103720
Dotted lines are showing
Jun 27, 2012 4:33 AM
First of all, I'm new to Indesign so I'm not an expert, and English is not my native language, so sorry if there are some mistakes in my English.
My question: I have made something in Indesign but when I export it to a pdf, the result shows some lines which I don't want (marked with the red arrows)lijntjes.jpg
In Indesign it also shows that lines but they are blue and I thought these where only guide-lines and would not be visible in the PDF
Is there something I did wrong or how can I make sure that those lines do not show in the PDF?
    Jun 27, 2012 4:39 AM   in reply to 103720
    What version of InDesign? What build? What kind of graphic is that? Is it a placed INDD file? What export settings did you use when creating the PDF?
    Bob
    Jun 27, 2012 5:02 AM   in reply to 103720
    When you've answered Bob's questions we'll know for sure, but it looks like a transparency flattening artifact called "stitching."
    If you look cloesly you'll see the lines in ID are, as you thought, the frame edge, but the lines in the PDF are further from the text along the bottom because they are bounding the area of transparency that is the drop shadow.
    Jun 27, 2012 5:20 AM   in reply to 103720
    There you have it…stitching.
    Why are you using Acrobat 4? Change that to at least 5.
    Bob
    Jun 27, 2012 7:29 AM   in reply to 103720
    Yup. The drop shadow is a transparency effect, and Acrobat 4 does not support transparency, so it gets flattened and shows the stitching artifact. If this is for a magazine ad or something similar tht will be output on press it should be OK, stitching generally is only visible on screen and in low-resolutuon prints. If you are not required to submit flattened PDF, then Acrobat 5 or higher compatibility will keep the transparency live and eliminate the problem.
