Tip:  non-destructive texture
Jun 27, 2012 9:57 PM
If you're working on an image with a lot of layers, and you want to add some texture, instead of merging all the layers into a new one and applying the texture to that merged layer, you can:
  1. Create a new "Overlay" layer above the layers you want to have the texture.  You need to use Layer...New from the main menu bar and select the "Overlay" mode and the "Fill with neutral color" option.
  2. Apply your texture to that overlay layer.
For example:
For this image effect:
The advantages of doing this:
  • If you don't like the effect, you only need to delete that one layer to start again.
  • You can adjust the opacity of the layer to fine-tune the texture effect.
  • You can create more than one texture layer, using whichever texture is appropriate for the final output.
This works for the Filter...Noise...Add Noise, as well as several textures from the Filter Gallery, including Film Grain.
Ken
    Jun 27, 2012 10:50 PM   in reply to photodrawken
    That's a nice tip Ken.
    Also if you want to use one the preset patterns, one could fill the layer (the paper texture layer in your screenshot); Edit>Fill>Pattern and use Filter>Stylize>Emboss to get the same look as the texturizer filter.
    Jun 28, 2012 4:22 AM   in reply to photodrawken
    Good tips, guys!
  • 99jon
    Jan 6, 2010
    Jun 28, 2012 2:59 PM   in reply to photodrawken
    Nice tip Ken. Someone was asking about creating a canvas texture and I’m sure your technique would be suitable. Thanks for sharing with us.
    Jun 28, 2012 7:35 PM   in reply to photodrawken
    It's not as easy using the emboss filter. One needs to adjust the three parameters to achieve the same effect as the filters in the filter gallery.
    But the filter gallery has a lot more options such as combining the filter effects.
    Message was edited by: R_Kelly
    Jun 29, 2012 1:14 AM   in reply to photodrawken
    A variant method to apply textures is to add a new 'Fill layer/pattern...' in overlay mode.
    - click on the small triangle on the right of the image in the dialog,
    - in the new panel, click on the small double triangle
    and from the dropdown menu, choose a pattern.
    This method gives you access to a host of standard various patterns and textures. Remember you can easily create your own patterns from your own pictures. (Menu edit/define pattern). Most of the time you'll use soft light or overlay blend modes.
    You also can transform a home-made pattern with the high pass filter at various radius settings. This can be more natural as it does not add color.
Bookmarked By (1)
