How to set Document Properties by default for all PDFs
May 31, 2012 1:44 PM
Tags: #settings #view #properties #document #default #title #author #initial
Is there a way to edit the author, Title, Description, Copyright stuff and set it for the default in the future?
For example, rather than it saying my login name as the author, it is set to be our company name for all PDFs created in the future?
Also if I can hav ethe initial view be set to the page and bookmarks panel.
Lorne
    May 31, 2012 5:56 PM   in reply to lorne17
    Hi Lorne,
    How do you create these PDFs? If you convert them from applications like MS Word, you can set these options (author, title, description etc.) in MS Word and then convert the document to PDF. Once the settings are saved in MS Word, they will always appear in the PDF Document. This is just an example. You can set these settings in other applications as well. Because each conversion may have different description or title, Adobe Acrobat shouldn't control this. For anything or everything that you do in Adobe Acrobat, for example, signing the document or adding comments to it, information saved under Edit Menu->Preferences->Identity is used.
    Apart from this, if you want to modify this metadata after conversion you can go to File Menu-> Document Properties-> Description-> Additional Metadata and Add the information. By Default Acrobat takes the Login Name from the LDAP, thats your login ID.
    Answer to your second question is Yes. You can set it to the document (or a bunch of document together). Go to File->Document Properties->Initial View and Select the options under Navigation Tab. If you want to apply these settings to multiple document select this option in Action Wizard and apply the settings to multiple PDFs. To do this, File->Action Wizard->Create New Action->Document Processing->Set Open Options->Click on Options and Set the initial View. then you can run this action on multiple files/folders.
    Feel free to write back for more information.
    ~Sandeep V.
    Jun 1, 2012 9:53 AM   in reply to Sandeep V.
    Just to add to my last response:
    You can also add the information like Title, Subject, Author and Keywords to the PDFs that have already been created. Try this:
    File->Action Wizard->Create New Action->Content->Add Document Description->Click on Options and add the details.
    Now you can run this action on multiple PDFs.
    Jun 12, 2012 4:25 AM   in reply to lorne17
    If you are about to move to Windows 7 from XP, you are wasting your time creating metadata - you can't see it in Windows Explorer or My Computer!
    See my post about Windows 7 compatability.
    Jun 13, 2012 9:13 AM   in reply to Slate666
    Metadata can be used for a variety of purposes -- Search Engine Optimization is one of them for PDFs posted to the web.
    There is a suggestion on how to expose PDF metadata in Windows 7 in this post:
    http://forums.adobe.com/message/2666758
    Jun 14, 2012 1:25 AM   in reply to LoriAUC
    I have had a look at the suggestion on how to expose metadata in Windows 7 and given it a try.  Unfortunately, the data I need to look at is not indexed so I can't add it to a library.  I'm not sure what the upshot will be if I do index it - apparantly I have to make it available 'offline' - whatever that means.  It's a very large folder containing many sub-folders stored on our Windows 2008 server.  I don't really understand what it's going to do - I get the idea that it's going to create another large file.  Will it be stored on the server or the PC trying to index it?  What happens when people add to the folder in the future - will that automatically be indexed or will we have to do something?
    Jun 28, 2012 6:11 AM   in reply to Slate666
    Having discussed this with our IT people, indexing is not an option.  It would dramatically increase network traffic while PC offline libraries indexed with the server.
