I am converting a print indesign file for use with dps. The problem is DPS wants individual files for each page. Is there a script to take each page and save as an indesign file?
Yes. Our fellow scripter wrote a script for this, please check this site more details....
http://www.loicaigon.com/en/auto.php?goTo=2
Green4ever
G'day
You could start with something like this :
tell application "Adobe InDesign CS4"
set enable redraw of script preferences to false
activate
set dsDoc to active document
set dsDocProps to properties of document preferences of dsDoc
set pages per document of dsDocProps to 1
set dsFilePath to (full name of dsDoc) as text
set text item delimiters of AppleScript to "."
set dsFilePath to text 1 thru text item -2 of dsFilePath
set text item delimiters of AppleScript to ""
set dsPageCount to (count of pages of dsDoc)
repeat with w from dsPageCount to 1 by -1
set dsNewDoc to make new document with properties {document preferences:dsDocProps}
duplicate page w of dsDoc to after page 1 of dsNewDoc
set active document to dsNewDoc
delete page 1 of dsNewDoc
save dsNewDoc to (dsFilePath & "_" & w & ".indd")
close active document
delay 1
end repeat
close dsDoc saving no
end tell
m.
Message was edited by: myDwayneSmith
Sorry, just posted this before seeing the 5.5 thing — should still work if you update the version number in the first line.
You might need to change "set dsFilePath to (full name of dsDoc) as text" to "set dsFilePath to (full name of dsDoc) as string"
you can try this....
//**** Page extractor 1.0 - A script from Loïc Aigon with the great help of Peter Kahrel and other guys
//**** that cooperated on this stuff in tha adobe scripting forum. Feel free to improve.
//**** a little mail at loic _ aigon@yahoo.fr if you appreciate that script would be nice.
// <L10N> :: FRENCH_LOCALE :: RUSSIAN_LOCALE
// Please save you file first before processing the script :: Enregistrez votre document avant de lancer le script :: Пожалуйста сохраните документ перед запуском скрипта
// Extract pages... :: Extraire des pages... :: Извлечь страницы...
// to :: a :: по
// Extract as separate pages :: Extraire chaque page comme un fichier :: Извлечь как отдельные страницы
// Remove pages after extraction :: Supprimer les pages après extraction :: Удалить страницы после извлечения
// Choose other extraction folder :: Choisir un autre dossier d'extraction :: Выбрать папку для сохранения
// </L10N> ::
// 2. Add the code's block below in your script:
if ( typeof __ == 'undefined' )
__sep = ' :: ';
__beg = ' <L10N>';
__end = ' </L10N>';
/*arr*/File.prototype.getCommentsContaining = function(/*str*/k_)
var r = [];
if ( this.open('r') )
var line;
while(!this.eof)
line = this.readln();
if ( ( line.substr(0,2) == '//' )
&& ( line.indexOf(k_) >= 0 ) )
r.push(line.substr(2));
this.close();
return(r);
/*arr*/Array.prototype.parseL10N = function(/*str*/locale_)
var r = [];
var sz = this.length;
var lm, ss;
var st = -1
var rg = 0;
for ( var i=0 ; i < sz ; i++ )
ss = this[i].split(__sep, lm);
if ( ( st == -1 ) && ( ss[0] == __beg ) )
lm = ss.length;
for ( var j = 1 ; j < lm ; j++ )
if ( ss[j] == locale_ ) rg=j;
st = 0;
continue;
if ( st == 0 )
if ( ( rg == 0 ) || ( ss[0] == __end ) ) break;
if ( ss.length <= rg ) continue;
r[ss[0].substr(1)] = ss[rg];
return(r);
/*str*/Object.prototype.toLocaleName = function()
for ( var p in Locale )
if ( Locale[p] == this ) return(p);
return(null);
String.L10N = File(app.activeScript).
getCommentsContaining(__sep).
parseL10N(app.locale.toLocaleName());
function __(s){return(String.L10N[s]||s);}
// 1. Control for documents open. If true, the script launches the dialog
if(app.documents.length >0)
var doc = app.activeDocument;
if(doc.saved==true)
extractdlg();
else
alert(__("Please save you file first before processing the script"));
else
alert("No documents open !");
// 2. Gathers many infos on the document.
