I'm hoping someone at Adobe can address the numberous bugs and general slowness in Photoshop CS6.
Before installing (MacBok Pro 2010 Intel i7, 8GB Ram) I whiped my drive and installed OS Lion. So CS6 went on clean.
What I'm finding:
1. General slugishness all around.
Layered PSD files I was using just fine in CS5 are now extremely slow. An examle is a small (20mb) web design file. So it has many layers (maybe 200, not 2,000) mostly comprised of typographic elements—not many layered effects to speak of. Not many image layers, either. Layer folders are slow to move, folders can't be moved using the shift + arrow key consecutive times, making it difficult to move a range of folders xxx pixels to the left, for example.
Things that were pretty snappy before, are now slow. This is very similar to the problems I and many others saw with the initial relase of CS5—in the next version (12.0.1 I think?) Adobe fixed the issue.
2. Problems with type, example keybaord arrow keys stop working many times when toye is selected. Frustrating.
More of a general rant here, but insted of (at least in addition to) a lot of other 'features' like video in PS extended (why not use Premiere?), 3d, etc., it would be really smart for Adobe to make core elements work better: A big complaint among interactive desigers is that type renders so poorly compared to CSS html. Maybe this could be addressed, as photoshop is used for the design of most all websites.
I have this general sluggishness issue as well, it's insanely frustrating. I upgraded from CS4 to CS6 and I am regretting it at the moment. Photoshop CS6 will produce a spinning beachball for 10-30 seconds when I simply try open a tiny 1.5MB file, or try to save a file. This is stuff that happened without a single bat of an eye in CS4. I even bit the bullet and upgraded my RAM from 4GB to 8GB thinking that might be the issue, but it really hasn't impacted anything. I've played with the performance settings as some on these board suggest (ie. Cache levels are at 4, RAM is at 65% of 8GB, drawing mode is at Basic as I find the Normal setting to make things even more sluggish).
Seriously, I've spent a day and a half in some sort of spinning beach ball limbo over the most trivial files and file sizes - I have the hardware to support this stuff, and it all used to work pretty smoothly in CS4. Why isn't CS6 just working so I can get on with work?! ![]()
Specs, for the record: MacBook Pro (model 7.1), 2.4GHZ Intel Core Duo, 8GB RAM, NVIDIA GeForce 320M graphics card.
I even checked to see if there are new drivers for my graphics card, but there are not. Any advice on how to get my new snazzy PS6 going smoothly would be grand.
Both of you seem to be working with smaller files (size in MB) with lots of layers. One thing that has changed from CS4/CS5 to CS6 is the default tile size for some systems with multiple processors and a good amount of RAM. I would suggest going to the Performance preferences and changing the tile size from 1024K to 128K. This will help speed up opening your files and should make working with those "web" files much better.
I will do what you suggest, but 1) my tile size was already set at 132K, and 2) in my most recent spinning beachball case it was just a 1.5MB JPG one-layer photograph that caused the issue. Any other tips? I am really happy there there are Adobe employees on this board adressing these questions by the way. Thanks for looking into this - I'm no software technician, I'm just a grapahic designer! I don't know how the guts of these programs work, or much about the performance levels, etc!
Just a small point in answer to your comment that "type renders poorly compared to CSS HTML"...
Understand that in most browsers, the rendering engine has information about the actual display the type is being rendered upon, and is taking advantage of things like knowing the colored columns on the display are in a particular order to enhance the font smoothing results. Photoshop has no such knowledge of the final display, and thus cannot use color to an advantage during font rendering. That said, being able to force it to do so under certain special conditions would be a nice option.
-Noel
thanks for the tips. i do appreciate it. turning off thumbnail previews immediately helped the issue of not being able to move a folder set with cmd + arrow. previously, i would get the nudge tool filter dialog, and after a 3-4 second pause, the layer set would only move 10px, regradless of how many times I keyed the arrow key.
my tile size was set to the default of 128k.
looking forward to 13.0.1 soon.
Hi Chris,
Again, I have ONLY been experiencing sluggishness in CS6 and nothing has changed in my system setup between CS4 and CS6.
I have to most up to date video card driver for my computer (NVIDIA GeForce 320M). There is no further update available for this card from NVDIA. It never caused a problem on CS4.
