SROBBD
Error Message: Missing MSVCR71.dll
Jun 28, 2012 5:41 AM
Tags: #encore #msvcr71.dll #digital_juice #the_juicer
Having an issue with Adobe Encore not opening due to an error message: (The program can't start because MSVCR71.dll is missing from your computer. Try reinstalling the program to fix this problem.) I had this exact issue a while back and it was after a bunch of research a direct correlation between Encore and Installing or updating a program called The Juicer by Digital Juice. Unfortunately I cant remember what I had to do, but I recently updated The Juicer and am having the issue again. Any help would be great??
    Jun 28, 2012 5:53 AM   in reply to SROBBD
    Sometimes the other QT components might make it difficult for Encore on a system.
    Try copying The msvcr71.dll and msvcp71.dll from the Adobe Bridge folder (generally found at  C:\Program Files (x86)\Adobe\Adobe Bridge CS6) to Adobe Encore folder.
    Let us know the results.
    Ramesh.
    Jun 29, 2012 5:31 AM   in reply to SROBBD
    You are always welcome.
    Glad that you can work with Encore.
    -Ramesh.
    Jun 29, 2012 4:48 PM   in reply to SROBBD
    That is great news!
    if you have a moment, you might want to mark the thread as Answered. That will help others, who visit the thread later, and will help Adobe do a better job with the forums.
    Good luck, and happy authoring,
    Hunt
    Jul 1, 2012 10:47 AM   in reply to SROBBD
    My bad. The term that I should have used was "Correct," and that takes care of it.
    Thank you,
    Hunt
    Jul 9, 2012 3:22 PM   in reply to Ramesh_Encore
    Hi
    I've also just had this issue, and the suggested solution worked for me too, so thanks for that
    Can anyone explain why it suddenly failed?  I was trying to write a DVD when everything locked up and I couldn't even switch the machine off
    Jul 9, 2012 3:38 PM   in reply to PmPhotographic
    Do you have the Juicer program? According to the original poster, it was a Juicer update that resulted in the problem.
    Many issues result from an update to one program or another deleting or changing a file that is needed by other programs.
