Can't find a way to stop 3D rendering in Photoshop CS6!
Only with force quit...
Any idea?
As the others said, you should be able to stop rendering by clicking in the UI with any tool. Also consider setting a different high quality threshold in the 3D prefs to avoid lock-ups, at least while you test things. You can always switch back to a higher setting later and then give your machine enough time to render at best quality...
Mylenium
Some more details pointing out as a "hardware performance / software interrupt" problem bug:
On MacPro 3,1 [2x2.8GHz Xeon 16GB RAM]= no way to exit from render, no matter what you click. Only ForceQuit solve.
On Hackintosh [3.49GHZ Core i7 32GB RAM]= works OK. Stops immediately when you click.
Both same osX, same CS6 versions.
Asking for a more responsive UI feedback when in rendering. Reserve some CPU power to mouse action...
Thanks Adobe.
