How can I validate "Name" spry-textfields???
Jun 26, 2012 7:39 AM
Tags: #cs5.5 #dreamweaver #javascript #spry #dreamweaver_cs5 #ajax #textfield #validation #regular_expressions
Hi I would like some information, if its possible.
I'm building a contact form and I want to add some validation to the fields using Spry.
The problem comes for my First Name and Last Name spry-textfields, where from the properties panel in type menu there is not any proper format like e-mail or zip-code has. The only thing I found that might help me is the custom option, but dont know exactlly how to use it. Basicly I 'd like to add some regular expressions to check that these fields will accept only characters and whitespaces, no numbers or symbols like @,#, etc etc
Is there any article or video (better) available that can help me work with that??
Any help would be appreciated.
    Jun 26, 2012 8:10 AM   in reply to Lykos22
    <!doctype html>
    <html>
    <head>
    <meta charset="utf-8">
    <title>Untitled Document</title>
    <link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet">
    </head>
    <body>
    <span id="sprytextfield1">
      <label for="text1"></label>
      <input type="text" name="text1" id="text1">
      <span class="textfieldRequiredMsg">A value is required.</span><span class="textfieldInvalidFormatMsg">Invalid format.</span>
    </span>
    <script src="SpryAssets/SpryValidationTextField.js"></script>
    <script>
    var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "custom", {validation:myValidation, validateOn:["blur", "change"]});
    function myValidation(value) {
      return /^[a-zA-Z\s.\-]+$/.test(value)
    </script>
    </body>
    </html>
    Gramps
    Jun 26, 2012 9:28 AM   in reply to Lykos22
    <!doctype html>
    <html>
    <head>
    </head>
    <body>
    </span>
    <script>
    </script>
    </body>
    </html>
    Jun 26, 2012 5:26 PM   in reply to Lykos22
    What is the problem? What is it that doesn't work?
    For regular expressions you might like to go to http://regexlib.com/
    Gramps
    Jun 27, 2012 7:43 PM   in reply to Lykos22
    I have looked all over the place to help you, but could not find a solution. Maybe you could try adding the letters of the Greek alphabet in a similar manner as a-zA-Z.
    Gramps
