android best practice
Jun 27, 2012 2:07 AM
When creating my indesign files for Android 1280x800 it's recommended to create pages at 1280x752 when just in landscape, like my files are. so that's what I've done.
Question, should I used the standard drop down of 1280x800 to create the new folio, or use a custom size of 1280x752....or doesn't it matter?
Cheers
Alistair
    Jun 27, 2012 5:07 AM   in reply to mobly
    1280x800.
    Bob
  • Bob Bringhurst
    May 29, 2007
    Jun 27, 2012 6:35 AM   in reply to mobly
    The aspect ratio of the source documents needs to match the folio's aspect ratio. If you're creating a landscape-only folio for Android tablets, create a 1280x756 folio, and create 1280x756 InDesign documents. If portrait-only, create a 1232x800 folio and 800x1232 InDesign documents. If both, use 1232x752 for folio size and document size.
    Jun 28, 2012 5:07 AM   in reply to mobly
    Yup. Haven't played with that in a while. All my work has gone to iPad.
    Bob
  • Bob Bringhurst
    May 29, 2007
    Jun 28, 2012 7:19 AM   in reply to mobly
    Typo. I meant 752.
  • Bob Bringhurst
    May 29, 2007
    Jun 28, 2012 7:29 AM   in reply to mobly
    If you use the same application ID for your iPad and Android apps, you should create renditions. All your iPad (and iPhone) folios show up on Android viewers.
  • Bob Bringhurst
    May 29, 2007
    Jun 28, 2012 8:36 AM   in reply to mobly
    If you set up renditions properly, only one rendition should show up in the viewer. Copy/paste the Folio Name and try again.
    Jun 28, 2012 9:20 AM   in reply to mobly
    Copy/paste is the safest way to handle this. No typos.
    Bob
  • Bob Bringhurst
    May 29, 2007
    Jun 28, 2012 10:05 AM   in reply to mobly
    If it's a retail folio, the Product ID values also need to be the same. If it's a subscription app, the Publication Date values also need to be the identical -- for each folio rendition, choose the same date from the Calendar widget in Folio Producer.
    Of course, the Folio Name values need to be identical. It's case-sensitive. Be careful about extra spaces.
Bookmarked By (1)
