file types don't save properly in CS6
May 19, 2012 6:18 AM
Why? and what is Adobe doing to fix. I have read some long workarounds that are ridiculous. Photoshop has alwaysnever had issues with pointing to plugins, or old plugins moving to the new software. This is clearly a failure on their end. Photoshop USES plugins, this is snothing new. It should not be some surprise to Adobe. Will threre be a fix, or do we all have to go do Adobe's job for them?
    May 19, 2012 6:24 AM   in reply to steveparke
    Did you point the additional plugins in cs6 to a cs5 plugins folder?
    May 19, 2012 6:58 AM   in reply to steveparke
    That's the trouble probably.
    You should install the plugins in the cs6 plugins folder or your certain to have those problems as has been reported on this forum in numerous posts since cs6 came out.
    More info:
    http://forums.adobe.com/thread/965931?tstart=0
  • Noel Carboni
    Dec 23, 2006
    May 19, 2012 8:17 AM   in reply to steveparke
    It has never been a good idea to mix plug-ins from different versions of Photoshop.  The Extra Plug-ins Folder setting should only point to non-Adobe 3rd party plug-ins.  You may have had different problems before.
    -Noel
    Jun 26, 2012 2:31 PM   in reply to steveparke
    See the previous replies -- you copied plugins from a previous version of Photoshop, or set the additional plugins preference to a previous version of Photoshop.
    The duplicated plugins are causing the file format menu to be off.
    This is not a bug in Photoshop, just simple user error (combined with a MacOS issue that makes it difficult to see that the menu is messed up).
  • Noel Carboni
    Dec 23, 2006
    Jun 26, 2012 2:36 PM   in reply to steveparke
    I don't doubt and can appreciate that you have a lot of experience with Photoshop, Steve.
    But you have been doing this particular thing wrong all along.  Honest.  Chris, a Photoshop architect, is telling you so as well.
    Mixing plug-ins from different versions of Photoshop has always been a bad idea.  You may have had problems or missing functionality you didn't know was attributed to this because of having done so before.
    -Noel
    Jun 26, 2012 2:58 PM   in reply to steveparke
    No, in previous versions duplicated plugins may have caused problems, and would have been more visible because they would show up duplicated in the file format menu.  In CS6, there are enough changes that older plugins can cause more problems, and a MacOS issue causes the menu to not show duplicates and get out of sync with the internal list of formats.
    You never should have pointed to a plugin folder from a previous version. Yes, that was always a mistake, and probably caused some weird problems for you in older versions of Photoshop.
    This is just user error.  We can work around the OS menu limitation, but you still need to get rid of the duplicated plugins that are causing you problems.
    Jun 26, 2012 3:07 PM   in reply to Chris Cox
    With it now known that the Mac OS hides duplicates, perhaps a check for duplicate plug-ins can be made during Photoshop’s initial plug-in scan, and a warning issued.
    Jun 26, 2012 3:13 PM   in reply to ssprengel
    We have to allow duplicates to allow for some third party plugins.
    But we can work around the OS limitations on the menu and make it more obvious that the user has duplicated the file format plugins.
    Normally the user would also see duplication in the filter menu, or just lots of problems with the filters, or warnings about extensions not being compatible with this version of Photoshop -- which should give them some hint about having obsolete plugins loaded.
    Jun 26, 2012 3:16 PM   in reply to steveparke
    It is a known user error, and is documented in the CS6 FAQ, the tech support documentation, here in the forums, and on the feedback.photoshop.com site.
    The only action to be taken is to inform users of their mistake and ask them to resolve the duplicated/obsolete plugins.
Bookmarked By (1)