function pageinfos()
var pg = doc.pages;
var pglg = pg.length;
var pFirst = Number(pg[0].name);
var pLast = Number(pg[pglg-1].name);
var pgHeigth = doc.documentPreferences.pageHeight;
var pgWitdh = doc.documentPreferences.pageWidth;
var docname = String(doc.fullName).replace (/\.indd$/, "");
var docpath = doc.filePath;
var docfullname = doc.fullName;
var infoarr = [pglg, pFirst, pLast, pgHeigth,pgWitdh,docname,docpath,docfullname];
return infoarr;
// 3. Main function. First part is the dialog
function extractdlg()
var docfile = String(pageinfos()[7]);
var dlg = app.dialogs.add({name : "Pages Extractor 1.0 - ©www.loicaigon.com"});
with(dlg)
var firstclmn = dialogColumns.add();
with(firstclmn)
var firstrow = dialogRows.add();
with(firstrow)
var clmn1 = dialogColumns.add();
with(clmn1)
var row1 = dialogRows.add();
row1.staticTexts.add({staticLabel : __("Extract pages...")});
var row2 = dialogRows.add();
with(row2)
var r2c2 = dialogColumns.add();
with(r2c2)
var r2c2r1 = dialogRows.add();
var pgStart = r2c2r1.realEditboxes.add({editValue:pageinfos()[1], minWidth: 30});
var r2c3 = dialogColumns.add();
with(r2c3)
var r2c3r1 = dialogRows.add();
r2c3r1.staticTexts.add({staticLabel : __("to")});
var r2c4 = dialogColumns.add();
with(r2c4)
var r2c4r1 = r2c4.dialogRows.add();
var pgEnd = r2c4r1.realEditboxes.add({editValue:pageinfos()[2], minWidth: 30});
var secondrow = dialogRows.add();
with(secondrow)
var clmn2 = dialogColumns.add();
with(clmn2)
with(row2)
var sepbox = checkboxControls.add({staticLabel:__("Extract as separate pages"), checkedState:false});
var thirdrow = dialogRows.add();
with(thirdrow)
var clmn3 = dialogColumns.add();
with(clmn3)
var row3 = dialogRows.add();
with(row3)
var rembox = checkboxControls.add({staticLabel:__("Remove pages after extraction"), checkedState:false});
var foutrhrow = dialogRows.add();
with(foutrhrow)
var clmn4 = dialogColumns.add();
with(clmn4)
var row4 = dialogRows.add();
with(row4)
var savebox = checkboxControls.add({staticLabel:__("Choose other extraction folder"), checkedState:false});
// If the user made good choices, the script operates.
if(dlg.show()==true)
if(pgStart.editValue >= pageinfos()[2] || pgEnd.editValue <= pageinfos()[1])
alert("The pages numbers may be at least "+pageinfos()[1] +" for the first page of the range and "+ pageinfos()[2] + " at maximum for the last page");
else
// If the user choose to pick a different folder, he will be asked for. Otherwise, the dafault folder is the one containing the file.
if(savebox.checkedState==true)
var extractfolder = Folder.selectDialog ("Please choose a folder where to save extracted pages...");
if(!extractfolder)
exit();
else
var saveextractfolder = String(extractfolder.fullName)+"/" +String(doc.name).replace (/\.indd/, "");
else
var saveextractfolder = String(pageinfos()[5]);
var rem0 = pageinfos()[0]-1;
var rem2 = (pgStart.editValue-2);
// Variables definition regarding to the choice of the user to separate or not the extracted pages.
if(sepbox.checkedState==true)
var W = pgEnd.editValue-pgStart.editValue+1;
var rem1 = pgStart.editValue;
else
var W = 1;
var rem1 = pgEnd.editValue;
// Extraction loop
for(w=0; w<W;w++)
var exportdocname = "_Pg" +(pgStart.editValue+w) +".indd";
else
var exportdocname = "_Pg"+pgStart.editValue+"_to_Pg_"+pgEnd.editValue +".indd";
for(var i=rem0; i>=rem1+w;i--)
doc.pages[i].remove();
for(var i=rem2+w; i>=0;i--)
var exportdoc = doc.save(File(saveextractfolder + exportdocname));
exportdoc.close(SaveOptions.no);
if(sepbox.checkedState==true && w<(pgEnd.editValue-pgStart.editValue))
app.open(File(docfile));
// If the user chose to remove the extracted pages from the original document, it will re open the first document then remove the unuseful pages.
if(rembox.checkedState == true)
for(var i=pgEnd.editValue-1; i>=pgStart.editValue-1;i--)
app.activeDocument.close(SaveOptions.yes);
Note: I have not tested all the features of this script.
