Hi Folks,
I've got a form which uses fragments.This form previews fine in the designer, but when I try to run it using generatePDF Output in a process, the parts that come from the fragments are gone.
The following entries are in the log:
2011-03-04 10:27:19,482 WARN [com.adobe.document.XMLFormService] ALC-XTG-016-649: [1160] Error attempting to read from file
2011-03-04 10:27:19,482 WARN [com.adobe.document.XMLFormService] ALC-XTG-029-698: [1160] InvalidSourceException Exception on URL: repository:///Header_Block_Variant2.xdp Exception: javax.ejb.EJBException: An unexpected exception occured: ALC-REP-018-000: Resource [/Header_Block_Variant2.xdp] does not exist or you do not have sufficient rights to access it.
2011-03-04 10:27:19,482 WARN [com.adobe.document.XMLFormService] ALC-XTG-029-217: [1160] Bad value: 'Header_Block_Variant2.xdp#som($template.Header_Variant2.Header)' of the 'usehref' attribute of 'subform' element ''. Default will be used instead.
2011-03-04 10:27:19,482 WARN [com.adobe.document.XMLFormService] ALC-XTG-029-418: [1160] XMLForm, PAexecute : 29418, Cannot resolve url: Header_Block_Variant2.xdp.
2011-03-04 10:27:22,591 INFO [com.adobe.idp.dsc.provider.service.file.write.impl.FileResultHandler Impl] FileResultHandlerImpl ----- preserved- source
Does anyone have any idea what the problem might be?
Vincent
I suspect its the path to the fragments.
The error says LC is looking for the repository:///Header_Block_Variant2.xdp fragment. That looks a bit odd as the fragments aren't generally stored at the repository root. Generally they are in an application or a sub directory under an application. For example if I have an application called myApp which contains a folder called fragments, the path would be: repository:///myapp/fragments/Header_Block_Variant2.xdp
We also have an application where the fragments are stored in a subdirectory from the application. When we run that process, the serverlog show this:
2011-03-04 15:25:53,325 WARN [com.adobe.document.XMLFormService] ALC-XTG-016-649: [1160] Error attempting to read from file
2011-03-04 15:25:53,325 WARN [com.adobe.document.XMLFormService] ALC-XTG-029-698: [1160] InvalidSourceException Exception on URL: repository:Fragments/Header_Block.xdp Exception: javax.ejb.EJBException: An unexpected exception occured: java.lang.ClassNotFoundException: No ClassLoaders found for: com.adobe.repository.RepositoryException
2011-03-04 15:25:53,325 WARN [com.adobe.document.XMLFormService] ALC-XTG-029-217: [1160] Bad value: '..\..\Fragments\Header_Block.xdp#som($template.Header.Header)' of the 'usehref' attribute of 'subform' element ''. Default will be used instead.
2011-03-04 15:25:53,325 WARN [com.adobe.document.XMLFormService] ALC-XTG-029-418: [1160] XMLForm, PAexecute : 29418, Cannot resolve url: ..\..\Fragments\Header_Block.xdp.
2011-03-04 15:25:54,341 INFO [com.adobe.idp.dsc.provider.service.file.write.impl.FileResultHandler Impl] FileResultHandlerImpl ----- preserved- source
As you can see, the path starts with ..\..\Fragments\etc
Which I interpret as, go 2 subdirectories up and than go into the Fragmenst directory and get the fragment.
Vincent
Assuming you launched Designer in Workbench and used that to add the fragments to the template, then the relative paths should be alright. What you need to add is some information to tell Output where to start with the relative paths.
In your generatePDF call, under Template Options there is a Content Root URI field. Output uses this, along with the paths in the form template to find the fragments. The Content Root URI should point to the form template (not the fragments).
For example. Say I have an application called GeneratePDF_Test v1.0 which has both a Fragments and a Forms directory. Using Designer I create a new form and add the fragments from the Fragments directory. Designer sets up my relative paths for me. I save the form to the Forms directory.
In the generatePDF step I set the Content Root URI to:
repository:///Applications/GeneratePDF_Test/1.0/Forms/
Now Output knows where to start the relative paths so it can find the fragments
