hello every one
var rightArow:Boolean;
var leftArow:Boolean;
var upArow:Boolean;
var downArow:Boolean;
var speed:int = 10;
stage.addEventListener(KeyboardEvent.KEY_DOWN, keypress);
stage.addEventListener(KeyboardEvent.KEY_UP, keyrelease);
stage.addEventListener(Event.ENTER_FRAME, everyframe);
function keypress(event:KeyboardEvent):void {
if (event.keyCode == Keyboard.RIGHT) {
rightArow = true;
if (event.keyCode == Keyboard.LEFT) {
leftArow = true;
if (event.keyCode == Keyboard.UP) {
upArow = true;
if (event.keyCode == Keyboard.DOWN) {
downArow = true;
function keyrelease(event:KeyboardEvent):void {
rightArow = false;
leftArow = false;
upArow = false;
downArow = false;
function everyframe(event:Event):void {
if (rightArow) {
if(plyr2.hitTestObject(r1)||plyr2.hitTestObject(r2)||plyr2. hitTestObject(r3)||plyr2.hitTestObject(r4)||plyr2.hitTestObject(r5)||p lyr2.hitTestObject(r6)||plyr2.hitTestObject(r7)||plyr2.hitTestObject(r 8)||plyr2.hitTestObject(r9))
plyr2.x -= 2;
else
plyr2.x += 2;
if (leftArow) {
plyr2.x += 2;
else
plyr2.x -= 2;
if (upArow) {
plyr2.y += 2;
else
plyr2.y -= 2;
if (downArow) {
plyr2.y -= 2;
else
plyr2.y += 2;
i have used the above code to check hitTest and stop the object where the collision is detect. well... this is working..but not in proper way....
when i press right arrow my object moves in left side....and whenever it goes out of road_mc(i.e. r1, r2...r9) it works fine...that is moves right side...
i need solution for this.. plz help me.
Hi. I have tried to update your code. It is definately some Wild-West code, and I have to emphasize, that this answer is not the proper way to do it :-)
The main problem with your solution is, that you are using hittest on a clip that you want to be on. This hittest gives false, when you are out of the tile, and you then have a lot of trouble getting back in again.
The code I made was this:
import flash.display.DisplayObjectContainer;
import flash.display.MovieClip;
import flash.geom.Rectangle;
var upArow:Boolean;
var speed:int = 5;
var road:Array = ["r1","r2","r3","r4","r5","r6","r7","r8","r9"];
if (event.keyCode == Keyboard.RIGHT) rightArow = true;
if (event.keyCode == Keyboard.LEFT) leftArow = true;
if (event.keyCode == Keyboard.UP) upArow = true;
if (event.keyCode == Keyboard.DOWN) downArow = true;
updatePos();
if (event.keyCode == Keyboard.RIGHT) rightArow = false;
if (event.keyCode == Keyboard.LEFT) leftArow = false;
if (event.keyCode == Keyboard.UP) upArow = false;
if (event.keyCode == Keyboard.DOWN) downArow = false;
function isInside(element:*, index:int, arr:Array):Boolean
var plyrPos:Rectangle = plyr2.getBounds(stage);
var base:DisplayObjectContainer = stage.getChildAt(0) as MovieClip;
var tmpRect:Rectangle = MovieClip(getChildByName(element)).getBounds(stage);
if(tmpRect.containsRect(plyrPos))
return true;
return false;
function updatePos():void
if (rightArow)
plyr2.x += speed;
if(!road.some(isInside))
while(!road.some(isInside))
plyr2.x -= 1;
if (leftArow)
plyr2.x -= speed;
plyr2.x += 1;
if (upArow)
plyr2.y -= speed;
plyr2.y += 1;
if (downArow)
plyr2.y += speed;
plyr2.y -= 1;
I placed all your movie clips inside an array, so I could use the Array.some() method. It uses a function on the array, and keeps iterating until it reaches a true in return. You can read about it at http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/Arr ay.html#some()
In the function isInside() I make two rectangles, and test for their bounds. The Rectangle class has a ot of useful methods like Rectangle.containsRect() that test to see if a rectangle object is fully contained inside another object. Read about it at http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/fla sh/geom/Rectangle.html
The last thing I can mention is that I made a cosmetic while loop, that subtracts 1 pixel from your player, so the rectangle fit perfectly to the edge of the squares. Because of different sizes, you may end up with a player that can't go all the way to the edge.
Please note, that this method calculate on rectangles, so if you have very odd-shaped elements you may look for other solutions.
I have made a working solution that you can see at:
http://eksempler.hjaelpmignu.dk/wwwhelp/flash/road.html
You can get the fla-file at:
http://eksempler.hjaelpmignu.dk/wwwhelp/flash/road.fla
Good luck
/ockley
