acrodist.exe application error
Jun 25, 2012 11:36 PM
Tags: #pdf #acrodist.exe
I installed Adobe Acrobat 7.0 successfully. But when I convert a word file into PDF file, a error message pop-up as " AcroDist.exe application error --- the instruction at "0x0048C9e5" referenced memory at "0x0190eb6c", The memory could not be "read" Click on OK to terminate the program "
If I click the program Acrobat Distiller, the same message box shows up.
I tried to uninstalled and re-installed. Couldn't solve the problem.
need help.
    Jun 26, 2012 5:24 AM   in reply to shan627627
    What OS? How were you trying to create the PDF?
    Jun 26, 2012 11:52 AM   in reply to shan627627
    Please clear the Windows Temp location on your machine and see if that works for you.
    Jun 27, 2012 5:59 AM   in reply to shan627627
    What Operating System. From the response, I assume it is XP. AA7 should work fine on that one. I assume there are no 64-bit uses (not common with XP). For a test, try selecting print-to-file. After that file is created, open it in Distiller to create the PDF. How does that do the job?
    Jun 27, 2012 8:24 AM   in reply to Bill@VT
    You can try to increase the virtual memory of your machine. Here are few things, you can try- Remove Acrobat using Adobe Acrobat cleaner tool and re install Acrobat in a new admin account.
    Cleaner tool link : http://labs.adobe.com/downloads/acrobatcleaner.html
    Hope that helps.
    Aug 5, 2012 7:04 PM   in reply to shan627627
    This problem came up on my laptop today and I have found a solution, at least on mine. I was getting the exact same error as above (with different memory locations) when I tried to start Distiller (Acrobat 7.0). It had worked fine for years. On mine it was limited to my specific user account. I could run Distiller fine from the Administrator account. I also created a new standard user account to test with and it ran fine from that one as well. But it wouldn't run from my personal account. So I knew it was something with that specific account.
    To make a long story short, it ended up being a corrupt cache. You can find the cache in the following location:
    C:\Documents and Settings\[your user name]\Application Data\Adobe\Acrobat\Distiller 7\
    What I did was just rename the old cache folder and let distiller recreate it. That fixed it. Good luck.
    Aug 14, 2012 9:23 AM   in reply to shan627627
    I had this issue as well and resolved it by setting the Application Data folder properties (and all subfolder and files) to read/write and not hidden.  Once completed the Application Error was gone!
