Hi everyone. I will try to keep this as simple as i can.
I'm trying to use the setFocus method for highlighting the default text in a text input field.
So bascially when user clicks on that text field - the text is highlighted and they can type over it. Currently have about 16 text fields with something akin to 'insert text here' as a prompt for our lower ICT demographic of users and it's a bit tedious to expect the user to highlight the text in each field and then type over it.
Can be performed awesomly if you tab through the text fields but I would not expect many users to use this method.
I've looked around on the net for solutions to this using as3 but I haven't found anything that has worked for me. I'd be very grateful for a suggestion or a point in the right direction....
If you want to have clicking a textfield end up with the text inside it selected, try the following...
tf1.addEventListener(MouseEvent.MOUSE_UP, selectText);
tf2.addEventListener(MouseEvent.MOUSE_UP, selectText);
tf3.addEventListener(MouseEvent.MOUSE_UP, selectText);
etc...
function selectText(evt:MouseEvent):void {
evt.currentTarget.setSelection(0,evt.currentTarget.length-1);
Thanks Ned...did the trick
Although I'm not sure what you mean about the 'lenght-1' but - I jsut got rid of the -1 as it was not selecting all of my text.
Also I think I'm going to set up an array and run a for while loop to assign the functions to all of my textfields - there are about 19 of them!
There is now way I'm going to set up all the even listeners for all of them individually.
Cheers.