I do not run any anti-virus programs, being on a mac, which nixes the bad anti-virus software (Norton) option.
I have no third party plugins installed in photoshop that I know of (though how can I be absoultey sure of this?)
And it's interesting you mention corrupt fonts:
1) The files I am opening that are causing the beachballing don't have font layers on them
2) merely clicking on the type tool in CS4 would immediatley throw down the "Cannot complete your request due to program error" window and I would have to force quit photoshop, though in CS6, the type tool actually works. I manage my fonts with Font Agent Pro and only have ~40 fonts activated at any time. None of those fonts are corrupt.
Any other ideas? What could I be missing here? I'm still in spinning beachball land....beginning day 3 now....
Comparing to CS4 doesn't tell us anything -- too many API changes (Cocoa), too many added features (OpenGL, OpenCL, etc.).
Font Agent Pro could be part of the problem, and has caused slowdowns in the past.
And it could still be a corrupt font, see http://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop-cs5.h tml for tips on troubleshooting the fonts.
Dear All Adobe Employees,
Thank you for replies, but PLEASE
Think twice before putting all the load on customers' side
As a client I can't accept any excuse from adobe while i do have two versions of the same product, the old version works smoothly and the latest needs a lot of procedures, steps, requirements and more to give me the chance to test if it will be better a little bit or not
All what you need to do is Appologizing And telling us about estimated date for updates release
Many factors outside of Photoshop could cause a slowdown or problems in a new version but leave older versions running just fine. Things like antivirus software, driver hacks, third party plugins, etc. And those are not things that Adobe can address. We see this with every release of Photoshop -- and we have to track down all the external factors that need to be removed, updated, etc.
You have a problem on your system. That does not mean that there is a bug in Photoshop, or that other people are seeing the same problem. It just means that there is a problem on your system. Since we do not see the problem, and do not have your system to diagnose, you will need to do some troubleshooting on your system to identify the cause. We've listed known problems -- now you need to rule out those known causes, see if there is something new going wrong with your system, then figure out what that might be.
Some things need to be stated, I think.
1. You're not dealing with some smooth talking marketing department here. Chris Cox and the other engineers who help here are substantially the ones that arrange the 1s and 0s in the code itself. They speak plainly, and while most folks who know them realize they get directly to the point, folks who don't realize the special level of communication we have here might think the Adobe folks are abrupt or evasive. Let me assure you they're neither. It is uncommon to have this level of access to engineers at a big corporation, and encouraging them to be here is one of the things Adobe does right. Very right.
2. Adobe's software uses and stresses your computer like no other software - not even the previous version of Adobe's software. They have provided you with cutting-edge graphics technology in the latest release, and the state of the art is that your computer system is both extremely complex and the operating system and driver software on it does not all work perfectly (not even a Mac). We see again and again, for example, that display drivers are hard put to work perfectly... There are certain "golden" releases of drivers that work well - and others that just plain suck.
What you may not realize is that there are already multiple levels of fallback inside the Adobe software. Some of them are automatic, and some you have to choose via preferences. Adobe really can do no more to try to ensure their software works around the glitches on your particular system.
-Noel
I do appreciate that Chris is answering and helping to identify issues that may pop up with this new release. I can't begin to imagine the complexity of programming a major software title such as PS.
I think for many people like myself who are working on Laptops (MBPro) we really cannot upgrade to a new Video Card to fully appreciate the new features.
With this said, I have had to return to using Photoshop CS5 do to the slowness of the program. Simple things such as editting text, turning on/off layers ( which I have tried keeping on only the layer being used when possible ) saving files, and many other daily tasks have become so time consuming waiting for PS to process the command that I will not even try using PS CS6 until an update is released which hopefully will address some of these items.
Keep in mind I use PS for web design so many of the files I am working with aren't very large in my mind.
I have been trying to use the other CS Suite programs and they as thus far do not have any of these issues, save Illustrator which seems to be a tad slower but not enough to degrade to CS5.
I can't say I'm disappointed, but it is unfortunate I have to return to a previous build to get the same work done.