Hi all,
I think the answer is here
http://indesignsecrets.com/get-your-old-scripts-running-again-with-mak e-it-run.php
Best,
Loic
Thanks! Well, it's almost working, I think. I used the new script that Green4ever posted above this last comment and created a new .jsx document. I loaded it into Indesign CS 5.5 and then ran the make-it-run script suggested above (it doesn't work at all without using the make-it-run script). Here's what happens:
It extracts one page (even though I set it for all 12 of my pages to make individual pages) and then gives me an error saying:
ReferenceError: Object is invalid
I'm not sure what this means or how to fix it. Does anyone else?
Continued thanks -
best,
Drew
I am attempting to use the extract pages script in InDesign CS6. I ran the "Make it run" script to update the extract pages script and then attempt to run the new script on the 64 page document. I am gettign the following error message: "Error: no file is associated with the currently active script." Does anyone have a suggestion?
Paul
Hi -
Thanks for the response. Full disclosure: I don't code. Maybe this is a simple fix... I just don't know.
I'd love for the script to be able to separate out each InDesign page in a file (and in a perfect world, allow me to rename each one it separates out, since my client is very particular about how files are named... but the splitting out is primary goal for now).
When I create a new jsx file with the code you posted I get this error message:
Error Number: 25
Error String: Expected: ;
Engine: main
File: /Applicaitons/Adobe Indesign CS5.5/Scripts/Scripts Panel/Samples/JavaScript/dwayne_Smith.jsx [I obviously named the script after you ha]
Line: 1
Source: tell application "Adobe InDesign CS5.5"
Offending Text: application
I'm not sure where to go from there. I don't have enough perspective in Code Land to understand why the things I try to do to fix it don't work - like taking out the word "application" or other uninformed things)
Thanks for any help you can provide
best,
Drew
OK — the script I posted is Applescript, not Javascript — so it's only useful if you're on a Mac.
Copy and paste it into AppleScript Editor which you'll find in Appications > Utilities (in older versions of OSX it's called Script Editor and it's in a different folder in Applications)
Change the first line to :
and change the 8th line to :
you might also want to delete this line :
You can run it directly from the editor by hitting the green run button at the top (this will help you identify any issues yet to be resolved)
Once you're happy with the way it runs, save it as a script (.scpt) into your Scripts Panel folder (will be somewhere like Applications > Adobe InDesign CS5.5 > Scripts > Scripts Panel)
Then it will be available in your Scripts Panel in InDesign (double click to run)
m.
I should say — this is the barest minimum for this kind of task.
It just takes a multi-page document and splits it into separate single-page documents
So, BizCard.indd becomes BizCard_1.indd, BizCard_2.indd, etc.
These are saved in the same location as the original.
In its current form it doesn't :
allow user to choose the new document names;
allow user to choose a different location for new files;
take into account InDesign's ability to have various page sizes;
etc.
Very basic functionality.
m.
Whoa - that was it!
I did have to take the semicolon out from the end of the script, because I got an error message - and now it works! I really appreciate your help! This will definitely save me some time.
If only I could figure out how to be able to stop the script before it each time it names a file (so that I can name it myself) that would be amazing. I'll research a little on that and see what I might can do.
Can't thank you enough ![]()
Drew
Glad it got you at least part way there.
Have a look at this post — it gives an example of how to build a dialog for user input in InDesign : http://macgrunt.com/2011/11/26/indesign-scripting-lesson-11/
Have fun with it.
m.
You may also want to read the section:
About scripting languages
in
ADOBE INDESIGN CS6
SCRIPTING TUTORIAL
Requesting a script for "Windows" is rather unclear, but it will either be a JavaScript or a Visual Basic script; VBScript and
"Translating a script from one
language to another is fairly easy."
Can your script be edited easily to change the number of pages you can split into? Two pages is what I would use frequently, but I would like to figure out where to edit the script in case I need my file split differently. I am a total script novice, so excuse my lack of knowledge.
And thank you for sharing yours!
jm
g'day jm
to separate out in sets of two you could change it to this :
tell application id "com.adobe.InDesign"
activate
if page width of dsDocProps > page height of dsDocProps then
set page orientation of dsDocProps to landscape
else
set page orientation of dsDocProps to portrait
end if
repeat with w from 1 to dsPageCount by 2
duplicate page w of dsDoc to after page -1 of dsNewDoc
duplicate page (w + 1) of dsDoc to after page -1 of dsNewDoc
delay 1
end repeat
end tell
i had to add that new if statement because I noticed that CS6 was not getting the page orientation right.
the other changes are to the repeat loop – it now increments by 2 and has an additional duplicate page line.
the after page command has also been changed to '-1'. page -1 is the last page of the document, irrespective of how many pages there are.
