Escanaba1964
Captivate 6 Connection Error for imported video
Jun 27, 2012 12:29 PM
Tags: #error #captivate6 #slide_video
I have inserted a video into a Captivate 6 project. When I publish and preview the swf, I see a "connection error" message instead of the video. I have tried flv and Mp4, importing to the slide and to the library. What am I doing wrong?
    Jun 27, 2012 1:08 PM   in reply to Escanaba1964
    Could you please share the following information:
    Are you accessing the published output from a network share?
    Mayank
    Jun 28, 2012 6:19 AM   in reply to Escanaba1964
    Did you changed the flash player version while publishing the project. And which version of flash player did you selected ?
    Jun 28, 2012 9:46 AM   in reply to Escanaba1964
    Can you please provide us with the following info so that we can see what the actual issue is?
    Which version of Flash Player did you publish before for which it did not work?
    It showed connection error while accessing for shared location or local system or both?
    What is the video type? (Progressive/Streaming/Flash Media) you can get this option in Video Menu-> Video Management...
    Thanks for your co operation
    regards,
    Hari
    Jun 29, 2012 12:43 AM   in reply to Escanaba1964
    Hi  Escanaba1964,
    Can you provide the information regarding the video which you are using in your project ? For HTML5  , flv video with codec On2VP6 is supported; if you are using flv other than this codec, you will not see video on the slide in html5 publish.
    Avinash
    Jun 29, 2012 10:20 AM   in reply to Escanaba1964
    Can you provide us with the project so that we can take a look and pin point the exact issue?
    you can mail the project at har@adobe.com
    regards,
    Hari
    Jul 11, 2012 8:51 PM   in reply to Hari-Krishna-R
    I was having a similar "connection error" problem. In my case, my IIS web server was not configured to deliver .mp4 files by default.
    Best regards,
    Paul
    Jul 11, 2012 9:33 PM   in reply to cunningham64
    Hello,  This may sound like a very dumb question, but what is 'On2VP6 codec'?   I convert my MP4 files to FLV using the Adobe Media encoder.
    Ali
    Jul 11, 2012 9:51 PM   in reply to aliiii123
    CODEC stands for Compressor/Decompressor.
    It refers to the algorithm developed to compress and decompress multimedia such as a video or audio file.
    On2 Technologies was a software company that developed a very effective CODEC known as VP6.  The On2 company was acquired by Google in 2009 and many of their products are no longer available.
    http://en.wikipedia.org/wiki/On2_Technologies
    However the On2VP6 CODEC appears to be still available because it is open-source.
    Jul 11, 2012 9:53 PM   in reply to RodWard
    Thanks Rod
    ali
    Jul 12, 2012 8:57 AM   in reply to Escanaba1964
    Escanaba1964, you're welcome, and glad that helped. Your question helped me to sort out the problem, too.
    Jul 17, 2012 8:07 AM   in reply to Escanaba1964
    I am having the same problem as well (Captivate 6 flv video connection error message). The videos play fine when previewing the project, but no matter how I publish the project I get the connection error. I have tried adjusting the Flash Player setting. I am testing it on my desktop, so it has nothing to do with any webserver settings. The only way the the project will play properly is by opeing the .htm file in Chrome (IE, and Firefox have the "connection error"). I am really at a loss as to where to go from here.
    Jul 17, 2012 5:51 PM   in reply to swcs_ncoa
    @BuckeyeonBragg:  If you are testing this locally on your hard drive, have you made sure that you have the publish folder location set up as a trusted location in your Flash Global Security settings?
    Jul 18, 2012 6:03 AM   in reply to RodWard
    Rod,
    Yes, it is a trusted location. I was able to find a work around for the issue, but I have not found a resolution to actually solve the problem. Here is the workaround:
    1- Delete .flv videos from the slides, save project, close Captivate
    2- Open Adobe Media Encoder CS6
    3- Import .flv files into AME
    4- Convert videos to .mp4 files using the H.264 preset (Androind Phone & Tablet 480p 29.97 fps 640x480)
    5- Export .mp4 files into the same folder that contained the .flv files
    6- Open Captivate in Administrator mode, re-open project
    7- Import .mp4 files into the project library
    8- Drag and drop videos onto their respective slides
    9- Save and publish
    Using these steps the project will play fine using any browser, locally in a pdf, or using the swf file.
