high quality display forever?
Jun 27, 2012 12:31 AM
How can I make the display performance to be high quality display forever for the whole document instead of individual objects?
    Jun 27, 2012 1:05 AM   in reply to arjun2
    View > Display Performance > High Quality Display.
    Jun 27, 2012 3:10 AM   in reply to arjun2
    You should reset it in your prefs, as well, so you don't need to do it on a doc by doc basis in future.
    Jun 27, 2012 7:14 AM   in reply to arjun2
    arjun2 wrote:
    thanks . isn't there an all in one fix forever? maybe a script?
    The default for new documents is "Typical", and (rather untypically) you cannot change it to "High"-with-no-documents-open (the trick that works for just about every other setting).
    But you can change the default, as Peter says, in Preferences -> Display Performance. The top item is "Default View".
    Jun 27, 2012 7:54 AM   in reply to arjun2
    Go back to the prefs and verify that you really chose High Quality Dislay, that the slers in the section below are all the way to the right, and uncheck the Preserve Object Level Settings box.
