As a new PC owner I wanted to find out what the best software for doing full backups to external hard disk, to to be used to restore the system if primary primary disk crashes. Im aware that Windows, Acronis and Paragon all have software that doing varying degress of back and resore functions.
The product I use is at http://www.terabyteunlimited.com/image-for-linux.htm
Image runs off of a bootable CD via Linux (the Zip you download includes a program to make the bootable CD) and it reads EVERYTHING on the drive, even the hidden registration information, so everything is restored when needed... and you may restore the image to a brand new drive in case of a crash, and not have to re-install anything
Please note that I own no part of Image, and I don't get a referral fee (that is just a plain web link) but I use the program and it has saved me a LOT of trouble when I had a hard drive die... and I was able to restore everything and not have to re-install or re-activate a single program, from Windows on up
lasvideo,
My favorites are ShadowProtect to do an "image backup" of boot drive and Beyond Compare for backing up files for all other "data" arrays. ShadowProtect does not seem to have much market share compared with Ghost and Acronis, but I really love it.
What I like about ShadowProtect:
- Extremely fast (complete image backup for 61GB of files on my boot SSD RAID 0 array to a RAID data array takes less than 3 minutes)
- Can do image backups across a LAN; restores from boot CDROM and USB device
- Allows for backups from one controller and restore of OS on a different controller and/or RAID configuration (has HAL tools; Hardware ? Layer I think)
- Can "mount" an image backup as a drive letter and see (and copy) all directories, files, etc. that are contained in the archive
What I like about Beyond Compare:
- Can choose what to backup and what to ignore very easily (for example you can set it to ignore certain files or directory names to ignore and then save how you set things up as a "session")
- Only needs to copy over files that are new or have changed since your last backup
- Makes it very easy to selectively delete files from your backup
Jim
Thanks Jim and Harm! I appreciate your input.
It looks like at this point my needs are to be able to do a full back up of my system / apps drive to a USB3 drive and create a boot disk, to be used in case the C: drive is damaged or crashes.
From what little research Ivd done its seems Paragon will do that for me. As time goes on my backup needs may change and get more varied.
