StageVideo?
Jun 28, 2012 8:36 AM
Decided to work a bit with StageVideo today and not having much luck. Using CS6 and publishing to AIR3.2 I am getting unavailable when listening to the StageVideoAvailabilityEvent. Getting this on two different Win7 64 machines, both of which have good video cards. Anyone know what I might be doing wrong, or why I might get unavailable?
    Jun 28, 2012 8:49 AM   in reply to dmeN
    To make sure stage video will be available, you must use wmode="direct" at all times.
    Jun 28, 2012 9:07 AM   in reply to dmeN
    In AIR you can select a wmode o render mode
    Jun 28, 2012 12:39 PM   in reply to dmeN
    Maybe this direct
    I tried to compile the example from here:
    http://www.adobe.com/devnet/flashplayer/articles/stage_video.html
    But I'm not home and the machine I have at the moment is really very old, and I also say unavailable
    Calculating status...
    Jul 17, 2012 3:56 PM   in reply to dmeN
    Any luck yet?
    Having the same problem. When testing in the browser it works fine, but when debugging in Flash Builder or CS6 it's unavailable..
    Jul 31, 2012 12:31 AM   in reply to Timbowicz
    StageVideo is not available in AIR for Windows. According to the Flash roadmap, it won't be available on Windows until 2013.
    And unless they change things, you would set the render mode ("Direct") in the AIR Settings window, not the Publish Settings window. They're two different things.
