razzhead
Apply multiple effects to multiple objects with single click box
Jun 26, 2012 4:16 PM
I would like to click on a click box and have one object appear and another object disappear. I guess what I'd like to do is apply effects to multiple objects with a single click box. Is that possible?
Thank you.
    Jun 26, 2012 4:26 PM   in reply to razzhead
    Welcome to our community
    Sure it can be done but you won't use effects to do it.
    When you insert an object in Captivate, you have an option to enable or disable Visibility. You also have an option to name the object. So you would give the object a meaningful name and clear the Visibility option to "hide" it until needed.
    Then you would create an Advanced Action that would hide some objects and show others.
    After that, you would assign the Advanced Action to a Click Box or a Button or some other event.
    Cheers... Rick
    Helpful and Handy Links
    Captivate Wish Form/Bug Reporting Form
    Adobe Certified Captivate Training
    SorcerStone Blog
    Captivate eBooks
    Jun 26, 2012 11:34 PM   in reply to razzhead
    Hello,
    Want to warn  if you are looking to see the effect . Is that the case? It may not be then as simple as showing the object to see the effect, because it depends also on the position of the playhead compared with the timeline of that object and the timing of the effect.
    If you do not need an effect, just ignore this posting
    Lilybiri
