Export to media with mono audio
Jun 28, 2012 8:47 AM
Tags: #cs5 #help #audio #sequence #export #premier
I am working on a project that is using footage that has been recorded to the camera in stereo using both tracks, and in stereo using only the left track. I am a novice with Premier Pro and wondering how to export this project to media with the audio in mono. I need to export it as a SD file for Vimeo, and also as a MPEG2_DVD.
The church I'm doing the project for has complained that when playing the video through their projection system that all the audio that was recorded to only the left track was not playing when I exported the files as stereo.
The project also has other audio tracks (background music, etc) that are stereo.
Thanks for your help
I am using Premier Pro CS5
    Jun 28, 2012 9:37 AM   in reply to howmanyscreennames
    You can use the Fill Left/Right method, or create a sequence with a Mono Master track.
    Jun 28, 2012 11:04 AM   in reply to howmanyscreennames
    Think of Fill Left as “fill from the left,” and think of Fill Right as “fill from the right.”
    Jun 28, 2012 11:10 AM   in reply to howmanyscreennames
    If the Audio Streams are identical, EXCEPT are 180 degrees out of phase, then they will cancel each other out. The Fill Left/Fill Right will not reverse the phase.
    Glad that it worked for you and good luck,
    Hunt
