venkat4adobe
button tool
Jun 28, 2012 9:02 PM
hi,
can we able to  create doc level button in tool bar?i want to create custom sticky note tool in my pdf,how it is possible?
please help me
Regards
Venkat
  • George Johnson
    Aug 11, 2002
    Jun 28, 2012 9:51 PM   in reply to venkat4adobe
    Yes. When you create a document-level button using app.addToolButton method, it creates a the button in a floating toolbar. Here's a link to the documentation: http://livedocs.adobe.com/acrobat_sdk/9.1/Acrobat9_1_HTMLHelp/JS_API_A croJS.88.134.html
  • George Johnson
    Aug 11, 2002
    Jun 29, 2012 12:05 AM   in reply to venkat4adobe
    If you place the code in a function, you have to then call the function so that the code it contains is executed. For example:
    function addMyButton() {
        // Code to add toobar button goes here
    // Call the function
    addMyButton();
  • George Johnson
    Aug 11, 2002
    Jun 29, 2012 1:51 AM   in reply to venkat4adobe
    You should post all of the code you're using if you want more help.
  • George Johnson
    Aug 11, 2002
    Jun 29, 2012 10:05 AM   in reply to venkat4adobe
    Why are you trying to add a menu item when you want to create a toolbar button?
    Jul 1, 2012 8:59 AM   in reply to venkat4adobe
    You can not add a menu item with a document script, menu items can only be added with a folder level script.
    addMenuItem
    addToolButton
    Jul 24, 2012 11:30 AM   in reply to venkat4adobe
    You can only add one button when you call the app.addToolButton method. You need to call it twice changing the parameters as needed for each specific button.
    // add first button
    app.addToolButton({
    cName: "myButton1",
        oIcon: iconStreamObj,
        cExec: "app.alert('You have clicked the JavaScript toolbar button1.');",
        cTooltext: "This is my button1",
        nPos: 0
    // add second button.
    app.addToolButton({
    cName: "myButton2",
        cExec: "app.alert('You have clicked the JavaScript toolbar button2.');",
        cTooltext: "This is my button2",
        nPos: 0
    Using the add button method as a document level script will create a floating button. It is a good practice to make sure you do not have duplicate tool bar buttons.
    Jul 25, 2012 11:12 AM   in reply to venkat4adobe
    Jul 26, 2012 6:29 AM   in reply to venkat4adobe
    You need to create an application folder level script that uses a function with the priviliged operation. See the
    Privileged versus non-privileged context and trustedFunction in the Acrobat JS API Reference.
    Jul 26, 2012 11:10 AM   in reply to venkat4adobe
    You can see all of the possible parameters for the addToolButton in the Acrobat JavaScript API Reference.
    Open the Navigation panel to see all of the Acrobat JavaScript documentation.
