Livecycle form
Avoid "Do you want to save changes to <filename> before closing?"
Jun 13, 2012 3:49 AM
When I open a reader enabled form and close it without doing anything it prompts "Do you want save changes to <filename> before closing?". How to get rid of this? I tried the below code in the layout ready event of a button but still no effect.
event.target.dirty=false;
event.target.requiresFullSave=false;
Any solution is greatly appreciated. Many thanks in advance.
    Jun 13, 2012 4:18 AM   in reply to Livecycle form
    You can create a close Button with this script in its click event.
    event.target.closeDoc(true);
    Jun 14, 2012 1:09 AM   in reply to Livecycle form
    The script you already use
         event.target.dirty = false;
    is the only way to avoid that.
    If it doesn't work, then because of any other script, that is executed also in the layoutReady event that causes to change the dirty flag back to true.
    Jun 29, 2012 1:36 AM   in reply to Livecycle form
    What's the other script you use and why?
    Jun 29, 2012 3:40 AM   in reply to Livecycle form
    The show/hide script in the layoutReady event is the problem as it dirties the form permanently.
    You should use another event to control the visiblity, like the change event.
    Jul 3, 2012 2:52 AM   in reply to Livecycle form
    Can you share your form please?