(all this should give you a bit of an idea of how you can adapt existing scripts to your specific needs).
if you wanted something more adaptable to various page ranges – or even multiple page ranges from the same document – you'd need to start playing around with user interfaces.
you can see how i used such an approach to exporting pdfs here : http://macgrunt.com/2011/11/26/indesign-scripting-lesson-11/
hope that gets you started on a long and rewarding relationship with scripting
m.
Thanks, myDwayneSmith. The script works quite nicely, especially since I am not a script writer. I wanted to put my images on separate pages in an ebook, to force the page break. BUT the resulting files each have the Pages Numbering and Section Options set to "Start Page Numbering at NN" ( where NN is the page number of the first page in the original section). So when the files are gathered into a book, all the new files have the same page number. The orginal file has the Automatic Page Numbering set, so not sure why this option gets changed. I can simply open each file and change the Page Numbering option, but it would be nice not to have to do that. Running 5.5. Any ideas?
G'day
I assume you're using the book feature in InDesign to recompile the pages into one document (?).
In which case you should be able to 'Update Numbering' from the book panel dropdown menu.
(although I would expect this to happen by default when you first add the documents to the book)
d.
Right. I am using the book feature to collect the pages into one document, in order to create a Kindle book. Without starting a new chapter, the only way to force a new page break in the exported ebook is to have a new file. Since pagination in an ebook is impacted by user settings (i.e. a large font size for reading), I can't always force the image and the associated caption to be on the same page (well, I could add the caption to the image in photoshop, and then it will be part of the image, but that doesn't always look right). If I force the page break with a new file, then I can effectively ensure the image and associated caption will always be on the same ebook page (unless they make the font really big!).
And yes, when I add documents to the book, each page normally gets renumbered, or I can also renumber with "Update Numbering." But also normally the default setting for Numbering & Sections Options (right-click on page in Pages palette or select Document Numbering Options from the Books panel pulldown) is "Automatic Page Numbering." But for some reason, this changes to "Start Page Numbering at nn" when processed by the script. In other words, if the multi-page doc is pages 41-50, and then I run the script, I end up with 10 1-page docs (exactly what I want), except on each of the new docs "Start Page Numbering" is set to 41. Update Numbering does not seem to reset this. I have to change the Page Number option back to Automatic and then Update Page Numbering works fine.
Running the script and then Changing the Page Numbering option in each doc is less work and less error-prone than manually breaking out each page, so I will happily take what I can get....
I'll have to play around with this. I haven't deliberately set sections, but my little bit of reading shows there may be something here.
I do wonder if part of the key to this is the line in the script:
If the current doc has the property "I'm on page 41", then wouldn't all new docs created have that property? (which is what seems to be happening). The Numbering & Sections Options dialog always seems to know the current page, so maybe ID regards that as a property?
To directly answer your question, from an ebook standpoint, pages don't really matter, so yes I could just let the ebook creation process (what you are calling recompiling?) run, but I am trying to create a dual purpose document. I work for a (very) small publisher and the other guy handles print, and I handle ebook. Eventually, we want to be able to create one ID doc that serves both purposes with minor tweaks (we aren't there yet).
With ebooks, the only way to force a page break is to start a new file. (Well, you can link a paragraph style to the HTML H1, but you only get to do that for one paragraph style. It's also how you create your ebook table of contents.) So you want your chapter to flow from start to finish, but you may want some things, like an image, to appear on its own page. That's why your script, to break up a bunch of image pages to ensure each appears on its own page, is so valuable.
I will keep playing with this. Maybe the light will dawn.
Yes, I looked at that the other day in the scripting dictionary, but nothing struck me as useful. I was looking for something to reset the automatic numbering.
But having another look at it today I found that you can add another line :
set start page number of dsDocProps to 1
This will still give you the first document as page 41 — but all the others will flow sequentially from that.
Then you only need to update the start page for the first document in the book (rather than all of them).
At least, that's the way it's working for me in CS6
Let me know how you go.
d.
Well, the short version is WOOHOO!
I turned off automatic page renumbering as it just slowed things down when adding the separate image pages back to the book. Adding the line above to the script caused all the new pages to be set to "1". BUT when I did a pull down of the Book pallette menu, and selected "Update Numbering", all the new docs renumbered just fine. I did not even have to update the first new doc. This script is going to be a biggie in my toolbox. Thanks!
Awesome — glad you got to where you were trying to go.
It's interesting that you are using this for exactly the same purpose as I originally created it — splitting docs up for ePubs.
That was a few years ago now and I found I still had to crack open the ePubs to fix them before re-zipping.
InDesign was plonking in a bunch of metadata that was causing the file to fail authentication.
Hopefully this is no longer a problem you have to deal with.
Have fun.
d.
