found on another forum (can't remember which one) that a person said they repared their Mac HD disk permissions 3x and it worked. So I did it once, no go, then I did it 3 more consecutive times and restarted and that worked. I HOPE that is a more permanant solution! This really seems like an Adobe issue.
Also, this whole issue started to happen with CS6 as soon as I installed the PPro & Encore Functional Content. Then I immediately had the loading issue and Encore would open but freeze with the lovely beachball. The Disk Permissions has fixed both issues.
Good luck!
27" iMac (early 2010), Snow Leopard 10.6.8, CS6 Master Collection (via cloud subscription)
Having tried repairing permissions etc I established that I could open Premiere Pro CS5.5 using the Root account. I then created a new admin user account - the application openened fine in that. I then switched back to my usual (admin) account and Premiere opened perfectly in that. Can't explain it, but it worked! Maybe coincidence as the problem has solved itself before.