What I don't like as I've seen on many other PS Forum postings is the tone of some responses from Adobe reps saying "it's your system" or " you need to turn this, this and that off to make it run better". It should run just fine out of the box so to speak without having to go in and make edits and tweaks, many many users do not have this capacity either due to Company IT security or just plain software knowledge.
-Just my thoughts and I will say I look forward to the next release of updates.
Just for a bit of balance here... I upgraded from 64bit CS5 to 64bit CS6 this week, and it's flying along on my desktop PC - Windows 7 with a Radeon HD5570 (I GB RAM). The PC has 12GB of RAM. I'd say CS6 is about 20% faster and smoother than CS5 on my machine.
Under preferences in CS6 I have 7gb allocated for Photoshop (which is a lot). I don't really understand how the RAM between video card and PC RAM works, but last year I upgraded my card to the current one which has larger capacity. It's not cheap to do that, but it did give me better performance. Prior to upgrading it I also had problems with the Silver Efex Pro plugin - which also does a lot of graphics work. It too is OK now.
My System Information
Time of this report: 6/27/2012, 17:44:57
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
System Manufacturer: Acer
System Model: Aspire M5811
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz (4 CPUs), ~3.2GHz
Memory: 12288MB RAM
Available OS Memory: 12216MB RAM
Display Devices
Card name: ATI Radeon HD 5570
Manufacturer: Advanced Micro Devices, Inc.
Chip type: ATI display adapter (0x68D9)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_68D9&SUBSYS_E142174B&REV_00
Display Memory: 2761 MB
Dedicated Memory: 1006 MB
Shared Memory: 1755 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: SyncMaster P2450H(Digital)
Monitor Model: SyncMaster
OK, something is really wrong on your system.
A few people are seeing big slowdowns across the app -- most have been traced to video driver bugs, third party software (like anti-virus), permissions errors, and sometimes older third party plugins.
But most people are not seeing this. So, waiting for an update won't help.
We need to figure out what on your system is causing a slowdown that others are not seeing.
Are you running other software at the same time as Photoshohp? Try closing the other applications to see if one of them might be interfering.
Are you running third party plugins? Try disabling them.
Do you have third party fonts installed? Have you tried troubleshooting the fonts? http://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop-cs5.h tml
Do you have any utilitiy software installed that might interfere? Have you tried disabling it?
Hi guys - I'm also back at it with trying to troublesoot my CS6. For the most part it's fine but intermittently (oh, yes, THAT troubleshooting nightmare) it takes minutes upon minutes to open a file or close a file, or sometimes execute a command. It's sort of to the point that I force quit, relaunch, and usually the file will open or close faster the next time.
- what is a third party plug in and how can I see if I have any installed?
- what kind of utility software are we talking about? how can I see if I have any installed?
I will troubleshoot fonts this afternoon. I really, truly appreciate all the help from Adobe staff, though I also chime in with the seniment that it's too bad PS CS6 doesn't just work right out of the box. I appreciate that there's lots of variables but this particular upgrade has been pretty painful for my working life. I also have a MacBook Pro and I can't just go and upgrade the video card, if that's what's suggested in the end.
Anyways, I'll get started on fonts, if someone can let me know about the two about Qs we'll see what can be done. ![]()
Help - System Info will tell you what plug-ins are installed. As I recall the list of 3rd party plug-ins is at the bottom.
Photoshop CS6 works right out of the box for most folks (I know I haven't had any problems). I know something of what's going on under the covers... Between supporting two totally different platforms (Mac/PC), considering all the variations between systems (think "no two alike"), and considering the complexity of this state-of-the-art image manipulation software, it's kind of amazing it works as well as it does on as many systems as it does.
-Noel
Understood, Noel! It just sucks that my machine happens to be one that's cranky about upgrading!
SO, Help - System Info tells me: Optional and third party plug-ins: NONE
I have troubleshot my fonts, with no erroneous results. Someone mentioned earlier in this thread that the issue may actually lie with FontAgent Pro? How can that be, it's worked so well for years?
Also, what sorts of utility software should I be looking for?
Thx
vikki
I wanted to chime in again. I have a clean system all around. I reformatted my drive (MacBook Pro 2010, 8GB ram, 7200 speed HD) with Lion. So no concerns here about old CS bits and pieces floating around. Also, no antivirus software installed, nor 3rd party plug ins, all typefaces are clean based on the Adobe problem type script.
