MatthewRawlings
My Plug-Ins won't load or be verified in the Effect Menu
Jun 26, 2012 9:56 PM
Tags: #plug #ins
I've tried numerous times to install many effects in After Effects, but none of them seem to work. I've put the file in the plug-ins sections, but they will never appear in the program. Is there any sort of fix for this?
    Jun 26, 2012 10:57 PM   in reply to MatthewRawlings
    And what effects? What version of AE? Sounds like the classic case where you are using 32bit versions in a 64bit AE and naturalyl that's not going to work. Make sure to install the correct versions as per the vendors' instructions...
    Mylenium
    Jun 27, 2012 12:03 AM   in reply to MatthewRawlings
    Yeah, but you still need to take care to use the correct 64bit versions. So again: Make sure you have the right ones.
    Mylenium
    Jun 27, 2012 2:16 AM   in reply to MatthewRawlings
    Sorry, but you are missing the point: If your vendor provides versions for PC and Mac, it means he would still provide 32bit versions and 64bit versions for both platforms - 32bit for CS4 and before, 64bit for CS5 and above. Why don't you simply tell us, what plug-ins you are actually referring to?
    Mylenium
    Jun 27, 2012 6:24 AM   in reply to MatthewRawlings
    Where did you get the plugins?  All of Red Giant plugins have installers which require serial numbers.  Optical Flares has an installer AND requires online activation. Without running the installers and following the activation process, the plugins won't work properly.
    If the plugins don't appear in AE at all, as Mylenium says, they are properly not the correct versions for the bersion of AE you have.
