I have managed to get a tating image working with the following javascript:
<script type="text/javascript">
(function() {
var rotator = document.getElementById('rotator');
var imageDir = '';
var delayInSeconds = 5;
var images = ['h-images/homepage.jpg', 'h-images/rentalspage.jpg', 'h-images/investpage.jpg'];
var num = 0;
var changeImage = function() {
var len = images.length;
rotator.src = imageDir + images[num++];
if (num == len) {
num = 0;
setInterval(changeImage, delayInSeconds * 1000);
</script>
the page is www.helenmarino.com/test.html (you may have to refresh the page)
I am surprised I managed to get this far so any simple code added to make the images fade nicely would be greatly appreciated.
many thanks
Helen
Here's one that might work for you: http://www.dynamicdrive.com/dynamicindex14/fadeinslideshow.htm
Thanks - this looks great.
Sorry but I am a real novice at javascript - only thing is the instructions are not that clear - I have opened the file - do I now save it in
the first head section of my html page?
Also I can't work out which bit I specify my images in? Or with the full version of the cycle how I determine it so I just have a fade option with the ability to scroll to next page?
Maybe this is beyond my limits? Are there any detailed notes on how to do this?
Download the Cycle plug-in script and save it to your local site folder. I prefer to keep scripts in my Scripts folder but that's up to you.
http://jquery.malsup.com/cycle/download.html
jQuery has 3 basic parts to it:
<head>
<!-- jQuery latest core library -->
<script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js">
</script>
<!-- Cycle plugin -->
<script type="text/javascript" src="Scripts/jquery.cycle.all.latest.js"></script>
</head>
<body>
<div class="slideshow">
<img src="image1.jpg" width="200" height="200" alt="description" />
<img src="image2.jpg" width="200" height="200" alt="description" />
<img src="image3.jpg" width="200" height="200" alt="description" />
<img src="image4.jpg" width="200" height="200" alt="description" />
</div>
<!--Cycle function code-->
$(document).ready(function() {
$('.slideshow').cycle({
fx: 'fade'
</script>
</body>
That's all there is to it. If you want anything fancier, look at Cycle's More Demos & Examples near the bottom of their home page.
Nancy O.
Thanks - I have:
1) Put this in my head:
<head>
</script>
</head>
2. Put this in my body:
<img src="h-images/homepage.jpg'" width="600" height="298" alt="description" />
<img src="h-images/rentalspage.jpg'" width="200" height="298" alt="description" />
<img src="h-images/invest.jpg'" width="200" height="298" alt="description" />
</div>
fx: 'fade'
</script>
3. Added the downloaded file and saved as a file in scripts folder.
You can now see the it on www.helenmarino.com/test.html (will need to refresh) - but I think I have gone wrong somewhere by not refering to where it should be on my html page? I want it where the current main image is.
Sorry for being such a pain - you have made this v easy to understand, I'm just missing what I should put where I actually want the image to go.
Many thanks - I will have another look now in the morning.
Helen
Everything looks fine except I don't see the jquery.cycle.js file on your remote server. Did you upload it?
404 Not found
Nancy O.
Hi Nancy
I started again from the start as I had not used a capital S for my scripts folder.
I saved the file under the Scripts folder as jquery.cycle.all.js
I then tried to uplaod it and got an error message:
file activity not incomplete. 1 file or folder(s) were not completed
Can you help please?
Hi Nancy
I can upload all my html files okay - it just seems to be this js one. I tried loads of times.
I have just moved it to my main folder instead of the scripts folder and it uploaded okay.
Some success then - if you refresh the www.helenmarino.com/test.html page then the images do appear now - but not in a slideshow and in the wong place?
Any comments please?
Helen
Boils down to a path/naming problem.
Change this in your page:
to this:
<script type="text/javascript" src="jquery.cycle.all.js"></script>
Nancy O.
From this page:
http://jquery.malsup.com/cycle/int2.html
fx: 'fade',
speed: 800, //speed in milliseconds
timeout: 3000,
next: '.slideshow',
pause: 1
</script>
Nancy O.
