tlcano
Remember Paste Location?
Jun 27, 2012 1:30 PM
Tags: #indesign_cs6 #mac_os_x_10.7.4
Hello-
We prepress several stores, and then place them on a larger document for output. The layouts are imported into existing picture boxes, and there are color bars between, so they must be placed precisely within the box. In Quark, I was able to circumvent this by modifying the location of the imported files, deleting, and saving this new location in my template. This doesn't seem to work in ID (we are using CS6). Is there a way to control this? I know that we can use Paste Into to get a second copy to use the same formatting as the previous file, but if every store is different, that won't help us (the box doesn't remember the location if another layout is imported there). Any other suggestions? Am I missing a basic keystroke, or is this something that would need to be done through scripting?
    Jun 28, 2012 11:57 AM   in reply to tlcano
    I'm pretty sure I'm not understanding the question. Can you give us some screen shots?
    Jun 28, 2012 12:23 PM   in reply to tlcano
    Yeah… that would go for me too… There is a paste in place ( edit menubar ) and every box has it's own frame fitting options… ( object menubar/fitting/the last entry… ) Have you tried these out?
    Jun 28, 2012 1:05 PM   in reply to tlcano
    Are all of these coupons the same size?
    Jun 28, 2012 1:25 PM   in reply to tlcano
    So why not jsut select all the frames on your template and set the fitting options to fit content proportionally or center content?
    Jun 28, 2012 1:38 PM   in reply to tlcano
    Ummm. Have you considered resizing and/or reposition those frames inthe template so it does work?
    Jun 29, 2012 2:12 AM   in reply to Peter Spier
    If you are updating/replacing previously placed and positioned images/graphics and the replacement is the same bounds just drag n drop it in over the top…
  • Rob Day
    Oct 16, 2007
    Jun 29, 2012 5:41 AM   in reply to tlcano
    If you are using OSX try the script linked in this thread
    http://forums.adobe.com/message/4248435#4248435