    I would prefer to use the .flv files so that I can use the skins that are available in Captivate for the student to be able to control the movie, but I haven't been able to figure out how to get that to work. It works fine in all of the projects that I created using CP 5.5, but not using CP 6. If you have any other ideas, please let me know.
    Aug 8, 2012 11:27 AM   in reply to Escanaba1964
    I am storing my captivate project/videos on my local machine and not uploading to any servers or anthing so that issue is ruled out.
    I successfully imported my AVI file that was encoded and made into an .flv file. It is 3 sec long, about 550MB. I can preview the video, but I get the "connection error" after publishing the video and viewing the video. The video is a motion logo and is the first three seconds of my project.
    I've called Adobe and they are having the same issue on their end when they tried importing their own video and go to publish.
    Is this a bug? because it shouldn't be this difficult to get this work.
    The video works fine in Captivate 5.5 so I know the video doesn't have an issue. I tried opening a 5.5 created project in captivate 6.0, but the video doesn't work there either.
    So I am now waiting for Adobe to figure it out and get back to me....oh joy. Here is the error message in case you want to see what it looks like.
    Aug 8, 2012 12:44 PM   in reply to wendy451
    Hi Wendy;
    How big is the ouputted flv video file? I'm using 6.0 and can successfully publish a 35 mg video file and it runs fine and fast. 550 mg is a really big file for a 3 second video. (even with high res motion graphics) converted to flv its still probably pretty large. So I'm wondering if its giving you a can't connect mesage cause its having a hard time loading it.. just a thought.
    Steve
    Aug 8, 2012 3:16 PM   in reply to StevePixel
    It's a high-def motion logo with audio. The size is 534MB. It is a corporate resource file that is locked down to be used as is.
    I find it strange that the same exact video works with 5.5 and not 6.0.
    Aug 8, 2012 4:35 PM   in reply to wendy451
    So do I. Its strange. I came across this thread regarding Flash Player adjusments.
    http://forums.adobe.com/message/4524565#4524565 other that I am not sure. Best of luck
    Steve
    Aug 9, 2012 1:39 AM   in reply to wendy451
    Hi Wendy,
    Could you please try the following:
    After Creating a project, before publishing, Preview the project in Browser. (shortcut --> F12)
    Please update us with the result.
    Mayank Mahajan
    Aug 9, 2012 9:44 AM   in reply to Mayank08
    The video previews great when I press F12, F3, F4.
    The video is 3 seconds and during those three seconds is when I get the error. The reset of my project is a software simulation that plays great. So my steps were:
    1. Select Software simulation as my project
    2. Record software simulation
    3. Import 3-second motion logo AVI file to the first slide (encoded by captivate)
    4. Publish project
    The end product was three seconds of "connection error" (where the video is supposed to be) and the remainder of the project playing great.
    -w
    Aug 15, 2012 10:50 AM   in reply to wendy451
    I am currently haveing the same proplem with flv videos in captivate 6 using IE9 browser unable to find the video. Althought using FireFox 10.0.1 plays videos fine. I did find that if I publish to a file path that does not contain spaces in the path/folder names then IE will find the videos and play them. Very odd, I consider this a Captivate 6 bug because I don't believe I had this problem with ealier versions of captivate.
    Aug 17, 2012 4:39 AM   in reply to drummin
    I tried the whole morning to publish a file with embedded .mp4 video as .mp4.
    I got a correct and well-working preview in TMP-Directory, but every publishing-attempt  treated video as not been available at the webserver, even if fiile stored locally in same directory.
    Result: a good connection error message in the .mp4
    What would be the workaround for this?
    Maybe there is a workaround by using the URL settings for the progressive DL?
    But all attemts here lead to a bad preview rather than to a problem solution.
    Could anyone help?
  • Anjaneai Srivastava
    Oct 17, 2011
    Aug 17, 2012 4:59 AM   in reply to Escanaba1964
    Hi All,
    Please refer to this article --
    http://forums.adobe.com/message/4623434?tstart=0
    If you have a similar Scenario, try solution shared over there.
    Good Luck!
    Anjaneai
    Aug 17, 2012 5:25 AM   in reply to Anjaneai Srivastava
    Simply Works!
    Thank You!
    Aug 17, 2012 4:06 PM   in reply to ReinerJ
    is there a fix for Cp 5.5?
    Aug 17, 2012 4:16 PM   in reply to casbeck
    well, now I published several more times and the videos play.
    Cp is a very capricious tool.
Bookmarked By (3)