What did help speed and performance for me was turning off layer previews. Really helped!
But it would still be good to find out about known bugs. I haven't seen such a list anywhere.
For example, for me:
1. When I place Illustrator CS6 art into PS as a smart object, it places at an odd scale, like 99.821% x 100.51. (Initially on paste the toolbar reads 100%, but as soon as 'return' is slected to place the art, non-proportional scaling occurs. Very odd.
2. Keyboard controls not working with the type tool, and it seems other tools as well. So arrow keys won't work, I've also noticed that tool shortcuts will stop working at times. Very frustrating working with type!
Any way to inform us on known bugs, and a timeframe for the next update?
I hope you can figure things out to make it run better. We have been using CS6 since the beta and have only seen slowdowns due to video. We are one of users that is SOO happy that they added in video editing into this new version. We are an online retailer that edits hundreds of stills per day and were trying to find a better way to integrate more video. This solved everything! We can now edit videos inline with our stills and use actions as if they were stills. Amazing!
Anyways, we have found that we do get slowdowns occassionally. A quit and restart of Photoshop usualiy does the trick but we do sometimes have to do a full computer reboot, though we I don't recall having to do that since using the Beta. Ramping up the RAM used in preferences should help too.
I think Chris is going to have to answer that, because it was he who asked. I assume he means anything that you've installed on your system that isn't a pure "application" - e.g., desk accessories or other software designed to enhance your computing experience and which could be running at the same time as Photoshop.
-Noel
1) is because of the snap to pixel behavior (can be turned off in preferences)
2) Seems to be somethign external -- still being investigated with other users.
What sort of utility software: literally anything that isn't part of the stock OS and isn't an application. Font Agent Pro is a font management utility, for example. Dropbox is a file syncing utility. etc.
I have 'snap vector tools and transforms to grid' turned off in prefs. unless you mean another preference? also, i was under the impression this only applied to vector tools and transfroms, as menioned in the name. not smart objects, which i am referring to. either way, with it turned off, i still get odd scaling.
Julienlanoo, you should know that's not true with every machine. Something may be specifically amiss with yours, making it less compatible with Photoshop CS6 than CS5. I find Photoshop CS6 slighly faster than CS5 on the same machine for most things myself. Many things can contribute to problems, for example outdated drivers. Photoshop has a number of fall-backs coded on the general principle of "if it can't work fast using all the latest goodies, it should at least work slowly". So for example if it can't find a way to use the GPU on your video card, it uses the (slower) CPU instead.
-Noel
Ok, and how can you know that - Test it ? I mean,
I've turned off all the pluginns, i've turned off time machin, i've turned off all the plugins i've got, .. It's a new computer, with mac os X 10.7, 2.7 ghz quad i7 16 GB of Ram, AMD Radeon HD 6630M ?.. What would you like me to have so it works fine ? ..?
" like i hadn't expected the "it's your computers fault" awnser..
When checking the requierments of PSCS6 i am well in...
P.S. -> The efficiancy tag , bellow the image gives 100% value ..
Only a handful of people seem to be seeing CS6 run slow. And we don't know why, and have not been able to reproduce that slowdown at Adobe (despite testing on thousands of configurations).
So, the obvious suspect is that there is something about your system configuration that causes or triggers the problem.
But we don't know what that might be because we don't have your system to know how it is different from the millions of systems running without a problem.
The fact that you have a new, powerful workstation says loudly that there's a bug somewhere.
If I were a betting man I'd say that the display driver that Apple has released for your particular hardware is lacking in function to allow Photoshop to fully accelerate all its functions. There have been problems with AMD/ATI drivers on PCs up until VERY recently as well.
I'll go out on a limb and predict that an OS update will come out that will suddenly make your system more responsive.
-Noel
mhm i gave the poor thing a chance the last few hours...
When "use graphic Processor" is clicked off, then it works ok;.. Not that supper duppa faster than CS5.5 but the same... That's ok for me for now, as it's much more pleasant to work in CS6 than in the 5.5,... W8ing for update from apple..
